01-05-2016 05:35 PM
2,975 ... 1314151617 ...
tools
  1. cole2kb's Avatar
    when will u have a different boot animation for AOKP ?
    Delete bootanimation.zip in your /system/media folder and replace it with this one. http://dl.dropbox.com/u/72059024/bootanimation.zip
    Badboytoast likes this.
    07-08-2012 04:21 PM
  2. tdm's Avatar
    I have just gotten my first insufficient storage space message. It started after I cleared my market data from my apps menu. I think, looking at data, this might be coincidental. What I'm wondering, is why are all apks stored in data/app as well as on the ext. I've attached a df and, you can see I've got plenty of space on sd-ext, but not so much on data. Any solutions other than removing apps? Can i kill the automagic link and use a 2sd script? Can i move installer cache to sd-ext or eliminate the apks from/data? Tdm, any solutions?
    Filesystem Size Used Free Blksize
    /dev 209M 48K 209M 4096
    /mnt/asec 209M 0K 209M 4096
    /mnt/obb 209M 0K 209M 4096
    /system 164M 146M 18M 4096
    /data 178M 123M 55M 4096
    /cache 110M 1M 108M 4096
    /sd-ext 915M 546M 368M 1024
    /data/dalvik-cache 915M 546M 368M 1024
    /data/app 915M 546M 368M 1024
    /mnt/sdcard 28G 22G 6G 16384
    /mnt/asec/no.urtegata.go_theme_clean_white-1 3M 1M 1M 4096
    /mnt/asec/com.fgol.grabatron1-1 35M 33M 1M 4096
    /mnt/asec/com.foobnix.pdf.reader-1 5M 3M 1M 4096
    /mnt/asec/es.paraisoft.android.aptoiderepos-1 2M 208K 1M 4096
    You need to clear out /data/app for sdext to be used. Boot into recovery and move all your apk files to /sd-ext/app to fix it.
    07-08-2012 04:37 PM
  3. magus7091's Avatar
    Wow, thanks for the quick reply, but how do I move those files from within recovery?
    07-08-2012 04:41 PM
  4. tdm's Avatar
    With adb. If you aren't comfortable with that, do a full backup and wipe and restore.
    07-08-2012 04:45 PM
  5. tdm's Avatar
    Actually you can do it from the main system...
    07-08-2012 05:04 PM
  6. magus7091's Avatar
    I tested this using an app i didn't much care about by copying (overwrite) to sd-ext, since the apk was in both locations, and the app no longer launches. In the process of creating a nandroid and then copying every apk from /data/app to /sd-ext/app. If it kills it, I'll let you know.
    07-08-2012 05:10 PM
  7. ScreamoPichu's Avatar
    Works near beautifully. Best ROM I've ever used on my LG Optimus V. The only thing I really want changed is the video playback, it's horrible on more than just YouTube. Nearly every video (That I've tried) runs horribly.
    07-08-2012 05:14 PM
  8. magus7091's Avatar
    OK, so here's the output from df in adb:
    Filesystem 1K-blocks Used Available Use% Mounted on
    tmpfs 217948 32 217916 0% /dev
    /dev/block/mtdblock1 112768 1312 111456 1% /cache
    /dev/block/mmcblk0p1 30152240 24137872 6014368 80% /sdcard
    /dev/block/mtdblock5 168448 149808 18640 89% /system
    /dev/block/mtdblock6 183168 125804 57364 69% /data
    /dev/block/mmcblk0p2 937202 556784 330419 63% /sd-ext
    But the odd thing is when I ls or view /data/app when the phone is in recovery nothing shows, all apks show as being only in sd-ext...
    07-08-2012 05:24 PM
  9. tdm's Avatar
    That is odd. It looks like neither app nor dalvik are being remounted. But clearly you have an sdext partition that is being used.
