01-05-2016 04:35 PM
2,975 ... 3132333435 ...
tools
  1. henrikb's Avatar
    The battery level doesnt update on recoveries, so that makes no difference. Mine never charged from a touch recovery, only xionia. But I have no problems charging on an ics rom
    When you say "battery level doesnt update", do you mean "it does not charge" or "the level reported does not update"? My question is whether I could let it sit on recovery (you suggest Xionia but not Touch) and actually charge, and then I can check the battery level by booting up into a ROM?
    I'm trying to narrow where things go wrong and if I can also get it to charge in a recovery where you can charge it, I know at least something that works as expected on our phone (just as we know it charges on other ROMs).
    07-17-2012 02:50 AM
  2. sellers86's Avatar
    The level doesn't update. And for me, charging never worked in a touch recovery. Only xionia and cwm regular. But yes, in theory you should be able to let it sit charging in recovery then boot into a charged rom. I've done it before.
    henrikb likes this.
    07-17-2012 03:22 AM
  3. ThatGuyLurkin's Avatar
    Yeah. For me, charging in recovery is faster. But with no charger, battery dies in about2 hours while in recovery. o-o
    Sent from my Motorola Triumph using Tapatalk 2
    henrikb likes this.
    07-17-2012 03:34 AM
  4. Ryuk6666's Avatar
    I was thinking about that. Haha. My theories are that it's screen brightness is all the way up and maybe the cpu is on 600 the entire time? Unless recovery is able to control it? I would think that it does. XD Idk much about recoveries, so correct me if I'm wrong
    Sent from my A.C.R. Zombified Quattrimized AOKP OV.
    07-17-2012 05:28 AM
  5. nitestalkr's Avatar
    @tdm
    Is AOKP not compiling correctly? Last nightly was 7/15 on all mirrors.
    sent from my un-dead sammich in my hospital bed
    lerxst_x likes this.
    07-17-2012 05:36 AM
  6. tdm's Avatar
    @tdm
    Yeah, I found the issue. AOKP is using the CM9 version of bootable/recovery, which recently changed to require an update to openssl. But AOKP is using their own fork of external/openssl and apparently hasn't pulled in that change.
    I'm changing my build to use CM9 external/openssl.
    Don't know why AOKP hasn't fixed it yet, unless they are ignoring ICS and focusing on JB.
    07-17-2012 08:24 AM
  7. tdm's Avatar
    ro.product.model=LG-VM670
    That is the value already...
    Code:
    $ unzip ../quattrimus-VM670-cm9-nightly-20120716.zip system/build.prop; grep model system/build.prop
    Archive:  ../quattrimus-VM670-cm9-nightly-20120716.zip
    signed by SignApk
      inflating: system/build.prop
    07-17-2012 09:02 AM
  8. clodfelterac's Avatar
    Code:
    signed by SignApk
    i know... that was more in reference to the user who said that his was listed as V670... im guessing he got one of the modified props where i had changed it to =abadassV670... ive never had any issues with the play store with this edit myself, whether on gb or ics... :-)
    07-17-2012 09:12 AM
  9. JussCallMeUno's Avatar
    Ive got a problem wit tha play store too
    It wont download anything i get error 921 or sumthin like that..
    07-17-2012 12:16 PM
  10. flapjack.fiasco's Avatar
    Why don't you try clearing your dalvik cache?
    07-17-2012 12:31 PM
  11. jgdiaz731's Avatar
    I have question for those experiencing the clock lag, does the lag affect the alarm? I've been afraid to use it to wake up for work because of the possibility of oversleeping.
    Sent from my LG-LS670 using Android Central Forums
    topdawg661 likes this.
    07-17-2012 02:27 PM
  12. anthonycr's Avatar
    I thought it did, but I used it as my alarm one night and it rang right on time. Since you wake up early every day, set it five minutes earlier than your normal alarm and test it for a few days to make sure.
    07-17-2012 02:36 PM
  13. lerxst_x's Avatar
    On my phone, it does not seem to affect the built in alarm.
    07-17-2012 02:37 PM
  14. cole2kb's Avatar
    Alarm works just fine, however as a note, I use Alarm Clock Plus instead of the one built-in.
    07-17-2012 02:44 PM
  15. KidFr3sH's Avatar
    Vibration on notifications font work for Me on latest aokp nightly
    07-17-2012 03:48 PM
  16. flapjack.fiasco's Avatar
    Somebody edited my post. Number 810. It does not say exactly what it originally said.
    07-17-2012 04:34 PM
  17. sellers86's Avatar
    yes, that was cole2kb. he probably did it to make it easier to understand.
    07-17-2012 04:40 PM
  18. jonny5449's Avatar
    lol
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-17-2012 04:42 PM
  19. anthonycr's Avatar
    He's a sneaky mod.
    sellers86 and topdawg661 like this.
    07-17-2012 04:46 PM
  20. sellers86's Avatar
    He's a sneaky mod.
    good or bad thing? probably both lol
    07-17-2012 04:51 PM
  21. cole2kb's Avatar
    Somebody sent you a PM regarding the edit.
    07-17-2012 04:57 PM
  22. jensonco's Avatar
    I used to have similar issues to this. Clearing the dalvik cache; applying market fixes; and dirty flashing the ROM/Gaaps never helped. The solution I found, which worked for me, was to ensure that you are using an external partition on your SD card (aka sd-ext). This solved everything for me and now I can install apps until I am blue in the face. If you don't know how to make an sd-ext, you must do so in a custom recovery and go under the advanced options. There you will find an option to partition your sd-card, but be warned, you will erase everything on it, so back crap up yo! I suggest using a partition at least 10% of the total storage capacity of your card. Hope this helps.
    07-17-2012 05:04 PM
  23. Nate456's Avatar
    Ssh he's watching us
    07-17-2012 05:04 PM
  24. sellers86's Avatar
    psh.. im not scared of any mods! whats he going to do, ban me? wait an minute, he can do that . ill shut up now, back on topic, how awesome is this rom people?! super stable for me
    Nate456 and skealoha86 like this.
    07-17-2012 05:08 PM
  25. kobequintana's Avatar
    So what's wrong with the built in tethering is their a solution
    Evan+escenc
    (srry if u can't read it it a fong I installed on my lg OV and it looks so cool and Evan+escenc says Evanescence)
    07-17-2012 05:57 PM
