phonecharger
Re: [ROM][WIP]CM9.0 RC0-BobZ
solid rom. has been my daily for almost a week now. no reboots. amazing job!
gmail 4.x gives me a blank screen when I scroll through an email and once I finish scrolling the blank screen is still there. This cause me not to be able to read any emails that I have scroll on. I reverted to gmail 2.3.6 and that one is working fine. I'd love to be able to use the new ics styled gmail. Anyone else experiencing this?
I have seen this issue, but only once or twice not consistantly.
BOB.
Thanks for this rom, I am really liking it. I feel it runs smoother than the IHO rom did (maybe I am crazy but I think it is the case). Anyway my biggest issue is the speakerphone volume which I am sure it will be fixed sooner or later.
You should be fine with a dirty flash(wipe cache and dalvik)...but you may have to re-flash Gapps.Can we just do the update method or do we need to do a full wipe?
Sent from my VM670 using Tapatalk
hows the battery life?
Pretty good rom as long as you don't touch cpu and gov settings
sent from my icy cold optimus using inverted T.T.2
what's wrong with the settings?
I overclocked and had non-stop freezes.
I oc'd quattrimus and no freezes for me.
Sent from VM670 on MetroPCS
Hey guys, I don't know if this is a known issue or anything, but I can't stream music from Google Music without a force close. Local music plays just fine, but anytime I attempt to stream, it crashes.
I read that this has something to do with adblocking, so I guess a good starting point is to ask:
Does this rom have any sort of adblocking baked in? If so, is there a simple way of disabling it?
This was a problem with Quattrimus and Cold As Ice, the Hosts file (which contains entries for ad blocking) was formatted for a Windows/DOS system when it needed to be formatted for Linux.
This problem has since been fixed, and in Bobz' ROM, the hosts file contains no ad blocking and is in the proper format. I am using Google Music just fine. Have you tried the usual clear data / cache of the app, uninstall, and re-install?
