01-05-2016 04:35 PM
2,975 ... 99100101102103 ...
tools
  1. brotherswing's Avatar
    Handcent was giving me bigger issues with the lock screen than reboots.
    sent from here to there...
    09-10-2012 07:01 AM
  2. norosesnoskiesx's Avatar
    Big thanks to tdm for even building quattrimus. been using it from the beginning, hoping everything works out and can make an official release soon!
    tdm and Badboytoast like this.
    09-10-2012 08:00 AM
  3. cbucz24's Avatar
    Hey tdm, glad to see things still going well over here.
    Got a question for ya...I'm listing my ov on eBay an I've gotten 2 questions about getting the activation app back. Is there an apk somewhere I can flash?
    Or maybe push via adb?
    Sent from my PC36100 using Tapatalk 2
    09-12-2012 12:54 AM
  4. carloswii5's Avatar
    The bumblebee froyo from has activation in it
    09-12-2012 01:07 AM
  5. kcls's Avatar
    You must use a froyo ROM for activation. Any other Android ROM above android version 2.2 will not work. The activate APK will fail.
    Tapatalk from my Optimus V
    09-12-2012 05:53 AM
  6. cbucz24's Avatar
    Thanks, guys. I'll track one down then
    09-12-2012 06:03 AM
  7. thewraith420's Avatar
    Leslie made Rhode rom just for this purpose. Shouldn't be too hard to find :-)
    Tapatalk'n it from my VM670 running LS670ZVJ Baseband on Mandylion IHO ROM
    09-12-2012 06:39 AM
  8. brotherswing's Avatar
    http://www.vmroms.com/index.php?topic=177.0
    What would you do for a Klondike bar?
    strabo231 and flapjack.fiasco like this.
    09-12-2012 10:34 AM
  9. flapjack.fiasco's Avatar
    I don't need this at the moment, but I'm glad you posted it. I remember when she released it, but neglected to download it then. Something worth having on the sd-card, just in case.
    09-12-2012 03:28 PM
  10. brotherswing's Avatar
    I keep it around for that very reason!
    09-12-2012 03:51 PM
  11. Revenant Ghost's Avatar
    Hey brotherswing. Sorry I'm late to the party, but I only check here every once in a while. Hope you're enjoying the married life.
    brotherswing likes this.
    09-12-2012 05:19 PM
  12. chcub1's Avatar
    Well there goes one theory. This sounded a lot like the issues people were reporting on iho with zv9.
    Can you get a copy of /proc/last_kmsg?
    How do I get a copy of the /process/last_kmsg? I'm sorry I'm still new to this...
    09-12-2012 06:56 PM
  13. tdm's Avatar
    Use adb. Look it up on the forums, there is tons of info. Google too.
    The file is /proc/last_kmsg
    09-12-2012 08:21 PM
  14. thewraith420's Avatar
    Just wondering. I've went to the file with es file manager. Is there anything wrong with getting it this way?
    09-12-2012 08:57 PM
  15. tdm's Avatar
    Nope that should work also.
    thewraith420 likes this.
    09-12-2012 09:32 PM
  16. wb2alta's Avatar
    I can't seem to figure out how to enable a toggle for 3g data in the status bar. I'm using an LS670. I'm looking at the list of toggles available in the "enable toggles" menu and I don't see data anywhere. Is this not an option?
    09-12-2012 11:01 PM
  17. BuggerZ's Avatar
    Usually I just "cat /proc/last_kmsg" in a terminal emulator (or adb), but ya, file managers could work too.
    09-12-2012 11:28 PM
  18. tdm's Avatar
    Aokp does not have that option.
    09-12-2012 11:44 PM
  19. kenharkey7's Avatar
    Ok quick question. I know that using barnacle is a work around for wifi tether but anyone know a work around for usb tether that works on Linux?
    09-13-2012 12:44 AM
  20. clodfelterac's Avatar
    https://play.google.com/store/apps/d...FtLmV0cGMiXQ..
    kenharkey7 likes this.
    09-13-2012 12:50 AM
  21. BlairFam07's Avatar
    09-13-2012 08:44 AM
  22. chcub1's Avatar
    Uh adb I've tried to set it up but it never works, I found the file on es file manager. How do I get you a copy?
    09-13-2012 07:56 PM
  23. strabo231's Avatar
    If the only way you can get to it is es file explorer, just long press the file and it'll bring up a copy option, select that. Then go back to the main to the main root directory, select sd card, and then long press a blank spot on the screen to paste the file. Now it's on your sd card.
    09-13-2012 08:24 PM
  24. chcub1's Avatar
    After that, what do I do?
    09-13-2012 09:57 PM
  25. brotherswing's Avatar
    Upload it to pastebin
    09-14-2012 05:55 AM
