What is the best and most stable android 2.3 or 4.0 custom ROM that is compatible on the optimus v.
Did they ever fix the camera problem with CM9? and is MiRaGe a good stable one?
I have one more question before I flash this rom on my Optimus V, will I have to re-activate my phone and put all of my account settings back in after I flash the CM7 rom? I just haven't been able to find a clear answer about whether I will lose ALL settings & current capabilities for phone usage after flashing a rom. Thank you in advance for any help you can give me.
Yes the cam works now in cm9
Are there any android 2.3 custom roms with the touchwiz interface? and what is the best cm7 version?
Are there any roms that use launcher pro or any other launchers instead of adw?
