01-05-2016 04:35 PM
2,975 ... 104105106107108 ...
tools
  1. droiddekka's Avatar
    I'm getting the insufficient space error again. I have an SD Partition. Settings is telling me I have 69MB free (No jokes :P) When I try to install or update apps that I know are less then that, it gives me an insufficient space error. I haven't actually been able to update google maps since they changed their icon. However, some apps will update. it's just a stubborn few that won't. It also happens with apps not in the play store, such as CM themes from XDA. I wiped cache and dalvik, no go. I have no 01mdalvik file in /system/etc/init.d, so I know that's not the problem. Anyone know a good solid fix?
    I just cleared app data and cache from the manage apps screen...and am now updating left and right.
    09-30-2012 05:56 PM
  2. Deal Trees's Avatar
    This is a great ROM and I thank you very much for this.
    tdm and Badboytoast like this.
    09-30-2012 07:29 PM
  3. jonny5449's Avatar
    ...and in AROUND THE NET...
    AOKP JB Build 3 built for P500. Looks like it's portin' time:
    [UNOFFICIAL] [ROM] [BETA] [JB] Android Open Kang Project - LG-P500 - Build #3 (BETA1) - xda-developers
    Hope this does get ported aokp jb on nexus s is amazing.... *sigh* too bad optimus elite doesn't even have ice
    09-30-2012 09:44 PM
  4. kcls's Avatar
    Cleared cache+dalvik, market data+cache+uninstall updates, still no luck. I am able to install certain apps but not others. Gr.
    Tapatalk from my Optimus V
    09-30-2012 09:54 PM
  5. flapjack.fiasco's Avatar
    Are the apps that you're able to install smaller than the ones you can't install?
    09-30-2012 09:56 PM
  6. sellers86's Avatar
    ... it wont get ported, it should get built.. tdm plans on building it
    brotherswing likes this.
    09-30-2012 10:08 PM
  7. tdm's Avatar
    Yeah cm10 and aokp41 are in the works. I plan to get rid of that insufficient space error by using the sdext for more stuff.
    09-30-2012 10:52 PM
  8. tdm's Avatar
    Oh.. Anyone able to install bad piggies? I tried to side load it but the native libs didn't get installed.
    09-30-2012 10:57 PM
  9. YoshinJaa's Avatar
    Bad piggies?
    Sent from my Optimus V via Tapatalk
    09-30-2012 11:08 PM
  10. cole2kb's Avatar
    Doesn't even come up in Play for me. Try Amazon?
    09-30-2012 11:11 PM
  11. koeylondon's Avatar
    I know you've said this like, a dozen times now, but I am still freaking thrilled that this is happening. I'm totally just poking around in the AOSC and DxKitchen and you're building my dream OS from source. I don't think I've had this much fun learning something since culinary school and Lobster day.
    tdm likes this.
    09-30-2012 11:57 PM
  12. puffen619's Avatar
    Nope, shows in play store but says device isn't compatible
    10-01-2012 12:42 AM
  13. kcls's Avatar
    Heads up for anyone when cares: Nova Launcher Prime is only .25 in the Play store today. Make the phone feel 100x faster when using it with "Nova" transition speeds, and has JB style animations and features.
    10-01-2012 05:57 AM
  14. kcls's Avatar
    Some yes, some no. Lol, it is quite a weird problem. But TDM said above that stuff should be fixed in JB.
    10-01-2012 05:58 AM
  15. ThatGuyLurkin's Avatar
    Doesn't it end today?
    10-01-2012 06:26 AM
  16. velvetvetfog82's Avatar
    Search Bad piggies play store pn google. it will take you to the store and tell you it's not compatable with our phones
    10-01-2012 07:45 AM
  17. PMUSER's Avatar
    There is an armv6 compatible version floating around....
    I can't find a postable link but i Googled and found this:
    http://www.google.com/url?sa=t&rct=j...sN-jZXGFDMNUjQ
    velvetvetfog82 and tdm like this.
    10-01-2012 10:17 AM
  18. sellers86's Avatar
    Thanks for this. Bought it and it does run a lot faster
    Sent from my One V using Android Central Forums
    10-01-2012 02:27 PM
  19. TauSigmaNova's Avatar
    Apex ftw
    johnh02 and cole2kb like this.
    10-01-2012 05:16 PM
  20. jayleekay's Avatar
    I bought nova prime as well. Wish I had known there was a sale going on. Love .25 apps
    10-03-2012 06:41 AM
  21. monepone's Avatar
    What happened to the nightly builds? No changes since beta 2?
    10-05-2012 08:51 AM
  22. koeylondon's Avatar
    If you read back, you'll see that, since both CM and AOKP have abandoned ICS in favor of JB, and TDM has a great many projects on his plate, Quattrimus will be moving into a JB version very soon.
    According to the last update, we should see an "Alpha" version within the week. HOWEVER, TDM is also building a Marquee version of 4.0.4, as well as working on an ICS Kernel, so that's not a promise. However, he seemed pretty confident about it, so here's hoping.
    Badboytoast and johnh02 like this.
    10-05-2012 09:08 AM
  23. tdm's Avatar
    Yeah I've been working on the marquee and spectrum for the past couple Weeks. Made great progress so it won't be long now.
    10-05-2012 10:42 PM
  24. koeylondon's Avatar
    Yea, I was kinda poking around your source pages on github. As an aspiring dev, seeing that work in a relatively short period of time is inspiring. It's like when I was in bands and I got to sit in on some other acts recording. Like, "wow! look at that <curse> rip!" Not there yet, but I'm workin' on it... slowly.
    But we're off topic. By way of updates, should we expect a new thread I assume? I heard that CM might be opening up 4.0 to continuing nightlies again (might have been a rumor). Would we see maintenance of nightlies if that happened, or would should we expect that 4.0 is where it is?
    10-05-2012 10:55 PM
  25. tdm's Avatar
    I'll be moving to jb next, and resuming nightly builds there. Definitely a new thread.
    10-06-2012 12:38 AM
