1. sammyz's Avatar
    I successfully flashed this firmware!!!!!!!!!
    http://forums.androidcentral.com/opt...ml#post1886247
    Original Post:
    I just successfully extracted the .bin file for the Optimus S from the .cab file!
    Going to make a new unbrick guide for the Optimus S tomorrow!
    Can someone please send me the Optimus V ZV4/ZV5 firmware so I can extract it? I see links on xda here:
    Upgrading Optimus-V VM670ZV4 to VM670ZV5 firmware - xda-developers
    but they require passwords and I am unable to PM the guy because I do not have enough useful posts. Thank you.
    mlson likes this.
    06-24-2012 11:32 PM
  2. asadullah's Avatar
    I already posted the zv4 cab in the other thread
    06-24-2012 11:37 PM
  3. sammyz's Avatar
    ^duh
    and I got a response for the p/w to the zv5 link, not saying who it is though. Unless he wants to reveal himself.
    06-24-2012 11:43 PM
  4. asadullah's Avatar
    ^duh
    Good luck with that. Don't think anyone has been able to extract the bin or anythimg else from those cab files. On a side note if you don't know already you can just double click the cab in windows then pull the wdb and wdh files from it.
    06-24-2012 11:56 PM
  5. sammyz's Avatar
    It doesn't work that way.....not for me...does it work for you?
    06-25-2012 12:25 AM
  6. asadullah's Avatar
    Yes.
    I can also do it with sprint cabs using explorer
    06-25-2012 12:34 AM
  7. sammyz's Avatar
    Yes.
    Can you send me the ZV4 extracted then?
    ....Kinda weird windows 7 isn't able to O.o
    Are you on ubuntu?
    06-25-2012 07:25 AM
  8. sammyz's Avatar
    @asadullah, NVM
    06-25-2012 08:48 AM
  9. sammyz's Avatar
    ZV5 bin file:
    06-25-2012 09:58 AM
  10. asadullah's Avatar
    .....How? I've had a brick for months
    06-25-2012 10:42 AM
  11. sammyz's Avatar
    I'm going to write a guide once I figure out everything...
    It will be the ultimate unbrick source for the Optimus V!
    And then I will do one for the Optimus S.
    I wasn't able to flash the ZV5 at first, I found the original name of the .cab and I renamed it and BAM it worked like a charm!
    06-25-2012 11:03 AM
  12. asadullah's Avatar
    Can you upload the zv4 bin?
    06-25-2012 11:21 AM
  13. sammyz's Avatar
    I'll upload it and PM it to you, I only want the link in my unbrick guide, although I will only be using ZV5 in it because of the different touchscreens.....
    asadullah likes this.
    06-25-2012 11:36 AM
  14. Badboytoast's Avatar
    Man this is some advance stuff , please post a link to you guide once you set it up! Thanks!
    06-25-2012 12:53 PM
  15. sammyz's Avatar
    http://androidforums.com/optimus-v-a...oob-proof.html
    06-25-2012 01:22 PM
  16. ThatGuyLurkin's Avatar
    Firmware, not radio. Correct?
    Basic: This wont downgrade you?
    06-25-2012 03:22 PM
  17. sammyz's Avatar
    This flashed the ZV5 firmware that everyone thought was borked! As well as the ZV4 Firmware
    This will downgrade/upgrade you, look here for that guide: http://androidforums.com/optimus-v-a...stock-zv5.html
    06-25-2012 03:43 PM
  18. ThatGuyLurkin's Avatar
    That didn't exactly answer my question, sorry.
    The ZV9 update, basically, will it REMOVE it?
    06-25-2012 06:08 PM
  19. sammyz's Avatar
    Yes it will, but this is better for upgrading/downgrading, here:
    06-26-2012 09:08 AM
  20. thewraith420's Avatar
    Definetly works!! i just downgraded back to stock zv4
    06-26-2012 08:11 PM
  21. sammyz's Avatar
    Yea, if anyone needs the ZV4 firmware, PM me, it is only for those who have the old screen....
    Sent from VM670 on MetroPCS
    06-26-2012 10:36 PM
  22. thewraith420's Avatar
    Just a thought if someone with a new screen wanted bootloader access... Something that might work is setting up your pc for Android screencast then update to the zv4 firmware. The screen would be blank if successful but screencast should work. Use screencast to root and install a compatible rom and recovery.... Just thinking out loud really but it would in theory give zv5 owners fastboot access
    06-27-2012 08:10 PM
