10-19-2012 06:59 PM
329 ... 678910 ...
tools
  1. sellers86's Avatar
    I will be uploading a build with wifi working tonight thank drewwalton and me2151, I used their fix for cm10.
    07-20-2012 06:31 PM
  2. topdawg661's Avatar
    Omg!! can't wait!!
    inceyet and sellers86 like this.
    07-20-2012 06:46 PM
  3. Nate456's Avatar
    Nice:thumbup::thumbup::thumbup:
    Sent from my shole using Tapatalk 2
    07-20-2012 07:07 PM
  4. sellers86's Avatar
    Update is up, have at it! report any issues here
    CHANGES:
    fixed wifi (thanks drewwalton and me2151)!
    added egl tweak for better preformance
    topdawg661 and jonny5449 like this.
    07-20-2012 07:07 PM
  5. jonny5449's Avatar
    CHANGES:
    Gigidy
    Sent from my LG-LS670 using Tapatalk 2
    07-20-2012 07:11 PM
  6. topdawg661's Avatar
    Once I get out of work ill flash!
    sellers86 and jonny5449 like this.
    07-20-2012 07:18 PM
  7. jonny5449's Avatar
    When I hook to wi fi ditto here
    07-20-2012 07:26 PM
  8. jonny5449's Avatar
    Downloading
    Will post if it worked
    sellers86 likes this.
    07-20-2012 07:31 PM
  9. topdawg661's Avatar
    I couldn't wait so I flashed before work haha I go to work in 20 min I will report back after. So far amazing
    Sent from my VM670 using Tapatalk 2
    07-20-2012 07:41 PM
  10. inceyet's Avatar
    Downloading now
    07-20-2012 07:53 PM
  11. jonny5449's Avatar
    Amazing on my s I'm still finding ways too make smoother but I don't mind :thumbup::thumbup::thumbup:
    Thx
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-20-2012 08:10 PM
  12. JasonDiaz123's Avatar
    I cant restore apps from Titanium back up nor from the google store . I can only install from the apk. files i downloaded onto my sd card
    07-20-2012 08:19 PM
  13. JasonDiaz123's Avatar
    nvm only when i try to restore them from my titanium back it wont work :\
    07-20-2012 08:33 PM
  14. sellers86's Avatar
    I can't help you there, I dont use titanium backup. My advice is to use mybackup
    07-20-2012 08:36 PM
  15. JasonDiaz123's Avatar
    Okay thanks for the advide.. just one more question , i always set my cpu to 600-728 , but one this rom i guess its lagging it because it jitters sometimes...idk what it is , i didnt mess with anything else in the performace section because i really dont know much about the tweaks and other stuff , just cpu
    07-20-2012 08:53 PM
  16. sellers86's Avatar
    I can't recreate the issue. What do you mean by jittering?
    07-20-2012 09:15 PM
  17. jonny5449's Avatar
    Tips if your a s user
    Don't flash different kernel
    Download apex
    CPU settings to 768 Max 286 min
    Change buttons with app over at xda
    Change virgin mobile to sprint
    Mess around with tweaks
    07-20-2012 09:26 PM
  18. JasonDiaz123's Avatar
    Jittering as in um .. when i see a picture the picture flashes like 4x then stays normal . idk but umm is the camera suppose to work yet? cause mines dont, im just saying -.-
    07-20-2012 09:29 PM
  19. sellers86's Avatar
    Not sure about the jitters. And the camera prob is in the op
    07-20-2012 09:39 PM
  20. topdawg661's Avatar
    Lock screen didn't work once wouldn't let me unlock. So I had to reboot. And there's no music player???
    07-21-2012 01:08 AM
  21. sellers86's Avatar
    Man, I always forget about that . And by lock screen not working, do you mean it was split? If that's the case, lock and unlock the phone. And would you happen to have an sd-ext partition?
    topdawg661 likes this.
    07-21-2012 01:11 AM
  22. topdawg661's Avatar
    I mean like my touch screen wouldn't response? And I've never had an SD partition.
    07-21-2012 01:23 AM
  23. inceyet's Avatar
    Report: same spilt screen boot issue as Bobz and Johnnys roms (fix is the same press power button after boot is done) I've been running for a couple of hours now @600/480 interactive no rr , tb works fine to reinstall apps ( sellers I know with tdms ics it uses the SD next partion to install apps automatically just wondering if you were planning to add that feature on cna not a big issue just curious don't mind using tb) standard lock screen works just fine , that's about it for now for what I've really messed with I'll be back later with a update. Aside that yo looking real nice great work bro :thumbup::thumbup:
    Sent from my VM670 using Android Central Forums
    07-21-2012 01:44 AM
  24. sellers86's Avatar
    I'm 95% sure the split screen is something in bobs device and vendor blobs. And its caused by having a sd-ext partition. And I'd gladly add the script if I knew how. . I'll talk to tdm about that, may be in a coming update. I'll update tomorrow and add apollo. Glad it works for you though
    inceyet likes this.
    07-21-2012 01:49 AM
  25. topdawg661's Avatar
    I love it even more then the first day you posted it! Great rom man!(:
    07-21-2012 02:05 AM
329 ... 678910 ...
Tags for this Thread
