I'm not too sure if this is a bug but....
When I touch my screen, my physical buttons light up (menu, home, etc). If I lift my finger off the screen, after a few seconds, they go off. This has always happened on every build of Quattrimus I've tried.
Try rebooting once, this happens to me on occasion and when I reboot -"android upgrades" giving me that app back.Every time I flash a nightly I lose an app or two. BeWeather Pro in particular disappears. When I try to restore it from TiBu, it tells me it will overwrite an existing app, and then fails to install it.
I use the Prep to Upgrade prior to flashing.
Any suggestions?
Thanks
As others have said, and what worked for me was to:
1) backup apps with titanium backup
2) backup the data from your sd card to your computer
4) repartition sd card in recovery (will erase all data on sd card, so make sure to back up)
5) move files back to sd card from computer
6) restore apps using titanium backup
It's a pain and a half, but this was the only method that was able to fix this issue reliably for me.
Taking a new approach to the kernel. I noticed the P700 uses the msm7x27 and comes with ICS, so I'm using that for a base to start with. Looks like much less work than my previous approach, but still not easy by any means.
I have been having that problem since cm9 pre beta 3 u r the only person I have seen post anything about the issue. I posted on the alpha thread and it went unanswered. I'm now taking screen shots of the log after the freeze and I believe it said error 624 but I'm not sure on the error number. Next time it happens take a screen shot and post it. Ima post the few screenshots I have after the next YouTube freeze
i tried to partition my sd card and its says i can only do it up 4gb and i have an 8 gb cardAs others have said, and what worked for me was to:
Is this for gingerkenel? and what changes would it have?
Hey tdm, did you ever get the chance to look at those graphics? Anything you would want me to change?
