10-19-2012 05:59 PM
329 1234 ...
tools
  1. sellers86's Avatar
    I'll flash and test right now(:
    Sent from my AT100 using Tapatalk 2
    let me know how it goes.
    06-27-2012 03:09 PM
  2. jonny5449's Avatar
    thats all i did... lol. i didnt run a new build or anything
    Weird well I'm gonna flash the v one with no fix....... after waterpark
    I don't care who u are this is an awesome song
    sellers86 likes this.
    06-27-2012 03:28 PM
  3. topdawg661's Avatar
    Booting up now. All the problems I run into I will put on this post
    Edit: the whole screen is off set which makes it impossible to type so Its hard to set up and test.
    It fixed once I locked my screen.
    Runs super smooth once I messwd with the advanced settings. And oc'd it. My only problems is the offset and the wifi( which you already said)
    Great job!!(:
    06-27-2012 03:37 PM
  4. sellers86's Avatar
    Edit: the whole screen is off set which makes it impossible to type so Its hard to set up and test. Click to view quoted image
    Great job!!(:
    I'm not sure what is up with the offset... I'll reflash the one I uploaded and if I don't get it I'll reupload. Its hard to fix something I can't reproduce. Thanks for the feedback and I'm glad you like it
    topdawg661 likes this.
    06-27-2012 04:22 PM
  5. topdawg661's Avatar
    I loved it! Keep up the amazing work!(:
    06-27-2012 04:44 PM
  6. sellers86's Avatar
    I may have a surprise here in a month or two
    topdawg661 and inceyet like this.
    06-27-2012 05:56 PM
  7. topdawg661's Avatar
    Give a hint?
    06-27-2012 06:12 PM
  8. sellers86's Avatar
    Give a hint?
    That was a hint lol. Not sure what else I can say without giving it away
    06-27-2012 06:26 PM
  9. topdawg661's Avatar
    Well I can't wait(:
    06-27-2012 06:26 PM
  10. sellers86's Avatar
    Well I can't wait(:
    Hopefully I don't disappoint.
    06-27-2012 06:31 PM
  11. rukin5197's Avatar
    Woot! Is the battery life as good as it was back then?
    06-27-2012 06:50 PM
  12. Nate456's Avatar
    I may have an idea on what it is.:rolleyes:
    Sent from my Droid using Tapatalk 2
    cole2kb likes this.
    06-27-2012 06:56 PM
  13. BobZhome's Avatar
    For the wireless issue...make sure you use the wireless module that was in the same rom as the boot.img...If it is, then it's a permission issue.
    06-27-2012 07:27 PM
  14. sellers86's Avatar
    ill give it a try. Thanks!
    06-27-2012 07:30 PM
  15. sellers86's Avatar
    pretty much
    06-27-2012 07:31 PM
  16. sellers86's Avatar
    what is that. send me a pm and ill let you know if your right. but i dont think you will be
    06-27-2012 07:31 PM
  17. rukin5197's Avatar
    Actually now that I think of it, this is right. If you used an old boot.img from Bob's previous build, and you're using the newer modules, they should be incompatible.
    Are your sources for this on git? Better to take a look at it there.
    06-27-2012 08:07 PM
  18. sellers86's Avatar
    no i dont know how to use git. and wifi is even broke when i dont use a different one. im building with the kernel source soon and well see if that works
    06-27-2012 09:29 PM
  19. topdawg661's Avatar
    Don't wanna make you mad or anything but I hope u get all the bugs and kinks out. This rom is amazing! If wifi worked it would be my daily! You ever need a tester I'm here! Amazing job!
    06-27-2012 11:46 PM
  20. sellers86's Avatar
    doesnt make me mad. i knew wifi would be a big thing, and i was considering not releasing it until i got it working, but i did anyways.
    06-27-2012 11:50 PM
  21. terthii's Avatar
    Maybe v one will work just make a keypad switch
    I'm sorry, what is a keypad switch?
    06-28-2012 10:44 AM
  22. Zhara's Avatar
    Exactly what it sounds like. The Optimus V and S are basically the same except the home and menu keys are switched (on the S it goes home, menu, back, search...on the V it's menu, home, back, search). So, if I flashed a V rom on my S my home key would then function as the menu key and vice versa. Therefore we need a keypad switch to fix it
    06-28-2012 11:11 AM
  23. Ryuk6666's Avatar
    Never noticed this thread mostly because I stay hidden in my favorites lol. But it looks pretty tight. I might check it out when I'm not too lazy and I might have an idea what your surprise is but I think I'm probably wrong lol
    G-T-R & Quattrimus CM9 Nuff' said.
    (Also, sent from my LG-VM670 using Tapatalk 2.)
    06-28-2012 11:18 AM
  24. inceyet's Avatar
    What cna is back word gonna check it out as soon as I get off work. I'll give updates
    06-28-2012 01:01 PM
  25. ilikechicken123's Avatar
    downloading now.! I will post bugs and such after I flash .
    jonny5449 and sellers86 like this.
    06-28-2012 01:12 PM
329 1234 ...
Tags for this Thread
