01-05-2016 04:35 PM
2,975 ... 106107108109110 ...
tools
  1. Encerspay45's Avatar
    You need to have your SD card formatted in two partitions, one (the first) should be in fat32, the other should be in EXT format, either EXT2, 3, or 4. Myself, I would mount my phone by USB, then copy all the info off, then boot into recovery and use the recovery tools (in CWM or COT) to format your card correctly.
    Could I run Link2SD in Quattrimus with a FAT32 partition?
    There shouldn't be any lost apps because there'd only be 1 a2sd service running.
    Right?
    10-08-2012 06:37 PM
  2. sellers86's Avatar
    @tdm, if you havent found it already, here is the fast charging commit
    https://bitbucket.org/thekraven/iscr...3c6b2c90f243a8
    brotherswing and tdm like this.
    10-08-2012 07:50 PM
  3. ThatGuyLurkin's Avatar
    I'm not 100%, but I think that patch is just to add the toggle to the interface. The fastcharge option is in the kernel, but you need a method to enable it in some interface. The Quatt AOKP builds already have the toggle present, so it's just a matter of including the code in the kernel to disable the ADB and enable fastcharge. I'm still trying to find that code.
    Yes... flash the kernel, then flash the patch.
    10-08-2012 08:12 PM
  4. brotherswing's Avatar
    Right?
    No. No. No.
    That will break things. Honestly, your best bet is to copy any data you want to save to a pc, then use your recovery to redo your partitions. There may be other ways to force it to work, but this way will give you the best possible performance.
    Thus he spake
    10-08-2012 08:15 PM
  5. Encerspay45's Avatar
    No. No. No.
    Thus he spake
    Okay, thanks everyone for saving a little noob from ultimate harm!
    10-08-2012 08:18 PM
  6. RT78's Avatar
    With >340 posts, I don't think you're considered a noob anymore. But I could be wrong...
    Encerspay45 likes this.
    10-09-2012 01:51 PM
  7. ThatGuyLurkin's Avatar
    Hey. You can have >10 post and still be a pro. People do it. :P
    10-09-2012 01:52 PM
  8. Encerspay45's Avatar
    Haha, >340 posts of stupid questions
    I'm still learning
    RT78 likes this.
    10-09-2012 04:19 PM
  9. TauSigmaNova's Avatar
    Lmfao, a noob is a noob, post count regardless :P
    Lol, I guess that makes me a noob , aww :P Lmfao, it's kay, I have my moments.
    johnh02 likes this.
    10-09-2012 05:16 PM
  10. brotherswing's Avatar
    I've been a guru to newb translator for many years now.
    Thus he spake
    10-09-2012 09:56 PM
  11. Encerspay45's Avatar
    Thus he spake
    Without your translation services I have no idea where this phone and I would be today!
    10-10-2012 09:13 AM
  12. brotherswing's Avatar
    Happy to be of help! Knowledge not shared is knowledge wasted.
    Thus he spake
    10-10-2012 12:05 PM
  13. Ditka2k7's Avatar
    I was recently running vanilla bean and it was burning through my battery but I didn't have the clock sync issue I had on quattrimus. Is there a fix forthe clock sync in this ROM? I really liked this while I was using it but the clock issue nagged at me.
    10-10-2012 06:30 PM
  14. TauSigmaNova's Avatar
    Don't kid yourself, my ROM probably had the same damn issue, you probably just never noticed.
    sellers86 and flapjack.fiasco like this.
    10-10-2012 09:12 PM
  15. brotherswing's Avatar
    I'm currently running this...
    http://forums.androidcentral.com/sho...d.php?t=212517
    It doesn't seem to have the clock sync issue (unless I just didn't notice) and it's battery life, for me anyway, is absolutely abysmal.
    Thus he spake
    Badboytoast likes this.
    10-10-2012 09:28 PM
  16. flapjack.fiasco's Avatar
    i havent noticed any time lapse with GS3ICS either... as far as battery drain, try charging to full and wiping battery stats... or charge to full and recalibrate... :-)
    Do any of the OS ICS ROMs lack the clock sync issue? I don't go over to their forums as often as I should.
    This space intentionally left blank.
    10-10-2012 10:29 PM
  17. terthii's Avatar
    Being that they're all based off Quattrimus, they all should have the clock sync issue.
    flapjack.fiasco likes this.
    10-10-2012 11:02 PM
  18. sellers86's Avatar
    Lol, they aren't all based on quattrimus. Cold as ice for example is its own cm9 rom
    Sent from my One V using Android Central Forums
    10-10-2012 11:45 PM
  19. koeylondon's Avatar
    This is true, there are a few CM9 roms that aren't built off Quatt. CAI also has/had this issue. I think it has to do with the kernel sleep, but I've been wrong before. I find that as long as my phone is set to update the time from Sprint, it doesn't lag for more than a few seconds.
    10-10-2012 11:59 PM
  20. brotherswing's Avatar
    Excellent point, and it's probably the only cm9 rom I haven't tried. I probably should. Right now I'm toying with bobz cm10. I think I've about found the limits of my trusty OV. Every JB build I've tried is lagtastic.
    Thus he spake
    10-11-2012 12:06 AM
  21. flapjack.fiasco's Avatar
    Wow, shows how often I read the OS forums. I had no idea they were all based on Quattrimus. For some reason, I thought Kraven built built his independently.
    10-11-2012 12:19 AM
  22. purpulehaze's Avatar
    Just checked out the sgs3 Rom. Its kinda cool, not tdm aokp kool but close. Haven't had the clock lad issue yet (though in waiting on it) overlooked the phone at
    48 something min 787 max performance gov and its running smooth. Keyboard is pudding me off lol. Its a nifty Rom not quatt but its a very good runner up
    10-11-2012 01:30 AM
  23. purpulehaze's Avatar
    Hey in wondering if anyone else has a similar issue I've been having with back up and restore on the cannibal recovery with quatt. Since I like trying new time all the time I always make android back ups. For some reason. The back up for quatt now gets stuck at the cyanogenmod for logo after I restore? I have had.no option but to completely wipe and reflash quatt every time, restore is what makes the phone get stuck. In using the sgs3 Rom now cuz I don't want to reflash and reinstall all my apps with th again. Any advice on the matter?
    10-11-2012 01:37 AM
  24. purpulehaze's Avatar
    I like trying new roms.... Sorry for the multi posts
    10-11-2012 01:39 AM
  25. brotherswing's Avatar
    Try thekraven's ls670 build of twrp. I just switched to it, and I really like it
    Thus he spake
    10-11-2012 08:23 AM
