[ROM][WIP]CM9.1.0-BobZ
suku92
16
3
Re: [ROM][WIP]CM9.0 RC0-BobZ
Can anyone show me a non-themed screen shot of Bob's view of ICS? Maybe the lockscreen/homescreen. I want to compare it to TDM's so I can see if I want to test or not.
I dislike the theme a few posts back, it's not very aesthetic. But it's only a theme.
Nico72
55
16
They are 2 different versions of CM9, which is ICS. The UI isn't going to be super different. The coding is going to be different, and you might get better performance using this ROM or tdm's. Just make a backup of the one your using now, flash this one, and give it a whirl! Don't like it? Just go back to your backup.
drm1992
267
45
Sent from my VM670 using Tapatalk
BuggerZ
139
40
I benchmarked both Bob's and TDM's ROM's. I found Bob's ROM (RC0) to be slightly faster, although it's negligible to me. There are a lot of other UI differences (different launcher, less ringtones, etc). So to me, it all comes down as a matter of preference, as in, which style do you prefer more. I like TDM's more based on style (more stock-ish ICS style).
dzdzjb
71
13
Ran this rom all day ,overclocked 122-748 smartass.
[snip] and it was the hottest my phone has ever felt. I wasn't dl-ing anything but had a missed call and missed text. Possibly just an anomaly.
A quick search didn't help me find a link, but LeslieAnn has suggested that the minimum clock setting should probably be 480 and no lower, and that the processors in our phones are likely to get very hot trying to set itself to a clock speed lower than they were designed to do.
And as BobZ mentioned in the OP, all OVs aren't created equal. Some people get away with some pretty crazy speeds that give me perpetual reboots and overheating.
ThatGuyLurkin
2,155
665
I know this has been asked before most likely and recently, but what causes 3G to disconnect on wifi and sometimes when device is locked?
curtis1973
King Of Pants
Aug 7, 2011
672
131
well both have a lousy startup wallpaper ( no offense fellas but they both are blurry and low quality) and both clock Widgets look weird with jagged edges. but minor stuff you can change easily
Zakman
492
185
So does MMS work? Cause I just went to change the strings in the build.prop and they're already changed.
batteriies
4
Had this rom running for about 6 hours no with zero force close or reboot issues, one thing I have noticed and I'm not sure if this is really anyones fault but my own, but I can't edit my contacts, I can add, remove, set pictures, but I can't actually go in and change numbers on existing contacts. Just throwing it out there.
ThatGuyLurkin
2,155
665
Looool what!?
That's normal. Just like a phone book. :)
Edit: Mis-Read your post! Sorry. :eek:
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Tap "People", find the contact you want to edit, tap it, press the Menu button, and then tap Edit.
batteriies
4
I actually didn't have "People" at all for some reason, which baffles me because it was there when I first booted the phone, it disappeared all together after I took it off the dock, re-flashed and took it off the dock again, but now its still there.
guylenn49
