[ROM][ALPHA][WIP][ICS]: CodenameAndroid
topdawg661
333
70
Booting up now. All the problems I run into I will put on this post
Edit: the whole screen is off set which makes it impossible to type so Its hard to set up and test.
It fixed once I locked my screen.
Runs super smooth once I messwd with the advanced settings. And oc'd it. My only problems is the offset and the wifi( which you already said)
Great job!!:)
Sent from my AT100 using Tapatalk 2
Reactions: sellers86
sellers86
1,837
617
Edit: the whole screen is off set which makes it impossible to type so Its hard to set up and test. Click to view quoted image
Great job!!:)
I'm not sure what is up with the offset... I'll reflash the one I uploaded and if I don't get it I'll reupload. Its hard to fix something I can't reproduce. Thanks for the feedback and I'm glad you like it :)
Reactions: topdawg661
BobZhome
296
627
For the wireless issue...make sure you use the wireless module that was in the same rom as the boot.img...If it is, then it's a permission issue.
