A-android-B
It's a system app. You have to do it manually with root. You could use adb or a terminal emulator.
I have no option to uninstall voice search. What am I missing here?
USB storage isn't working on my windows home prem 64bit the screen comes up and I click the enable button but thats all that happens. Bug possibly?
Root browser. Free in the market. Open it and go to /system/app/voice search and delete. Reboot the phone then go to market and get voice search. I've been having to redo it after ROM updates as well. Good luck.
You could go about it that way but if you were taking an app off of your pc you wouldn't delete it you would uninstall it. I think it removes more left over things on your phone. Root browser will work though but you may consider a wipe cache and dalvik cache when your done to rebuild them with out any thing from apps you don't have. I'm not saying any one is wrong just throwing out suggestions
hows the battery life compared to the quattrimus beta2?
Just thought you guys should know, CyanogenMod is starting to officially release stable builds of CM9 for many devices, might wanna check out their github or something to see what's new.
Sent from my LG-E739 using Tapatalk 2
Maybe I'm the last one to realize this, but USB storage works if you disable USB Debugging
Please fix the HD problem! I'm tired of using this ROM at low quality
