01-05-2016 04:35 PM
2,975 ... 105106107108109 ...
tools
  1. purpulehaze's Avatar
    I'll be moving to jb next, and resuming nightly builds there. Definitely a new thread.
    Omg so excited
    10-07-2012 12:07 AM
  2. ThatGuyLurkin's Avatar
    Google's about to release 4.2. Their releasing so quickly!
    Anyone use Nova Launcher and get use Widgets in drawer?
    ilikechicken123 likes this.
    10-07-2012 10:45 AM
  3. ilikechicken123's Avatar
    I want me a slice of key lime pie!
    johnh02 likes this.
    10-07-2012 10:50 AM
  4. tdm's Avatar
    Link?
    topdawg661 and Encerspay45 like this.
    10-07-2012 11:13 AM
  5. A-android-B's Avatar
    Link?
    Or it never happened lol
    10-07-2012 12:02 PM
  6. topdawg661's Avatar
    Link?
    Here you fellers go
    http://androidandme.com/2012/10/news...ed-google-now/
    Sent from my MB886 using Tapatalk 2
    10-07-2012 12:04 PM
  7. cole2kb's Avatar
    Give it up for rumors and speculation. *clap clap clap*
    topdawg661, johnh02 and inceyet like this.
    10-07-2012 12:14 PM
  8. ilikechicken123's Avatar
    At this point no one is for sure. To be honest, I hope they don't release it too soon. We haven't even had time to perfect ICS. But the Optimus has gone so far..... :') it brings me so much joy.
    johnh02 likes this.
    10-07-2012 12:24 PM
  9. topdawg661's Avatar
    All three of my phones are running ics at the momment "ov bobz, one v cm9, and my atrix hd stock" i cant imagine another update so quick
    10-07-2012 12:53 PM
  10. sellers86's Avatar
    Just remember that a lot of rumors come true.. such as the ics to jb rumor, phones on vm rumors, etc. But they are still rumors, take them lightly that way you aren't disappointed
    Sent from my HTC One V using Android Central Forums
    johnh02 and topdawg661 like this.
    10-07-2012 01:22 PM
  11. brotherswing's Avatar
    I dunno, my OV runs like hot garbage on all the JB builds I've tested. I can't imagine that 4.2 would run any better....
    Thus he spake
    10-07-2012 02:10 PM
  12. sellers86's Avatar
    Thus he spake
    A lot of people think its better to have the newest stuff. I even run ICS most of the time on my one v, I like it better
    10-07-2012 10:39 PM
  13. androidalais's Avatar
    i found it and a few other decent games here (armv6)... thanks to AndroPalace and Manoj The Gamer... :-)
    http://www.andropalace.net/
    THE GAMING PLACE [GALAXY Y/DUOS Only] [UPDATE] - xda-developers
    Anybody looking for a v6 compatible templerun i have aan apk
    Sent from my Kindle Fire using Android Central Forums
    10-08-2012 05:26 AM
  14. kenharkey7's Avatar
    You can find them thru a simple Google search but it's really buggy. Every version I've tried lags really bad and glitches. It's a problem with the arm v6 build
    10-08-2012 05:30 AM
  15. Encerspay45's Avatar
    Is there a way I could get the fast charging mod onto Quattrimus like Cold as Ice?
    Cold as Ice was really buggy for me and now I want Quattrimus.
    But I also want fast charging.....
    10-08-2012 12:30 PM
  16. tdm's Avatar
    Can you find the commit in kravens github?
    10-08-2012 12:37 PM
  17. Encerspay45's Avatar
    I'm sorry, I'm a total noob, and have no idea what you're asking. O_O
    10-08-2012 12:44 PM
  18. koeylondon's Avatar
    Audio Routing Fix: https://github.com/thekraven/android...e9f36cad3b6fea
    Camera Fix added late last month: https://github.com/thekraven/android...f52cf774a6429d
    Unfortunately, I can't find the USB Fast Charge commit. I also couldn't find the Home Button to answer call commit. I will continue searching, though. The later is important to me, the former seems to be popular right now (I never use it, anyway).
    Encerspay45 and tdm like this.
    10-08-2012 01:36 PM
  19. Encerspay45's Avatar
    You're a huge help because charging takes forever on my phone.
    10-08-2012 01:41 PM
  20. ThatGuyLurkin's Avatar
    Flash TheKravens latest kernel. Then flash his patch.
    10-08-2012 02:28 PM
  21. koeylondon's Avatar
    I'm not 100%, but I think that patch is just to add the toggle to the interface. The fastcharge option is in the kernel, but you need a method to enable it in some interface. The Quatt AOKP builds already have the toggle present, so it's just a matter of including the code in the kernel to disable the ADB and enable fastcharge. I'm still trying to find that code.
    10-08-2012 03:24 PM
  22. Encerspay45's Avatar
    Okay, another issue. My sd-ext partition isn't being used or recognized, so I run out of space rather quickly...
    10-08-2012 04:20 PM
  23. brotherswing's Avatar
    What file system is it formatted to?
    Thus he spake
    10-08-2012 04:30 PM
  24. Encerspay45's Avatar
    Thus he spake
    FAT32...? I think
    10-08-2012 05:23 PM
  25. koeylondon's Avatar
    FAT32...? I think
    You need to have your SD card formatted in two partitions, one (the first) should be in fat32, the other should be in EXT format, either EXT2, 3, or 4. Myself, I would mount my phone by USB, then copy all the info off, then boot into recovery and use the recovery tools (in CWM or COT) to format your card correctly.
    10-08-2012 06:13 PM
