1. androidalais's Avatar
    I flashed the IHO Backside rom a couple days ago and it works almost perfectly with only the ocassional lag (no overclocking performed.) But today i noticed that my wifi dosn't work properly, it says its connnected everywhere i look but when i try to use it, say in the play store it says no connection. When i open up google in dolphin it loads the page most of the way and then stops loading. It worked the day i flashed it. Any ideas? It's not like i need wifi because i have unlimited data but where i live my service isn't that great. But with the 3g/4g speed optimizer my data speeds have increased 10 fold. Still would be nice to have wifi. Thanks.
    06-26-2012 08:39 AM
  2. ilikechicken123's Avatar
    Maybe you should reflash?
    Do you know for sure that your router is working and there's no problems with it? I've never had this issue with backside.
    06-26-2012 10:09 AM
  3. androidalais's Avatar
    is there anyway to reflash without having to go through restoring all my apps from ti-backup? and i'm not sure if it is. I will reboot the router when my dad gets off work.
    06-26-2012 10:26 AM
  4. sellers86's Avatar
    You can just reflash right over top
    06-26-2012 10:33 AM
  5. androidalais's Avatar
    How does that work? sorry, i'm kinda a noob to flashing. This is my first flash besides the cwm recovery.
    06-26-2012 10:35 AM
  6. s13-d's Avatar
    Glad to see I wasn't the only one. Been using IHO for a few months and out of nowhere the wifi just decided to quit this weekend - it would sit there saying "Connecting..." then "Disconnected" and wouldn't show any available networks. Tried rebooting, purging the wifi cache, deleting all the remembered networks... nothing. Rather than re-flash the same ROM, I discovered that the devs here have pretty much everything from ICS working on these phones now, so I upgraded to quattrimus and have been very pleased so far.
    06-26-2012 01:26 PM
  7. androidalais's Avatar
    Are there any features that you have found don't work so far? I really enjoy this rom but the wifi thing is making me mad.
    06-26-2012 01:30 PM
  8. androidalais's Avatar
    And where can I download the rom?
    06-26-2012 01:39 PM
  9. s13-d's Avatar
    The display drivers in ICS aren't as good as the ones in 2.x ROMs, so if you play a lot of graphic-heavy games or use Netflix on your phone, you're better off sticking with IHO. Aside from that, there are minor headaches such as needing a free third-party app to play video files and having to remove the pre-installed Voice Search and replace it with the one from the market, but if you ask me, it's a small price to pay to have the latest and greatest running on our dated little phones.
    06-26-2012 01:40 PM
  10. s13-d's Avatar
    http://forums.androidcentral.com/opt...rimus-ics.html
    Since it's a whole different generation of ROM, after performing the standard backup steps (Titanium Backup for apps and a full nandroid in recovery), wipe your cache and dalvik-cache, then format your boot, cache, data, and system partitions for a clean slate.
    06-26-2012 01:45 PM
  11. androidalais's Avatar
    what are the differente mirriors for? is there any difference from x to x?
    06-26-2012 01:54 PM
  12. s13-d's Avatar
    No, just multiple servers to download from in case one is down. Just make sure you choose the right device, i.e. for Optimus V use a mirror listed under "CM9 VM670." Don't download anything listed under AOKP as it is currently broken.
    06-26-2012 01:58 PM
  13. androidalais's Avatar
    I know, what is AOKP?
    06-26-2012 02:51 PM
  14. EarthnFire78's Avatar
    AOKP = Android Open Kang Project
    06-26-2012 04:45 PM
  15. sellers86's Avatar
    just a suggestion, and if you dont want to listen you dont have to, but ICS is in pre-beta. seeing as youve only used one rom, i wouldnt recommend using it until you get more experience
    06-26-2012 05:52 PM
  16. androidalais's Avatar
    I know, i didn't plan on it anyway. i'm waiting for it to go to beta or nightly before i will use it.
    06-27-2012 07:17 AM
  17. androidalais's Avatar
    I tried flashing over it to see if it would fix the wifi problem but it still dosn't work. It might just be the wifi network isn't supported by my phone. I will check with another wifi network.
    06-27-2012 07:18 AM
  18. clodfelterac's Avatar
    could be the modules... flash bobzv4 or mrg666s kernel... :-)
    06-27-2012 07:29 AM
  19. androidalais's Avatar
    I figured out its just my router, needed rebooted.
    06-29-2012 08:07 AM
