Worked flawlessly at the first attempt. THANK YOU!!!
I'm sorry.... but wasn't Asadullah the one who said to install AnyCut?
Where can I find the .bin file for use in the emergency mode. That's how bricked I' am currently
I had similar issue, did he LGNPST+DFS trick, but when I copy and past the AAA/HA to the profile and write to phone, after reboot it just reverts to its original status. Tried with zero out ESN then write the AAA/HA, they can stick until I changed ESN back to the real value, it reverts too. How could I save the AAA/HA value in the phone then?
Does the phone need to be put in other mode (emergency or development) in order to make the AAA changes stick? I just used usb diag mode, and my phone could connect/read/write fine. Just have a hard time to figure out why the changes always revert.
Sounds like you missed the part about anycut.
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
Thanks for the reply, that explains it.
So I assume after the shortcut, I no longer need to zero out ESN, my NV items would stick with the "undermined" device?
Also, after I follow the steps in OP with the Anycut setting and phone reboots, I no longer need to mess with this app? Everything else happens in DFS demo?
Thanks again.
So I followed every step and could confirm that the AAA value sticks. But when I do "update profile", error 67's gone, but I still got "client error" and my 1x data is gone too.
When using anycut, should I choose Sprint instead of "undetermined"? I'm using it on Sprint if that matters.
Edit: answer my own question, changed ppp carrier to sprint in anycut cause the nv items not to stick. But why I still could not update profile and get any data?
