01-05-2016 04:35 PM
2,975 ... 1516171819 ...
tools
  1. jayleekay's Avatar
    I just used tibu to uninstall the v search an installed the one from play. Is that the gingerbread one? It seems to work pretty good regardless.
    Sent from my LG-VM670
    07-08-2012 10:31 PM
  2. tdm's Avatar
    well another option would be to check the differences between ics and gingerbread's iptables to see what went wrong, at the moment its just a temp solution
    Feel free to investigate but I'm not going to spend time on it when a real ics kernel is so close.
    iptables is very interdependent with the kernel, as the user space tool and libs are just thin wrappers to push parameters to the kernel modules.
    tcrider84 and kenharkey7 like this.
    07-08-2012 10:36 PM
  3. HurrrDurrrDURP's Avatar
    How close tdm?!?!?!
    07-08-2012 10:45 PM
  4. tdm's Avatar
    How close tdm?!?!?!
    Soon as either Drew and I can get it to boot. Maybe tomorrow, maybe next week. Probably not longer than that.
    tlrsax54, cmerlyn, inceyet and 7 others like this.
    07-08-2012 10:49 PM
  5. inceyet's Avatar
    07-08-2012 10:51 PM
  6. HurrrDurrrDURP's Avatar
    Do you mind if I inquire why it doesn't want to boot?
    07-08-2012 10:57 PM
  7. sellers86's Avatar
    I gotta say, you guys are geniouses. I tried for a couple of hours last night, and it didn't even compile. Multiple tries and I got nothing. I was hoping I could help, but I guess not. Thanks for all of your hard work guys. You deserve more than virtual thanks for what you do.
    tdm likes this.
    07-08-2012 11:03 PM
  8. tdm's Avatar
    If I knew that, I'd have it fixed in no time. Not having a serial console is a huge challenge for this.
    07-08-2012 11:41 PM
  9. sellers86's Avatar
    Serial console? Does that mean no dmesg? That is the kernel report right haha?
    07-08-2012 11:44 PM
  10. tdm's Avatar
    Yeah. If the kernel doesn't boot all the way, there is no console messages to say what happened. Just a boot loop. Fun, huh?
    sellers86 likes this.
    07-08-2012 11:49 PM
  11. HurrrDurrrDURP's Avatar
    Does it at least start to read the RAMDisk?
    07-08-2012 11:54 PM
  12. sellers86's Avatar
    Oh yeah haha. So right now your kind of just stumbling in the dark I take it. Its like the start of ics all over again . Just curious, when the kernel gets built, how big is it?
    07-08-2012 11:55 PM
  13. clodfelterac's Avatar
    @tdm--- updater script/binary mabey?... or is that irrelevant to the issue?...
    07-09-2012 12:20 AM
  14. sellers86's Avatar
    If your talking about the kernel I doubt its the updater script because it is set to extract the boot.img and it does. If it was the updater script, it would boot right into fastboot. This was my experience with cna, so take it lightly
    clodfelterac likes this.
    07-09-2012 12:29 AM
  15. tdm's Avatar
    I'm not at a computer but its too early tip have a meaningful comparison.
    07-09-2012 12:36 AM
  16. tdm's Avatar
    How would I tell without a console...?
    flapjack.fiasco likes this.
    07-09-2012 12:52 AM
  17. sellers86's Avatar
    Well thanks for the updates. Ill follow closely, and possibly even try again sometime.
    07-09-2012 12:56 AM
  18. HurrrDurrrDURP's Avatar
    How are you testing the kernel? Are you using the device or an ARM emulator?
    Because if you are using an ARM emulator, can't you just use a Register analyzer and see what calls the system is making? And get some type of clue whats going on in the kernel?
    07-09-2012 01:03 AM
  19. A.I.'s Avatar
    @TDM: Apparently these guys got OpenMax incl. Youtube HQ working for the GSM version of the phones. Thread is here and linked-from post is here.
    In case you didn't know.
    tdm likes this.
    07-09-2012 07:59 AM
  20. tdm's Avatar
    No they don't have omx working.
    07-09-2012 08:02 AM
  21. sammyz's Avatar
    Difference between current kernel and ICS kernel would be what exactly??? Yea noobish question coming from me...
    topdawg661 likes this.
    07-09-2012 08:14 AM
  22. thekraven's Avatar
    That omx attempt didn't work. http://forum.xda-developers.com/show...postcount=1612
    The galaxy ace supposedly got YouTube hq working with kernel memory tweaks. But they have the msm7x27 turbo chipset.
    Badboytoast likes this.
    07-09-2012 08:55 AM
  23. A.I.'s Avatar
    Hmm ok then I guess. Youtube HQ is my only gripe with deep sleep so I'm on the prowl for anything that would help.
    07-09-2012 09:42 AM
  24. TauSigmaNova's Avatar
    Hey TDM, as much as I have NO developing experience at all, I saw Gannon's Porting tutorial and feel up to the challenge to port a ROM to the Optimus V, preferably ICS based. Though I know a GB ROM would be /way/ easier to port, after having ICS, I just can not force myself back to 2.3 at all. Could I use Beta 1 of Quattrimus as a base (with all credit to you for the base, if i succeed?) for my port attempt?
    07-09-2012 09:51 AM
  25. cbucz24's Avatar
    Lmao, I was just reading that myself.
    I'm sure you read all the warnings about arm6 and arm7 how they don't play nice with each other too.
    07-09-2012 10:32 AM
