01-05-2016 04:35 PM
2,975 ... 100101102103104 ...
tools
  1. EpicSilver's Avatar
    how stable is this against bobz cm 9
    09-14-2012 04:59 PM
  2. inceyet's Avatar
    Hands down is my fav (aokp) I cant stay away from it to long its like crack just beware once you use it you'll be hooked. A very stable rom no rr @600/480 is fast and responsive :thumbup::thumbup:
    tdm and EpicSilver like this.
    09-14-2012 08:47 PM
  3. EpicSilver's Avatar
    Thanks for the info, I wanna use this as a replacement for stock but be able to access day to day things with as little bugs as possible
    09-15-2012 11:49 PM
  4. brotherswing's Avatar
    It's been my daily driver for a few months now....
    All I miss is Netflix.
    What would you do for a Klondike bar?
    sellers86 and EpicSilver like this.
    09-16-2012 05:05 PM
  5. chcub1's Avatar
    Posted it on paste bin, what's next?
    09-18-2012 09:32 PM
  6. flapjack.fiasco's Avatar
    Post a link to your pastebin dump here so tdm can see it.
    kenharkey7 likes this.
    09-18-2012 10:02 PM
  7. tdm's Avatar
    It looks like aokp has abandoned ics, I'm thinking the next builds might be jb.... Also thinking about giving gummy a spin.
    09-18-2012 10:45 PM
  8. kcls's Avatar
    Gummy?
    Tapatalk from my Optimus V
    09-18-2012 11:02 PM
  9. koeylondon's Avatar
    Looks like another group, like CM and AOKP. Probably a little smaller circle, but likely pretty mobile on development. I couldn't see their site (seems like it's down), but they've done a full build of their own. Good stuff.
    09-18-2012 11:15 PM
  10. sellers86's Avatar
    Tdm, gummy abandoned the whole project all together
    Also, can you gtalk me when you get a chance? I was contacted by ByteCode on XDA.
    09-18-2012 11:33 PM
  11. kenharkey7's Avatar
    Even if quattrimus ics ends here I think it's good enough for a daily driver for most people. It was a fantastic run, thank you tdm and I look forward to your upcoming projects
    09-18-2012 11:41 PM
  12. ZackVortex's Avatar
    Reminds me of last day of school XD the end of ics already.....
    Thought it would end until at least tethering was fix but great run...... thanks tdm for all your work
    Sent from my VM670 using Android Central Forums
    09-18-2012 11:59 PM
  13. tdm's Avatar
    Lol don't get all teary eyed, quattrimus is about Android 4, and jb is still 4. It is certainly going to take some work to get back to what we have with beta2, but we went through this before... Remember the 4.0.4 upgrade for alpha8? That sucked but it all worked out.
    09-19-2012 01:01 AM
  14. ganggreen30's Avatar
    Tdm I enjoyed this ROM thanks 4 all the work. I look forward to ur next work!
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    09-19-2012 01:11 AM
  15. purpulehaze's Avatar
    Very much looking forward to your next project then tdm in my opinion you are one of the best devs I have seen. It was this rom alone that has kept me on this phone and inspired me to learn how to use Linux for developing quattrimus is the best
    09-19-2012 01:25 AM
  16. pbailey212's Avatar
    Gummy is based off aosp, not cm9, so it might be a bit of a challenge. Gummy is a good alternative though
    sent from my Nokia 5110 using t9
    09-19-2012 01:28 AM
  17. androidalais's Avatar
    Hey guys, gotta question foe ya. I'm running this on my phone at 480/600 on conservative. And all of a sudden my phone starts rebooting. Its weird, it just started randomly. J had this problem with Godzilla to and figured out it was a bad flash. But that did it almost constantly. This one is about every 15 min. I don't think it could be a bad flash because I've been running it quite a while with no problems. Any ideas?
    Sent from my hot ice cream sandwich
    09-19-2012 05:34 AM
  18. flapjack.fiasco's Avatar
    Someone over on Bobz CM10 thread mentioned that when they changed the I/O scheduler from SIO to DEADLINE, it stopped their random reboots. I don't believe that there's a way to change the I/O scheduler from settings in CM9, it would have to be changed in the kernel from what I understand. Maybe something for tdm to take a look at though? Unless you want to try to build it yourself.
    strabo231 likes this.
    09-19-2012 08:43 AM
  19. clodfelterac's Avatar
    try setcpu or similar to adjust scheduler... i also saw that post, im going to try it later...
    flapjack.fiasco likes this.
    09-19-2012 01:09 PM
  20. flapjack.fiasco's Avatar
    I'm dying to try AOKP JB! Seriously cannot wait for it.
    09-19-2012 02:48 PM
  21. sellers86's Avatar
    That was my secret project. I got it built and booting, ril worked but systemui glitches and crashes rendered it useless. So I have another in mind
    Sent from my One V using Android Central Forums
    Ryuk6666 and inceyet like this.
    09-19-2012 08:06 PM
  22. Ryuk6666's Avatar
    Lol I knew it xD
    Sent from my Android Ice Cream Sandwich of an OV.
    sellers86 likes this.
    09-20-2012 12:17 AM
  23. TauSigmaNova's Avatar
    I came to Quattrimus at Alpha 7 when it got camera. Never looked back.
    Alpha 8 was wonky, but I stayed with Alpha 7 until Alpha 10 Pre 3 :P
    Good times.
    09-20-2012 06:33 AM
  24. jonny5449's Avatar
    I guess we won't see aosp
    Sent from my LG-LS670 using Tapatalk 2
    09-20-2012 07:02 AM
  25. ThatGuyLurkin's Avatar
    Hey Guys, check this out
    http://forum.xda-developers.com/show....php?t=1891711
    09-20-2012 07:17 AM
