10-19-2012 05:59 PM
329 ... 45678 ...
tools
  1. ThatGuyLurkin's Avatar
    What if you base it of TDMs rom?
    07-04-2012 06:33 PM
  2. sellers86's Avatar
    what do you mean base? this isnt a port. this is built from source...
    07-04-2012 06:35 PM
  3. Badboytoast's Avatar
    I think thatguylurkin meant combined them together!
    Hummmmm I wonder now that would turn out?
    Sent from my VM670 using Tapatalk 2
    07-04-2012 07:38 PM
  4. sellers86's Avatar
    It doesn't work. Cna refuses to run with gingerkernel.
    07-04-2012 08:07 PM
  5. inceyet's Avatar
    Sellers I just tried to flash cna and the screen was split any thoughts fyi SD is partioned 512ext 64 on on a 16 g
    AOKP, G-T-R, MiRaGe, Godzilla, JOYOS, Harmonia killing the game!!!!
    sellers86 likes this.
    07-05-2012 03:26 PM
  6. jonny5449's Avatar
    Put phone to sleep and wake up
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-05-2012 03:28 PM
  7. sellers86's Avatar
    I'm not sure why it does this, people are reporting it on bobzhomes ICS rom also. It doesn't happen to me.
    topdawg661 likes this.
    07-05-2012 03:36 PM
  8. ThatGuyLurkin's Avatar
    I just meant for the wifi issue. :P
    07-05-2012 05:01 PM
  9. sellers86's Avatar
    kernel isnt the issue. Ive tried different kernels and it doesnt work. I made some edits and then I deleted something wrong and I borked my setup. It takes a couple of hours to add the modified files then my own fixes, and I havent had a chance to do it. Im not sure what it is. when i get a chance ill logcat it and see what i get. thanks though.
    Badboytoast likes this.
    07-05-2012 05:54 PM
  10. topdawg661's Avatar
    Bump
    07-07-2012 10:52 AM
  11. sellers86's Avatar
    Sorry guys, I haven't been able to work on this for a while. The day my build environment broke, I decided to try getting a logcat of turning on wifi. I couldn't get adb working on 12.04 Ubuntu. So I installed 11.10. I couldn't get a good sync on any git. So yesterday I installed 10.04 and everything's up and running, though I haven't set up for cna yet. Sorry
    07-07-2012 11:52 AM
  12. sellers86's Avatar
    Is anyone interested in this?
    jonny5449, topdawg661 and inceyet like this.
    07-08-2012 09:38 PM
  13. jonny5449's Avatar
    In cna I am
    07-08-2012 09:44 PM
  14. reaper420's Avatar
    I would love to use this but without wifi I can't use it
    07-08-2012 09:45 PM
  15. jonny5449's Avatar
    Ya that's my reason too
    07-08-2012 09:59 PM
  16. topdawg661's Avatar
    Yes I am(:
    07-08-2012 11:45 PM
  17. inceyet's Avatar
    Definitely been anticipating the update hopefully you can get it going
    07-09-2012 01:03 AM
  18. sellers86's Avatar
    Well, it'll be a while. I'm currently also working on something else, and haven't been able to get the environment set up. I've spent probably ~7 hours of the last 2 days working on something else, not to mention work, and my social life. Remember, I'm 15 and also, I like to sleep during the day. A lot. Lol. Thanks for the support, ill try to get it going soon.
    inceyet and topdawg661 like this.
    07-09-2012 01:26 AM
  19. cole2kb's Avatar
    Right now my want is a stable AOKP, but CNA seems to have most if not all of it's features, so it could easily become my daily as well. I'd love to see it continue development.
    07-09-2012 01:40 AM
  20. sellers86's Avatar
    Ill do my best. If all goes well though, I think you may like my other project
    07-09-2012 01:56 AM
  21. jonny5449's Avatar
    Never under-estimate sellers :sly::sly:
    07-09-2012 11:52 AM
  22. Nate456's Avatar
    Yes, yes we will
    Sent from my Droid using Tapatalk 2
    07-09-2012 12:55 PM
  23. topdawg661's Avatar
    Bump(:
    07-10-2012 08:58 AM
  24. jonny5449's Avatar
    Can't wait for wi fi
    07-10-2012 10:19 PM
  25. sellers86's Avatar
    sorry guys, but this wont be getting much attention from me for a while while im trying to work on jellybean. im not dropping it though.
    topdawg661 and Teh_Gaberz like this.
    07-11-2012 12:01 AM
329 ... 45678 ...
Tags for this Thread
