01-05-2016 05:35 PM
2,975 ... 3536373839 ...
tools
  1. sellersj27's Avatar
    I also had the same problem on zv4. But get this. Both aokp and cm9 only got unstable after I pushed my over clock past the limit. After that, anything I had it on was unstable..
    I too have freezing occasionally that requires a battery pull on zv4... is zv5 any better?
    07-19-2012 12:29 PM
  2. cbucz24's Avatar
    Zv5 was pretty good. I made the mistake of upgrading to zv9. Call quality went up an seems no fc an less reboots. But data speeds dropped dramatic.
    @tdm im downloading latest nightly to give a try. But sadly I won't be using as much soon. My evo 4g should be here Monday. Got it nearly nib for $70. Couldn't pass it up.
    I'll still test your work on my v just to help but I won't have service much longer.
    Too bad I couldn't talk you into building for my evo. Lol kidding I know your way to busy here. Thanks for all your hard work! You rock bro!
    07-19-2012 12:37 PM
  3. LeoLawliet's Avatar
    tdm, I just thought you should know that your ICS builds are more stable than ICS nightlies I've tried on officially supported devices, which are high end. Your work is amazing.
    Sent from my LG-E739 using Tapatalk 2
    tdm likes this.
    07-19-2012 12:37 PM
  4. Badboytoast's Avatar
    Ian still on! Z4 and its solid like a Rock! I can OC at 864 with out a reboot! Yes on ICS too
    I always use "pre for new rom" before flashing!
    07-19-2012 01:04 PM
  5. LeoLawliet's Avatar
    Does anyone know of any good apps I can use to monitor my CPU change frequencies?
    07-19-2012 01:05 PM
  6. jensonco's Avatar
    What baseband?
    VM670ZV5
    tdm likes this.
    07-19-2012 01:05 PM
  7. strabo231's Avatar
    Click to view quoted image
    I have 32 apps installed and 1gb next partition but it still tells me that I am running out of space.
    What's going on?Click to view quoted image
    I'm confused... you have like 150 free out of 179. Why do you say you are running out of space? Clear your cache file and that will drop the number too. Also you have to remember that the app data stays on the phone and doesn't move to the ext unless you create another partition for data.
    07-19-2012 01:11 PM
  8. cole2kb's Avatar
    CPU Spy. https://play.google.com/store/apps/d...k.cpuspy&hl=en
    Glenar and LeoLawliet like this.
    07-19-2012 01:13 PM
  9. LeoLawliet's Avatar
    Thanks, just needed to make sure my device is entering sleep mode correctly
    Edit: and it does, thanks again
    07-19-2012 01:17 PM
  10. kobequintana's Avatar
    I lost my recovery what do i do
    This Song Rocks:
    Forever Given Forever You
    By: Evanescence
    07-19-2012 04:46 PM
  11. nitestalkr's Avatar
    Netflix ran on my gb too, but it was an ancient version of the app.
    Netflix only works without sync issues on FROYO, on GB audio and video sync is off by a few seconds, theunknownartists made a GB rom themed to look like ICS, but wasn't actually android 4.0.
    A few months ago, Netflix changed the way the app connects to The server and check for updates, forcing all older apps to update, so there is no work around. Netflix will ONLY work without any issues on Froyo based ROMs.
    sent from my un-dead sammich in my hospital bed.
    07-19-2012 04:52 PM
  12. inceyet's Avatar
    This Song Rocks:
    By: Evanescence
    Get GUI then flash your rom from SD card
    07-19-2012 04:52 PM
  13. kobequintana's Avatar
    This sounds retarted but what's a gui
    This Song Rocks:
    By: Evanescence
    07-19-2012 04:55 PM
  14. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    Graphic user interface
    07-19-2012 04:57 PM
  15. robwalters72's Avatar
    This Song Rocks:
    By: Evanescence
    flash image gui. you can get it in the market for 99 cents.
    Rob
    07-19-2012 04:57 PM
  16. kobequintana's Avatar
    Rob
    I don't got no money lol
    This Song Rocks:
    By: Evanescence
    07-19-2012 04:58 PM
  17. inceyet's Avatar
    Rob
    If you go to the root stickie its there for free
    robwalters72 likes this.
    07-19-2012 04:59 PM
  18. kobequintana's Avatar
    Culd u give me a link
    This Song Rocks:
    By: Evanescence
    07-19-2012 05:02 PM
  19. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    You could Google it, and look for the xda link. The dev offers it for free on xda.
    07-19-2012 05:03 PM
  20. inceyet's Avatar
    This Song Rocks:
    By: Evanescence
    http://forums.androidcentral.com/sho...d.php?t=108282
    [HOW-TO] Simplified Root + Recovery + Custom ROM
    First page
    Edit here you go
    http://play.google.com/store/apps/details?id=com.joeykrim.flashimagegui
    07-19-2012 05:08 PM
  21. drezliok's Avatar
    So I need two 1GB Ext3 partitions? I mean I had a full wipe including SD-EXT before flashing. I'm just wondering how I can run out when I am no where near the end of a GB worth of storage.
    07-19-2012 05:26 PM
  22. strabo231's Avatar
    No for data a 256 should be plenty. Also if you look in settings apps you'll probably notice that there are a few apps you can't move. Get titanium backup and you can move the rest to sd. don't use app 2sd or anything like that though. It'll just make a mess. After you do that you might find that you don't even need to worry about the extra partition.
    07-19-2012 05:31 PM
  23. kobequintana's Avatar
    First page
    Edit here you go
    http://play.google.com/store/apps/de....flashimagegui
    Thank you it worked
    This Song Rocks:
    By: Evanescence
    inceyet likes this.
    07-19-2012 05:32 PM
  24. drezliok's Avatar
    This rom does app to ext automagically already. Why would anyone want to put stuff on the SDcard if they have a large SD-EXT just for that?
    07-19-2012 05:58 PM
  25. strabo231's Avatar
    Several apps do not move because of the app permissions required to run. If you move an app with titanium, it does go to you re sdext, not regular sd.
    07-19-2012 06:01 PM
