01-05-2016 04:35 PM
2,975 ... 2324252627 ...
tools
  1. dingermtb's Avatar
    Can someone tell me how I can lower my overclock setting before my phone reboots. I accidentally hit 806 when I was scrolling and my phone has been stuck rebooting. There is about 15 seconds before it reboots again, I've tried to get to settings but I can't in that time. I tried to flash AOKP(was on CM9) and went back but the setting was saved for CM9. I know I could just wipe and flash again but I'd lose settings and stuff. Could I flash data from a backup of this without bringing that overclock with it?
    I know most of these questions are kind of stupid and I'll just end up doing something before I get a reply, but for future reference I'd be curious to know if I could.
    This time, you may have to reflash. For future reference try some of the different overclock apps on the market. Find one that opens quickly, like SetCPU. Keep it in your internal memory, so it's available instantly. I use CPU Master, but it sometimes takes awhile to open, but it has an option for safe mode, where you can boot to your stock settings or boot right into your overclock settings.
    Sent from my FusedEvil-VM670 using Xparent Red Tapatalk 2
    07-12-2012 08:12 PM
  2. inceyet's Avatar
    Lol I did a stupid mistake accidentally deleted Google Search. Can I just download the beta1 ZIP again, wipe catch and dalvik cache and flash?
    I think all you would need to do is reflash gapps
    GTR, AOKP, MiRaGe, CM9, BOBZ ICS, GODZILLA, Harmonia 2.08 killing the game!!!!!!!
    topdawg661 likes this.
    07-12-2012 08:27 PM
  3. thewraith420's Avatar
    That.... or pull the app from the zip and use a root file manager to put it in your /system/app folder
    Sent from my VM670 using Tapatalk 2
    07-12-2012 08:32 PM
  4. bennettg's Avatar
    is there anything we can do to assist tdm with making his kernel? are kernels from other phones or tablets helpful?
    07-12-2012 08:34 PM
  5. JadenBrown30's Avatar
    Thanks guys, I just decided to reflash just the ROM, worked lol I was trying to put Google Now on it, needless to say...it didn't work
    07-12-2012 08:35 PM
  6. grosskum's Avatar
    Thanks, I did just end up reflashing. I tried wiping just certain things but it didn't work. I had a recovery of all my stufff but I formatted my SD because I had so many apps from different roms that it took up 14GB of 16. Never thought about a different overclocking app. I stopped using them once I figured out I could do it in settings.
    07-12-2012 08:53 PM
  7. kjmott's Avatar
    Has anyone figured out a solution to or why some phones can't charge on this rom.
    I got the rom working but my phone will not charge. Any ideas?
    07-12-2012 09:45 PM
  8. Nate456's Avatar
    Which rom? AOKP or CM9
    Sent from my shole using Tapatalk 2
    07-12-2012 09:49 PM
  9. cbucz24's Avatar
    No, kernels can't just interchange. All the drivers are individual to each device. There are similarities, and close matches sometimes works. But usually not.
    07-12-2012 10:07 PM
  10. kjmott's Avatar
    I had the problem with both aokp and cm9. I flashed the beta's and then I did the nightlies. I upgraded my recovery and tried again. I have tried so many things.
    07-12-2012 10:16 PM
  11. tdm's Avatar
    Not really. Adding more devs doesn't generally make a project go faster any more than adding women makes a baby come out faster.
    07-12-2012 11:12 PM
  12. sammyz's Avatar
    Still, two heads are better than one
    07-12-2012 11:14 PM
  13. dzdzjb's Avatar
    But if you want to play with the kernels, the git repositories may be available to allow you to download what you need; if you have concrete suggestions or come up with changes that work, you might be able to offer them to willing ears. Eyes. Minds. Something.
    That said, it seems to me the devs are pretty busy, so I doubt you'll get much advice or hand-holding from them directly.
