01-05-2016 04:35 PM
2,975 ... 103104105106107 ...
tools
  1. flapjack.fiasco's Avatar
    I have a nine month old constantly engaged in random acts of cuteness, so a functional camera is a non negotiable for me. I haven't followed jb development on the OV but the last time I tried it the camera didn't work, and it ran crazy slow. :banghead:
    Thus he spake
    Camera works in the latest build, but the preview is distorted like some of the early ICS builds.
    09-25-2012 01:11 AM
  2. koeylondon's Avatar
    Definitely, the guy working on it was using a SGS II and all the files are Drawable-HDPI
    Neat thing from XDA front page- Easily Resize Images for APK Mods with Android Resizer Tool – xda-developers
    Basically a batch resizer designed to resize things for Android. Looks pretty good.
    09-26-2012 08:35 AM
  3. jonny5449's Avatar
    Neat thing from XDA front page- Easily Resize Images for APK Mods with Android Resizer Tool xda-developers
    Looks pretty cool so it can resize hdpi or xhdpi or ldpi to mdpi
    Sent from my LG-LS670 using Tapatalk 2
    09-26-2012 09:07 AM
  4. ThatGuyLurkin's Avatar
    Click it and find out.
    Encerspay45 likes this.
    09-26-2012 01:16 PM
  5. kcls's Avatar
    For people still wondering about the JB style status bar, someone over at that thread confirmed it working on MDPI. To get rid of the Status 0 errors when flashing, you had to replace the signatures in the flashable zip with ones from a flashable zip that is confirmed working with our phones. So, ones from quattrimus would work. Check out the thread and the latest couple posts for exact instructions. I've yet to try it, but I will this weekend.
    Tapatalk from my Optimus V
    09-26-2012 09:55 PM
  6. droiddekka's Avatar
    Observe and report please!
    09-26-2012 09:58 PM
  7. Badboytoast's Avatar
    Please report your finding!! iam really into that jb status bar!!
    09-27-2012 12:35 AM
  8. TauSigmaNova's Avatar
    Tried it-Installed fine;bootlooped on VanillaBean.
    Then again, it also bootlooped when I tried to replace the files in VanillaBean's SystemUI file also. Maybe I have to try with the stock 4.0 SysUI?
    09-27-2012 06:13 AM
  9. kcls's Avatar
    Possibly, I know it is meant for the system UI of the latest cm9 nigjtlies, since nothing is really being changed in cm9 anymore. If you've changed anything in VanillaBean, then it might boot loop. I'll be sure to backup my systemui first
    09-27-2012 06:28 AM
  10. TauSigmaNova's Avatar
    Yeah. After the bootloop I reflashed (dirty) VanillaBean and it worked fine.
    I don't know where to get the LATEST SysUI so for the next builld I pump out I'll try to use Quattrimus' SysUI!
    09-27-2012 06:38 AM
  11. hkazemi's Avatar
    I don't like that approach, I believe the vendor btld binary reads the bt, mac. I just haven't had time to look at it.
    Would implementing the workaround be possible, at least until the true fix is found? That workaround is better than (or at least no worse than) some of the other workarounds that are already documented for this ROM (mx player, barnacle, reinstall Voice Search, etc.)
    The non-unique bluetooth mac address issue has been the specific issue preventing some of us (including me) from loading this ROM onto our phones. Having multiple phones in the same family with the same BT mac address quickly becomes problematic when trying to pair multiple phones with the same car or computer.
    Here's the links again:
    http://forums.androidcentral.com/opt...221-print.html
    http://forums.androidcentral.com/opt...ml#post1959566
    Thanks!
    09-28-2012 01:24 AM
  12. hkazemi's Avatar
    a shout out to jb people LG optimus one has most features of aosp working jb!
    [ROM][JB][EXPERIMENTAL] AOSP (Android 4.1.1) - xda-developers
    Aosp jb now possible to port
    The known bugs list says "Wifi tethering (Fixed)". Maybe the tethering fix can be backported to Quattrimus ICS? Native tether (AP mode) is preferable to peer-to-peer mode.
    09-28-2012 01:43 AM
  13. flapjack.fiasco's Avatar
    Maybe, but it is AOSP...
    09-28-2012 09:12 AM
  14. cole2kb's Avatar
    I would <3 an AOSP build. I said the same thing about ICS though and ended up abandoning it for AOKP, which is probably what I'll do with Jellybean as well.
    09-28-2012 09:19 AM
  15. sinful.michael's Avatar
    Loved this rom but i noticed with this and all other ics roms i used the sms messaging hangs up and well it says sent my other phone won't get the message this happens as well the other way around the other phone will send the message but i won't get the message on this phone until hours later or never. Not sure why this is happening when i go back to a cm7 rom I have no issues? possibly my ov just hates ics that much
    09-29-2012 02:57 PM
  16. brotherswing's Avatar
    I've never had that issue, but then again, I always use Handcent or GoSMS.
    Thus he spake
    09-29-2012 02:59 PM
  17. kcls's Avatar
    I text tons every day and have never used anything other than the stock messaging app and have never had a single problem with it.
    09-29-2012 04:27 PM
  18. sinful.michael's Avatar
    do you think it might be a radio issue my baseband comes up as unknown?
    09-29-2012 04:55 PM
  19. sinful.michael's Avatar
    Well i went back to stock with the zv5 baseband,re rooted, and reinstalled aokp beta 2 will report back if this seems to help the issue at all....
    Update.... still same situation out of 20 recived texts i was only able to get 5 and out of 20 sent 7 went through full bars on 3g
    09-29-2012 06:29 PM
  20. kcls's Avatar
    I'm getting the insufficient space error again. I have an SD Partition. Settings is telling me I have 69MB free (No jokes :P) When I try to install or update apps that I know are less then that, it gives me an insufficient space error. I haven't actually been able to update google maps since they changed their icon. However, some apps will update. it's just a stubborn few that won't. It also happens with apps not in the play store, such as CM themes from XDA. I wiped cache and dalvik, no go. I have no 01mdalvik file in /system/etc/init.d, so I know that's not the problem. Anyone know a good solid fix?
    09-29-2012 08:01 PM
  21. tdm's Avatar
    The ics kernel just got a new boost. I was able to get a framebuffer console on my spectrum, which has a similar graphics system. If I can get that working on the ov, that would make kernel work sooooo much easier.
    09-29-2012 10:30 PM
  22. koeylondon's Avatar
    ...and in AROUND THE NET...
    AOKP JB Build 3 built for P500. Looks like it's portin' time:
    [UNOFFICIAL] [ROM] [BETA] [JB] Android Open Kang Project - LG-P500 - Build #3 (BETA1) - xda-developers
    09-30-2012 08:49 AM
  23. ThatGuyLurkin's Avatar
    Read the red text o_o
    I can attempt , But probably not post.
    09-30-2012 08:57 AM
  24. koeylondon's Avatar
    Oh, I read. Looking over the thread and bugs log, it looks like (if you're willing to do some legwork) most of the problems this rom is encountering have been solved elsewhere. I've started pulling it apart as an exercise in "how it's done," and if I'm reading things correctly, some of the fixes are basically drag and drop from other sources/builds. The big problem seems to be the Camera, which is non-functional here (which as I see elsewhere, is a common problem on the One line with JB). I wonder if BobZ has a source/app fix... (runs off to play).
    Badboytoast likes this.
    09-30-2012 09:56 AM
  25. droiddekka's Avatar
    I am in the exact same boat you are.
    09-30-2012 05:44 PM