    07-08-2012 05:34 PM
  10. magus7091's Avatar
    Sitting in recovery with not much else to do, anything I can try to do to fix it or diagnose it? I'll be a guinea pig for a while if it'll help me or anyone else...
    07-08-2012 05:41 PM
  11. tcrider84's Avatar
    im wondering if maybe rmnet0 drivers in the kernel need updating? here's logcat from what happens during wifi hotspot tethering:
    Code:
    D/DHCP    ( 1800): configuring rmnet0
    D/ConnectivityService( 1910): ConnectivityChange for mobile: CONNECTED/CONNECTED
    D/ConnectivityService( 1910): ConnectivityChange for mobile_hipri: CONNECTED/CONNECTED
    W/NetworkStats( 1910): dropping UID delta from unknown iface: iface=wl0.1 uid=0 set=DEFAULT tag=0x0 rxBytes=0 rxPackets=0 txBytes=56 txPackets=1 operations=0
    W/NetworkStats( 1910): dropping UID delta from unknown iface: iface=rmnet0 uid=0 set=DEFAULT tag=0x0 rxBytes=612 rxPackets=2 txBytes=76 txPackets=1 operations=0
    E/SecondaryTablController( 1798): ip route add failed: /system/bin/ip route add 28.194.86.161/32 via 0.0.0.0 dev rmnet0 table 60
    W/FrameworkListener( 1798): Handler 'interface' error (No such device)
    E/ConnectivityService( 1910): Exception trying to add a route: java.lang.IllegalStateException: Unable to communicate with native daemon to add routes - com.android.server.NativeDaemonConnectorException: Cmd {interface route add rmnet0 secondary 28.194.86.161 32 0.0.0.0} failed with code 400 : {ip route modification failed (No such device)}
    E/SecondaryTablController( 1798): ip route add failed: /system/bin/ip route add 0.0.0.0/0 via 28.194.86.161 dev rmnet0 table 60
    E/ConnectivityService( 1910): Exception trying to add a route: java.lang.IllegalStateException: Unable to communicate with native daemon to add routes - com.android.server.NativeDaemonConnectorException: Cmd {interface route add rmnet0 secondary 0.0.0.0 0 28.194.86.161} failed with code 400 : {ip route modification failed (No such device)}
    D/NetworkPolicy( 1910): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=19, warningBytes=2147483648, limitBytes=-1, lastSnooze=-1 to ifaces [rmnet0, rmnet0]
    D/ConnectivityService( 1910): NetTransition Wakelock for WifiStateMachine released by timeout
    I/GTalkService/c( 2063): [AndroidEndpoint@1092301488] connect: acct=1000000, state=CONNECTING
    D/Tethering( 1910): TetherModeAliveState.processMessage what=3
    D/Tethering( 1910): chooseUpstreamType(true), preferredApn =5, got type=0
    D/TetherController( 1798): setDnsForwarders(0 = '68.28.230.132')
    D/TetherController( 1798): setDnsForwarders(1 = '68.28.231.132')
    D/TetherController( 1798): Sending update msg to dnsmasq [update_dns:68.28.230.132:68.28.231.132]
    I/dnsmasq ( 3284): using nameserver 68.28.231.132#53
    I/dnsmasq ( 3284): using nameserver 68.28.230.132#53
    D/Tethering( 1910): notifying tethered with iface =rmnet0
    D/Tethering( 1910): TetheredState.processMessage what=12
    E/NatController( 1798): IP rule -6 rule add from fe80::/64 table 60 got 65024
    D/PicasaSyncManager( 2817): active network: NetworkInfo: type: mobile[CDMA - EvDo rev. A], state: CONNECTED/CONNECTED, reason: (unspecified), extra: , roaming: false, failover: true, isAvailable: true
    D/PicasaSyncManager( 2817): background data: true
    E/NatController( 1798): IP route route add fe80::/64 dev wlan0 table 60 got 65024
    I/MediaUploader( 2844): No need to wake up
    E/NatController( 1798): Error setting forward rules
    E/NetworkManagementService( 1910): enableNat got Exception com.android.server.NativeDaemonConnectorException: Cmd {nat enable wlan0 rmnet0 2 fe80::/64 192.168.43.0/24} failed with code 400 : {Nat operation failed (No such device)}
    E/Tethering( 1910): Exception enabling Nat: java.lang.IllegalStateException: Unable to communicate to native daemon for enabling NAT interface
    E/WifiStateMachine( 1910): Tethering reports wifi as untethered!, shut down soft Ap
    full logcat:
    http://pastebin.com/Ba35gWRv
    07-08-2012 05:53 PM
  12. tdm's Avatar
    Check that /data/app exists and is a normal directory and is empty. Then reboot and capture a log with logcat -d and post it in an attachment.