    07-12-2012 11:49 PM
  14. mjvelasco's Avatar
    The Clock Drags To Change Is There A Patch To Fix This? Lg Optimus V
    07-12-2012 11:51 PM
  15. Nate456's Avatar
    There is no fix for this. It is a known bug in the roms.
    07-12-2012 11:56 PM
  16. sinful.michael's Avatar
    Great job i love it so far the only problems i encountered are facebook white screen and yahoo messenger can't send sms to the phone i get sms from everything else just not the yahoo numbers CM9 And AOPK.
    tdm likes this.
    07-12-2012 11:58 PM
  17. tdm's Avatar
    Yeah. If there are any devs lurking that want to play along at home, I'll be using github.com/tdm/codeaurora_kernel_msm for the merges. My gingerkernel repo is going to go away, it was a temporary solution that was only meant to exist until the ics kernel was done.
    07-13-2012 12:32 AM
  18. clodfelterac's Avatar
    @tdm--- aokp0712:
    -power menu still opens twice, back closes both...
    -still had intermittent rr's (the usual InteractiveX/480/600) while adjusting settings and browsing so i started looking through the build.prop and made a few adjustments...
    adjusted-
    windowsmgr.max_events_per_sec=500
    dalvik.vm.heapgrowthlimit=32m
    dalvik.vm.heapsize=32m
    ro.max.fling_velocity=8000
    removed-
    ro.HOME_APP_ADJ=1
    -ive been trying for 3hrs to get this thing to rr but no dice... :-)
    -youtube still a bit off- (i think heaven lost an angel!)
    but some vids do play decent (on hq)-
    -bootanimation is perfect... glad you implemented the ics blue into it...
    tdm likes this.
    07-13-2012 01:52 AM
  19. arizaga55's Avatar
    Does anyone else have problems with the stability? My phone is constantly rebooting while using this rom.
    Any advice?
    07-13-2012 02:03 AM
  20. sellers86's Avatar
    I will attempt kernels once again
    07-13-2012 02:14 AM
  21. braxton355's Avatar
    Any advice?
    Underclock 480-320, I can almost guarantee that'll fix your problem.
    07-13-2012 02:14 AM
  22. braxton355's Avatar
    Haha tdm I'm diggin the simple OP, very nice (; for a guy like me (who doesn't like reading books on the forum), that's great.
    07-13-2012 02:18 AM
  23. clodfelterac's Avatar
    Does anyone else have problems with the stability? My phone is constantly rebooting while using this rom. Any advice?
    read post #618... this worked for me... still no rr's :-)
    07-13-2012 02:22 AM
  24. cammykool's Avatar
    happy to say google now is working on CM9
    xda-developers - View Single Post - The Google Now for ICS Project. [UPDATE 7/6][NO VOICE][APK AND ZIP]
    download in that post
    instructions:
    1.) Rename GoogleQuickSearchBox.apk in system/app to GoogleQuickSearchBox.bak
    2.) Rename the "Velvet-theos0o-5.apk" that you downloaded (link below) to: "GoogleQuickSearchBox.apk"
    3.) Place the renamed .apk in the system/app folder and set the permissions to rw-r-r
    4.) Reboot and enjoy!
    __________________
    Working:
    -It boots!
    -searching through the text-box works
    -location services work
    -info cards work
    -notifications work
    Not working:
    -Can't exit the app using the back button on the Google Now 'Cards' screen
    -Sometimes cannot submit a typed search-query
    -Voice search (Jelly Bean kernel-specific, we probably won't be able to fix )
    (copied from the OP of the thread)
    (editing phone search options seems to cause reboot on quattrfimus)
    I changed the sdk version from 15 to 16 in the build.prop but then G+ would force close randomly (but i didnt use it alot to begin with so i uninstalled it)
    complete credit goes to:SilentStormer on XDA
    07-13-2012 02:27 AM
  25. ctalkington's Avatar
    just finished putting together a new site for the project and donated a domain while I was at it. existing pages on simplydev should start redirecting soon.
    http://getquattrimus.com/
    07-13-2012 04:23 AM
