1. 1keyblade's Avatar
    So back in October, I rooted my optimus v with superuser and had no problems until a few months after in which i woke up one morning to find my phone in an lg symbol boot loop. I'm finally wanting to try to fix the phone but i have erased almost all the android files on the micro sd card. Would it still be possible to fix the phone without those android files? Or am i out of luck at this point? I can't get into recovery mode but i do have access to emergency mode. I also have the lg drivers installed.
    06-25-2012 12:02 PM
  2. andrewnelson23's Avatar
    what happens when you try recovery mode? lg splash or blank screen?
    06-25-2012 12:17 PM
  3. 1keyblade's Avatar
    the screen goes black for a second and then the boot loop continues.
    06-25-2012 12:21 PM
  4. topdawg661's Avatar
    Emergency mode?? Can't he use that?
    06-25-2012 12:36 PM
  5. sammyz's Avatar
    He's in a bad/wrong screen recovery (I think) and no that's a last resort....
    Try this here: http://androidforums.com/optimus-v-a...ted-phone.html
    If he can't even get to a black screen while accessing recovery he is bricked, it can be fixed here: http://androidforums.com/optimus-v-a...oob-proof.html
    06-25-2012 12:43 PM
  6. 1keyblade's Avatar
    I just tried the first link you gave me. I placed the xionia_cwma_12518.3 onto the root of the micro sd and tried the home+vol down+pwr but nothing different happened. Screen just went black and continued the loop. I'm going to check out the second link.
    06-25-2012 12:57 PM
  7. topdawg661's Avatar
    Oh OK my bad. Never happened to me so idk :o haha sorry >_<
    06-25-2012 12:58 PM
  8. kcls's Avatar
    You have to write (Install) the recovery using ADB and Flash_Image. You can't just put it on your SD Card and expect it to work.
    Sent from my Optimus V using Tapatalk 2
    06-25-2012 01:46 PM
