I may have an idea on what it is.
Sent from my Droid using Tapatalk 2
what is that. send me a pm and ill let you know if your right. but i dont think you will be
For the wireless issue...make sure you use the wireless module that was in the same rom as the boot.img...If it is, then it's a permission issue.
Actually now that I think of it, this is right. If you used an old boot.img from Bob's previous build, and you're using the newer modules, they should be incompatible.
Are your sources for this on git? Better to take a look at it there.
Don't wanna make you mad or anything but I hope u get all the bugs and kinks out. This rom is amazing! If wifi worked it would be my daily! You ever need a tester I'm here! Amazing job!
Sent from my AT100 using Tapatalk 2
Maybe v one will work just make a keypad switch
I don't care who u are this is an awesome song http://www.youtube.com/watch?v=dxytyRy-O1k&feature=youtube_gdata_player
I'm sorry, what is a keypad switch?
I FELL IN LOVE WITH THIS ROM!!!!! Its great. The only problem I had besides it taking forever to boot was tethering not working but its because of the wifi not working. I can live once that's fixed. I didn't get a screen offset. And the in call speaker isn't very low like CAI, BobZ ics, quattrimus, or godzilla rom. I can actually hear the person on speaker during calls. AMAZING!
tethering doesnt work on any ICS ROMS. glad you like it though!
Panorama and Video recording aren't working either :c
It also doesnt play videos (youtube) and such. And videos on sd card play choppy.
I'll look into this.
Look into it....? Wasn't the issue that Quallcom or whatever doesn't want to make our Arm6 drivers for video acceleration or whatever? TheLeavdn linked people to it before.
