Can't wait to jump on this once the Wi-Fi gets fixed, I live in a horrible signal area so Wi-Fi is kind of a must
Im working on it, i just have no idea whats wrong with it...
..... i have no clue there. lol
I'll flash and test right now
Sent from my AT100 using Tapatalk 2
Maybe v one will work just make a keypad switch
I don't care who u are this is an awesome song Linkin Park - BURN IT DOWN (Official Music Video) - YouTube
thats all i did... lol. i didnt run a new build or anything
Booting up now. All the problems I run into I will put on this post
Edit: the whole screen is off set which makes it impossible to type so Its hard to set up and test. Click to view quoted image
It fixed once I locked my screen.
Runs super smooth once I messwd with the advanced settings. And oc'd it. My only problems is the offset and the wifi( which you already said)
Great job!!
I loved it! Keep up the amazing work!
Give a hint?
Well I can't wait
For the wireless issue...make sure you use the wireless module that was in the same rom as the boot.img...If it is, then it's a permission issue.
Woot! Is the battery life as good as it was back then?