    magus7091 likes this.
    07-08-2012 05:59 PM
  13. tdm's Avatar
    @tcrider84 does rmnet0 exist? What does the shell say when you run these commands?
    07-08-2012 06:01 PM
  14. magus7091's Avatar
    Sorry, kinda nub-ish with adb, but would this just be booting from recovery and then dumping the logcat to a file?
    07-08-2012 06:05 PM
  15. tcrider84's Avatar
    LOL i just checked build.prop:
    #mobiledata.interfaces=rmnet0,rmnet1,rmnet2
    it's commented out. maybe we need to allow it and change it to whatever our 3g's interface is? that doesnt make sense though because later down under the #BT section it has #mobiledata.interfaces=wlan0,ppp0
    07-08-2012 06:12 PM
  16. tdm's Avatar
    No you capture logcat from the running system. On your pc run "adb logcat -d > logcat.txt"
    07-08-2012 06:20 PM
  17. tdm's Avatar
    Paste contents of /proc/net/dev.
    07-08-2012 06:20 PM
  18. tcrider84's Avatar
    Code:
    Inter-|   Receive                                                |  Transmit
     face |bytes    packets errs drop fifo frame compressed multicast|bytes    packets errs drop fifo colls carrier compressed
        lo:    1440      20    0    0    0     0          0         0     1440      20    0    0    0     0       0          0
    dummy0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet0:     612       2    0    0    0     0          0         0      764       4    0    0    0     0       0          0
    rmnet1:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet2:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet3:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet4:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet5:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet6:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    rmnet7:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
      usb0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
      sit0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
    ip6tnl0:       0       0    0    0    0     0          0         0        0       0    0    0    0     0       0          0
     wlan0:  405658     596    0    0    0     0          0         0    75066     612    0    0    0     0       0          0
    I wonder if this commit might have anything to do with it(reguarding channel names):
    https://github.com/marc1706/desire_k...bcad7f9d684428
    nope. not a channel issue.
    07-08-2012 06:26 PM
  19. magus7091's Avatar
    Wouldn't let me upload to the forum, but here's on my dropbox..
    logcat
    07-08-2012 06:31 PM
  20. tcrider84's Avatar
    logcat
    use pastebin.com next time, we can view it without downloading it ^.^
    magus7091 and tdm like this.
    07-08-2012 06:35 PM
  21. magus7091's Avatar
    07-08-2012 06:41 PM
  22. tdm's Avatar
    Didn't catch it early enough. I need the first couple of pages of output.
    07-08-2012 06:49 PM
  23. magus7091's Avatar
    Okay, I waited until all the boot stuff was done, should I grab it as soon as I have a desktop, immediately after "upgrading applications" disappears? That does appear every boot, I don't know if it's everyone or just me FWIW.
    07-08-2012 06:56 PM
  24. cbucz24's Avatar
    what are you looking for?? Isnt the unicorn their trademark? Would you prefer farting unicorns??
    07-08-2012 07:08 PM
  25. gliuzzi's Avatar
    I'm having trouble updating. Can someone please explain the process/ what apps to use.
    07-08-2012 07:13 PM
