LG_VM670
This should be stickied
It awesomeness for the OV
Will update after school tonight or tomorrowOP needs an update!! Also this should be stickied
sent from my VM-670 on CyanMobile
He came home, threw his bookbag, played games and didn't do his homework
@nate456 lol
@sammyz12 I don't think you can flash any img files in any recovery ....
The vm670 cwm recovery that bobz hands out is usually found in .img form, i think.
---------- Post Merged at 05:40 PM ---------- Previous Post was at 05:34 PM ----------
I know this might be the wrong place to ask it, but i figured since we were talking about recoverys not to long ago i figured i'd ask. If i change my recovery from cwm 4 to cannibal open touch can i still use my old nandroids. Or for any recovery switch for that matter.
miui and democracy both point to http://forums.androidcentral.com/op...cks/162404-themes-roms-updated-8-02-12-a.html
That is where both of the ROMs are located...
