Badboytoast
This is a CM9 ROM, Bob has not made an AOKP build.
Yet...
Unplugged it at six this morning. Sent several texts, several emails, looked at tapatalk, and checked the time A TON (I was at school)... I had four bars all day and access to campus wifi so no slow 3G. 16 hours is good, but it just goes to show how inefficient these phones are with the screen sucking 76% of the battery... an its not even a big screen.
Was your brightness turned all the way up? Turning it down a bit may improve your battery life even more.
I have been having problems with music. I'm not using apollo, I'm using fusion. When I'm playing music it tends to screw up and make a funny sound. No biggie, just figured I'd let ya know.
Sent from my sweet Ice Cream Sandwich.
This happens to me, but differently.
It makes. Cut off noise like it shorted out and the screen goes black so I can't do anything.
How do you guys feel about MIUI V4?
Also, my phone took a little water damage. Now it freezes a lot of ICS while unlocking, typing, or just while screen is off
any ideas on how to remove the "Android is upgrading"?
Still a mystery to this day
Sent from my LG-LS670 using Tapatalk 2
Word on the street is Bob has got it fixed in cm10
You must have done a dirty flash...wipe everything EXCEPT sd-card and re-flash.His cm10 is on my optimus v, still doing it. Unless he fixed it in some nightlies I'm not seeing? I flashed it Thursday though.
Sent from my LG Optimus Elite, bone stock.
Updated OP with new build...
Enjoy!
Enjoy!
