Love this ROM now with brightness fixed and I added the amphetamines mod to it. Still though, the minute I over clock it all hell breaks loose. Why could I run BACKside IHO cm7 overclocked at 806 using interactive gov but can't overclock this ROM?
I'm OC'd to 806 on this rom with no trouble. Your phone has problems.
I've had no issues overclocking with BS IHO cm7 ROM. How is it my phone?
First off remember not all phones are the same , some can take more abuse than others and start off 600/480 interactive to begin with then go up one notch while checking the camera for fc's or a rr and when that happens go one below that ans you now have your max
Anyone else experiencing a power up when the phone is plugged in to charge? Like, my phone will be off and I'll plug it in and instead of it going to a battery charging indicator it simply boots up like I turned it on. Weird.
Anyone else getting white ( blank ) screen in Facebook or boat browser?
Disable CPU rendering and your white screen issues should resolve.
