Kelemvor33
Re: [ROM][WIP]CM9.0 RC1-BobZ
I want to try this tonight or this weekend. Can anyone confirm if I've got everything? Don't want to kill my phone...
Thanks a ton!
OK, so using the pinned How To thread as a guide, I've got the BobZ file, his GApps file, the Wipe file, the Cannibal recovery, and the flashImageGUI file on my SD Card.
Oh, and do I need to be connected to the PC for any reason? I'm using Dropbox to get the files to my SD Card...
Let me know what I've got wrong before I start.
1) Install the FlashGUI app and select Recovery with the Cannibal file
2) Boot via the vol-Down stuff
3) Backup my current data
Do I then use the Wipe.zip file instead of manually doing the wipes from the menus? Is the wipe file better than Drew's wipe in the recovery file?
Does the wipe also do the formatting or do I have to do the Format option as well?
Install the BobZ file
Install the GApps file
Reboot and wait a bit...
Thanks a ton!
