01-05-2016 05:35 PM
2,975 ... 2829303132 ...
tools
  1. nitestalkr's Avatar
    I got 1900, 2320, and 1893 on Antutu Benchmark test. I'm at the number 1 spot in the Optimus V rankings.
    Aww yeah.
    Thanks for all the hard work tdm! Awesome Rom.
    btw, what governor do you guys recommend?
    I personally recommend the SavegedZen governor. I run 844max 480min on it.
    My phone usually lasts 23 hours, and no rr's.
    sent from my un-dead sammich
    07-15-2012 05:46 PM
  2. andrewnelson23's Avatar
    I wish I knew anything about developing and such! hahah all I see when tdm says all that is asdklfjadslfkj16389823983:2938y4r.lakd;fl193938.92374.9.-.adf.
    hahah I just look for 'new build!' haha Thanks so much for what you do tdm, wish I could help.
    07-15-2012 05:58 PM
  3. kjmott's Avatar
    The folks with the charging issue need to get together and figure out what they have in common... different recovery? Unusual/off-brand SD cards? Aftermarket AC charger? Something about their wipe/flashing ... There must be *something* different because most of us aren't having any problems and the hardware itself only comes in 2 versions.
    Sent from my NookColor using Tapatalk 2
    I would love to find a solution to this.
    I haven't given up but I think I am at the end of my ropes. This weekend I have flashed and reflashed. I ran mirages 7.2 for a day and half and then tried this afternoon to flash cm9 this afternoon and once again I have no battery charge.
    I use my charger that came with my phone, I tried my wives charger, I tried my car charger. No of them work with cm9.
    I guess I'm stuck with cm 7.2 until someone awesome figures out this problem. I'm not sure what else to check..
    When you all flash using cannibal 1.2 touch recovery what process do you use? That may help me because maybe I am doing something wrong. Thanks guys.
    Kyle
    07-15-2012 06:00 PM
  4. clodfelterac's Avatar
    use the flashimagegui.apk from the play store... rename the recovery to cannibalrecovery.img (or whatever, just make sure recovery is at the end)... start the application, select recovery option, choose the renamed recovery, checkmark wipe cache and wipe dalvik, select flash image, and follow the on screen prompt when its been completed to reboot normal..
    *note- i know for a fact that aokp charges if youd like to give it a go... :-)
    07-15-2012 06:28 PM
  5. thewraith420's Avatar
    The part of the whole ics doesn't charge bug that really boggles my mind is that it won't charge in recovery either.... Recovery and rom are completely separate AFAIK.
    Sent from my VM670 using Tapatalk 2
    07-15-2012 07:38 PM
  6. tdm's Avatar
    I believe drews cot uses a very similar kernel as ics.
    07-15-2012 07:45 PM
  7. clodfelterac's Avatar
    im waiting till later this evening before i dl aokp0715 and test... today is my daughters 15th birthday and weve been texting alot... have you merged the kernel changes so far in this build?...
    07-15-2012 07:53 PM
  8. tdm's Avatar
    nope.
    clodfelterac likes this.
    07-15-2012 08:06 PM
  9. hiya6972's Avatar
    you can try this one if youd like... seems ok but ive still noticed a visual artifact here and there... im gonna dl the latest nightly in a bit and ill keep messing with the prop... but theres only so much that it can do... let me know what you find... ;-)
    I tested your build.prop and my phone wouldn't boot. The previous one worked well.
    Currently on nightly 7/15 aokp
    07-15-2012 08:48 PM
  10. Badboytoast's Avatar
    Did you put the build.prop or the folder build prop??
    07-15-2012 09:14 PM
  11. Shryvone12's Avatar
    Ha i deleted my build.prop and replaced it with the custom build.prop and it did the same also! Wouldn't boot!
    07-15-2012 09:43 PM
  12. drm1992's Avatar
    Wats the latest build?
    07-15-2012 09:45 PM
  13. clodfelterac's Avatar
    I tested your build.prop and my phone wouldn't boot. The previous one worked well. Currently on nightly 7/15 aokp
    it works... i ran it most of last night and half of today... its not a flashable zip... i shouldve put up a notice... post has been edited... make a nandroid if you dont already have one... extract the file and place it in /system after you rename/whatever the original... boot to recovery>wipe cache/dalvik>reboot
    -and flash the attachment mabey?...
    07-15-2012 09:48 PM
  14. andrewnelson23's Avatar
    What is this?
    07-15-2012 10:00 PM
  15. clodfelterac's Avatar
    i just dl'd it and checked it again... the only thing i had changed from the one on mine was the heapgrowthlimit... i increased it to 128m... i have edited the attachment... the value is now set to 48m...
    07-15-2012 10:02 PM
  16. clodfelterac's Avatar
    What is this?
    its mrg666's flashable egl.zip... it removes the cpu rendering pathway from the system leaving gpu to render (increases performance somewhat)... (it is also enabled in the build.prop)
    http://forums.androidcentral.com/opt...rendering.html
    post #20
    07-15-2012 10:06 PM
  17. tdm's Avatar
    Builds are nightly. Always less than 24 hours out of the oven.
    clodfelterac and joerivera17 like this.
    07-15-2012 10:07 PM
  18. clodfelterac's Avatar
    mmmmm... still warm... with a little butter...
    inceyet likes this.
    07-15-2012 10:19 PM
  19. jayleekay's Avatar
    It was hard for me to part with my cm9 betapre3 but I finally made the plunge to nightly.
    andrewnelson23 likes this.
    07-15-2012 10:21 PM
  20. TGBlade's Avatar
    Going to give this setting a try. Been using smartassV2 at 748max, 480min.
    I really should test how high I can overclock....
    07-15-2012 11:22 PM
  21. andrewnelson23's Avatar
    So...Sorry to beat the dead horse with a stick, but is there any specific reason why Netflix video won't work on Quattrimus?
    I know it's only supposed to work on Froyo roms, and it does(I've watched movies on Harmonia), but would it be possible to get the video to work on Quattrimus?
    I much prefer to only run Ubuntu on my computer, and Netflix is incompatible with Ubuntu. I don't really like switching back to windows just to watch netflix, and on my phone, I like Quattrimus way more than any other roms.
    07-15-2012 11:28 PM
  22. drm1992's Avatar
    Dam. Haha if u don't mind me asking. How is that possible? Only 24 hours old? Gets updated on a daily bases?
    07-15-2012 11:31 PM
  23. sellers86's Avatar
    He wrote scripts to sync and build every night.
    07-15-2012 11:40 PM
  24. drm1992's Avatar
    And every night the build gets uploaded?
    07-15-2012 11:48 PM
  25. kcls's Avatar
    Yup. That's what nightlies are.
    Sent from my Optimus V using Tapatalk
    07-15-2012 11:53 PM
