01-05-2016 04:35 PM
2,975 ... 3940414243 ...
tools
  1. tdm's Avatar
    Here's a way to make one build tdm.
    http://forum.xda-developers.com/show....php?t=1461712
    Its called aroma installer. I'm thinking this is what your wanting to do.
    Thanks but I think I'll be able to write this in standard edify, except perhaps reading the baseband file.
    07-21-2012 10:09 AM
  2. tdm's Avatar
    Looks like hephappy won't work on jb. I wonder what the other p500 wizards will do...?
    http://forum.xda-developers.com/show...php?p=29108096
    sellers86 likes this.
    07-21-2012 10:13 AM
  3. jto101680's Avatar
    anyone running aokp care to try a new modded build.prop?...
    (nandroid beforehand)<--- in case you dont like it for whatever reason...
    https://www.dropbox.com/s/rdk73aicug6134e/build.prop
    feedback is appreciated... :-)
    -attached a list of added/adjusted lines/values to the build.prop from the 0715aokp nightly...
    found here:
    Geek Yogi Android - build.prop tweaks (Root Only)
    * goes in system/ (in place of original)
    * rename original .bak (in case you want to go back to the original and you didnt make a nandroid)
    Hey, these look awesome, everyone loves scripts that make things smoother and faster. I have a suggestion however, and maybe you've done this already. Why not make a separate post for these, perhaps name them "quattrimus mods" and just make them flashable zips. Kind of like amphetamines but more specific?
    andrewnelson23 likes this.
    07-21-2012 10:27 AM
  4. varockchick's Avatar
    OK.....downloaded CPU spy and it seems its not going in deep sleep...so that's where my battery is going I guess? ..what can I do to fix it?
    07-21-2012 10:29 AM
  5. clodfelterac's Avatar
    thanks, but its just some edits ive found... ill think about the thread idea... if nothing else i guess it would be nice for us to have a centralized location to test/discuss the efficacy/application of the many tweaks that are floating around... i.e. build.prop, init.d, egl, agps, etc...
    jto101680 and LeoLawliet like this.
    07-21-2012 11:13 AM
  6. grantbob's Avatar
    About to upgrade from Gingerbreak. Should I install the beta or the latest nightly?
    07-21-2012 11:16 AM
  7. sellers86's Avatar
    Doesn't seem like arjen is either..
    Sent from my VM670 using Tapatalk
    07-21-2012 11:17 AM
  8. dingermtb's Avatar
    So far, the build.prop is smooth and fast. A great addition to tdm's awesomeness.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    clodfelterac likes this.
    07-21-2012 12:11 PM
  9. tdm's Avatar
    Is this with cm or aokp? I think cm might have some deep sleep issues but aokp seems to work better.
    07-21-2012 12:14 PM
  10. varockchick's Avatar
    Aokp....its bad for me on both
    07-21-2012 12:24 PM
  11. jto101680's Avatar
    Is there a way to make them zips. It would be awesome to just flash over the rom. If its not a flashable script I tend to shy away. I have never changed any lines of code or scripts. Scares the crap out of me.
    07-21-2012 12:33 PM
  12. jayleekay's Avatar
    I was going to test my old Netflix apk (1.2.2) but I can't even open it in ics. It auto closes. So much for that.
    nitestalkr likes this.
    07-21-2012 12:46 PM
  13. robwalters72's Avatar
    found here:
    Geek Yogi &bull; Android - build.prop tweaks (Root Only)
    * rename original .bak (in case you want to go back to the original and you didnt make a nandroid).
    I'm running AOKP and I just swapped out the build prop. Seems smooth but I haven't had a chance to really check it out yet. I'll check back in a little later after some testing.
    Rob
    07-21-2012 12:46 PM
  14. robwalters72's Avatar
    I am running AOKP and I checked my CPUspy and it says I was not in deep sleep at all, but I left my phone off the charger last night and after more than 14 hours of just sitting, battery was at 89%. That's awesome!
    Rob
    07-21-2012 12:50 PM
  15. clodfelterac's Avatar
    as long as you make a nandroid before you modify anything youll be fine... if you dont see any difference, then you can restore your nand or delete the modified build.prop, rename the original back to build.prop, save, wipe cache/dalvik via recovery, reboot... and its back to the way it was... ill work on making a flashable zip to simplify things... :-)
    jto101680 likes this.
    07-21-2012 12:54 PM
  16. andrewnelson23's Avatar
    I will most likely have a work-around for Netflix on ics late tonight. buuuut I kinda wanna go to dark knight rises tonight...
    monepone and nitestalkr like this.
    07-21-2012 12:55 PM
  17. dingermtb's Avatar
    try youtube(hq), does it seem any better?... any difference in call quality?... signal?...
    On the app, everytime i go to search, it freezes the phone and gotta pull battery. I'll try it on the browser later
    07-21-2012 01:57 PM
  18. varockchick's Avatar
    Where is the music player on aokp?
    07-21-2012 03:50 PM
  19. tdm's Avatar
    There aren't any installed by default. You need to find and install your own. This is not my doing, it is aokp policy.
    inceyet likes this.
    07-21-2012 03:54 PM
  20. robwalters72's Avatar
    I gave it a good testing and I found it would freeze and require a battery pull to reboot. I thought it might have to do with keeping the launcher in memory, but I couldn't find it using build prop editor from the market.
    Anyway, let me know if you make some changes. I'll test it out again.
    Rob
    07-21-2012 03:57 PM
  21. ganggreen30's Avatar
    Why is that a policy, I'm curious!
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    07-21-2012 04:11 PM
  22. braxton355's Avatar
    I switched to an iPhone 4 but I will be in the background ! I just wanna wish you luck tdm (: I'll be here.
    tdm likes this.
    07-21-2012 04:33 PM
  23. andrewnelson23's Avatar
    Ttpod is a good alternative, it has a pretty sweet widget. And it supports music types that aren't MP3. It now costs on the play store.
    07-21-2012 04:34 PM
  24. HurrrDurrrDURP's Avatar
    @tdm
    how is the kernel merge going? Did good luck come your way yet?
    07-21-2012 05:05 PM
  25. dschlemmer318's Avatar
    Has anyone had any trouble with 3g not reconnecting after losing service
    07-21-2012 05:16 PM
