01-05-2016 04:35 PM
2,975 ... 4849505152 ...
tools
  1. kobequintana's Avatar
    Best bug ever lol
    I guess my other statement is now obsolete xD
    sent from my un-dead sammich.
    Ikr
    This Song Rocks:
    Forever Given Forever You
    By: Evanescence
    07-23-2012 01:36 PM
  2. JasonDiaz123's Avatar
    Can you help me ? sometimes the AOKP rom like reboots my phone by it self -.- it gets annoying and i wanna know how i can stop it because its an awesome rom
    07-23-2012 02:24 PM
  3. nitestalkr's Avatar
    Try turning down your over clock speeds, and use the savagedzen governor. InteractiveX and performance often cause reboots.
    07-23-2012 02:29 PM
  4. JasonDiaz123's Avatar
    Oh alright , thanks alot dude. hopefully it works
    07-23-2012 02:32 PM
  5. reverendjoe's Avatar
    I just wanted to say as I'm not sure if this has been mentioned before but on quattrimus beta 1 my phone will reliably enter deep sleep mode it seems only if airplane mode is turned on. It is not enough to just have data switched off, as that still seems to prevent it from sleeping. just something i noticed
    07-23-2012 02:35 PM
  6. daddy4life09's Avatar
    where to get the latest nightly?goo.am is only showing up to 7/12
    07-23-2012 02:38 PM
  7. Nate456's Avatar
    You seem to be running outdated software i suggest downloading a nightly.
    07-23-2012 02:39 PM
  8. nitestalkr's Avatar
    Within goo.Im manager, goto browse files
    /devs/tdm/roms/quattrimus/nightly/vm670. There's no more change logs. Just the ROMs, latest is 7/23 for both aokp and cm9
    daddy4life09 and Badboytoast like this.
    07-23-2012 02:45 PM
  9. daddy4life09's Avatar
    whats the better build?in your opinion?cm9 or aokp?i know last i checked aokp youtube was a slideshow...
    07-23-2012 02:50 PM
  10. kobequintana's Avatar
    I like CM9 it wrks for me
    This Song Rocks:
    By: Evanescence
    07-23-2012 03:02 PM
  11. nitestalkr's Avatar
    I prefer AOKP, the only time I use YouTube, is to listen to music, so the video quality doesn't matter to me.
    I like the customization that AOKP has to offer.
    Badboytoast likes this.
    07-23-2012 03:22 PM
  12. kobequintana's Avatar
    In stalled the new CM9 nightly still asom thanx tdm
    This Song Rocks:
    By: Evanescence
    07-23-2012 03:34 PM
  13. drymarro's Avatar
    I really like AOKP but it's too much of a battery drain. I'm not even using it and it loses battery life really fast.
    07-23-2012 03:46 PM
  14. nitestalkr's Avatar
    I rarely burn through my battery, it lasts on average, 15-19 hours standard use (texting, music, occasional phone call, some internet browsing, and Facebook) and 6-9 hours heavy usage (screen off for maybe 5 minutes tops every hour).
    I'm clocked at 844max/480min on savagedzen governor, 24/7.
    And I don't have any other performance or battery saving scripts flashed on top of the ROM.
    You can view the thread I made, listing my entire system configuration.
    "The Rom comparison thread"
    http://forums.androidcentral.com/sho...set up Thread.
    07-23-2012 03:50 PM
  15. kobequintana's Avatar
    Speeking about cpu settings what is the best cpu setting to save battery life on CM9
    This Song Rocks:
    By: Evanescence
    07-23-2012 04:01 PM
  16. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    As always, I recommend savagedzen with 787max(or something in the 700 range)/480min.
    07-23-2012 04:09 PM
  17. kobequintana's Avatar
    Dose it reboot like no tomorrow or dose it reboot like once every few hours etc.
    This Song Rocks:
    By: Evanescence
    07-23-2012 04:17 PM
  18. RavinX's Avatar
    This Song Rocks:
    By: Evanescence
    I use 787/480 savagedzen and I have had zero reboots in 5 days. Using AOKP beta build.
    07-23-2012 04:29 PM
  19. kobequintana's Avatar
    O well im using CM9 nightly 23
    This Song Rocks:
    By: Evanescence
    07-23-2012 04:30 PM
  20. kobequintana's Avatar
    Dose any 1 els on the CM9 have a bug with the Facebook App
    This Song Rocks:
    By: Evanescence
    07-23-2012 05:00 PM
  21. dingermtb's Avatar
    This Song Rocks:
    By: Evanescence
    I use Friendcaster with no issues.
    Also, i run 806 max 480 min with SavageZen with 0 reboots. Was on AOKP, but CM9 seems to run much smoother for me. The main thing i miss in AOKP is the ability to center the clock and to be able to change carrier from Virgin Mobile to Zombie Mobile.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    07-23-2012 05:15 PM
  22. kobequintana's Avatar
    Lol Zombie Mobile XD
    This Song Rocks:
    By: Evanescence
    07-23-2012 05:18 PM
  23. nitestalkr's Avatar
    That's why I love AOKP, the customization options keep me using it. My carrier label is set to "un-dead sammich".
    And I'm glad to see more people taking my advice with the savagedzen governor. Its the most stable governor IMO, and has a nice balance between performance and battery life.
    dingermtb likes this.
    07-23-2012 05:24 PM
  24. kappacat's Avatar
    Can easily change that with by editing eri.xml in /system/framework/framework-res.apk with a hex editor. If you don't know how a quick google search would be a good idea.
    07-23-2012 05:26 PM
  25. nitestalkr's Avatar
    I was thinking asking someone if they could make a flash able zip for cm9, but I got lazy. If you provided the modified files, I could make a flash able zip for everyone.
    07-23-2012 05:31 PM
