[ROM][WIP]CM9.1.0-BobZ
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Anyone know why I'm still getting Invalid Packet Data when I try to update or install anything from Play Store?
Try uninstalling play store updates
Unsync account
Wait a couple secs
Resync
Let play store update to latest version
Enjoy
Sent from my LG-LS670 using Tapatalk 2
Ryuk6666
489
88
Still not working. :(
do you have an ext partition on your sd card? Cause if you don't, it's doing that because your dalvik cache is full in the system. So if you don't have an ext partition, make one and dalvik and apps get moved there automagically and you shouldn't have to worry about the invalid package error any longer :) hope this helped
Sent from my Paranoid OV :D
ThatGuyLurkin
2,155
665
This is actually pretty solid. Been watching YouTube videos and browsing tapatalk.
And its actually been 2 hours. The time is screwy on ICS.
88% - 77%
ThatGuyLurkin
2,155
665
Motoblur inspired.
Even after 10 hours, it still says 1h 19M battery. I have 58%. Changing the theme, i tend to start getting alot of reboots.
When listening to Apollo for 5 minutes, the music stops and screen goes black and i have to battery pull. Any solution?
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
Motoblur inspired.
I have the same problem with Apollo... I listen for five minutes and it freezes completely and restarts the song. Its so annoying that I gave up on it and decided to use play music instead (play music has a better interface anyway).
Rudeco
Banned
Jul 26, 2012
129
3
Has anyone successfully eliminated the ' white screen ', in Facebook, browser, etc? I've flashed the EGL patch and everything but still get it every time. Pretty much my only gripe about an otherwise awesome and stable cm9.
Rudeco
Banned
Jul 26, 2012
129
3
So I have 108mb internal space available, but still having problems updating and downloading from play store. Its either Invalid Packet or Just doesn't install. Any ideas? I don't see how an SD ext partition would help being that I'm not using all the internal phone storage.
JussCallMeUno
Active member
Jun 29, 2011
39
3
Unsync gmail and try it again.
atrain2324
203
Re: [ROM][WIP]CM9.0.0-BobZ
I'm on MIRAGE right now. My SD-Ext partition is formatted as FAT32, which I know can't be read on ICS roms...I have over 85 apps on the SD-ext partition and if I reformat it to ext-3, I need to reformat it back to FAT32 if I ever go back to MIRAGE (restoring it via Nandroid backup)?
Basically, I just want to see how this ICS rom works, see if I like it and if I don't, I'd like to be able to restore my backed up Mirage ROM without any complications...if that makes sense?
thewraith420
1,987
223
63
Make sure your recovery backs up your sd-ext (I think all do) and I'm pretty sure sure you'll have no issues
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
A-android-B
414
21
Well we'll see how this goes. I heard it takes at least 3 reboots for this ROM to run smooth? And that the initial boot takes forever?
Forget what you heard lol. It's pretty smooth even one minute after the very first boot for me. The first boot after flash can take a couple more minutes then say the initial boot of a GB rom but I didn't even notice really
