[ROM][WIP]CM9.1.0-BobZ
Rudeco
Banned
Jul 26, 2012
129
3
Thx a million @BobzHome. I can finally overclock a CM9! The new kernel is the shiznit! Anyone tried flashing the amphetamines or the disable gpu rendering?
Reactions: BobZhome
A-android-B
414
21
I'm running the latest release with amphetamines and egl patch. Its so sweet even the brightness control via swyping the status bar is smooth. Thanks again bobzhome.
Reactions: BobZhome
Rudeco
Banned
Jul 26, 2012
129
3
Question, as I may have spoke too soon. After I rebooted once after flashing and overclocking, I've gotten a few FC now so what changed after the first boot after OC'ing?
Rudeco
Banned
Jul 26, 2012
129
3
Anyone else experiencing this? Package File is Invalid, while updating from play store?
**FIXED** I went into Manage Apps, removed Updates and opened Play Store back up. It re-updated and works fine now.
sellers86
1,837
617
I reflashed and retested... my notification sound does not go off no matter what. I don't get it
Rudeco
Banned
Jul 26, 2012
129
3
Weird blue screen anyone? Happened after turning screen back on from a 10 minute break in playing on my OV.
ThatGuyLurkin
2,155
665
The only problem I ran into is that when opening the Camera it can cause a soft reboot. The screen would go black, still on, and not so anything.
Could be my over clock though.
Rudeco
Banned
Jul 26, 2012
129
3
Where are you OCed to? I'm getting reboots at 480 and 748 using SalvagedZen. Anyway to get offline charging back or is that completely out of this rom?
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
Offline charging is kernel governed so you can't just "switch it on."
ThatGuyLurkin
2,155
665
I'm running
320/806 Smartass2
I actually prefer Online Charging. I reboot a lot due to testing. Offline charging kills the reboot.
vawlk
12
Re: [ROM][WIP]CM9.0.0-BobZ
Also noticed that my audible notifications are only playing through the phone speaker when using a bluetooth audio device. The volume lowers (when playing music) like usual but the audio never goes through the BT device.
sellers86
1,837
617
this is known with ICS. does it with headphones too.
Rudeco
Banned
Jul 26, 2012
129
3
Anyone know why I'm still getting Invalid Packet Data when I try to update or install anything from Play Store?
sellers86
1,837
617
Is there any way to fix this? It's really annoying, and the only thing keeping me from finally switching to ICS.
it would most likely have to be done in source, and audio routing is nasty. dont expect it to happen anytime soon.
kirk781
