01-05-2016 05:35 PM
2,975 ... 5152535455 ...
tools
  1. kobequintana's Avatar
    Yay i have mor spac on my sd card
    Befor: around 800MB
    Nw: 1.71GB
    This Song Rocks:
    Forever Given Forever You
    By: Evanescence
    07-24-2012 05:37 AM
  2. varockchick's Avatar
    ok....here is a screen shot of my negativeness....weird....it is still the same after the newest nightly
    07-24-2012 07:21 AM
  3. sellersj27's Avatar
    I had the same issue, and my GAPPS would come and go. I would suddenly have no market or apps, reboot and they were all back. I figured there was some residual data; wiped and reflashed, and everything is good!
    07-24-2012 09:03 AM
  4. varockchick's Avatar
    I was referring to the negative value of the used internal memory on my phone....i have very few apps on my phone...i mainly download books and read em...when i'm finished with one i delete it....most people think it must be a pain reading on such a small screen....but you get used to it...lol
    07-24-2012 09:32 AM
  5. Wheellzz's Avatar
    At the risk of coming off as a total noob, (sorry of this has already been addressed) on CM9 Beta 1 and nightlies i am unable to get vibration notifications to work. I'm assuming it's a known bug but was unable to pin down if it had been noted in the tread while searching.
    Also is there a way to edit the timestamp font color in messaging? Light grey on white. is a bit hard on the eyes.
    Thanks everybody.
    07-24-2012 11:00 AM
  6. varockchick's Avatar
    Thanks everybody.
    go into settings....sounds and make sure you have vibrate and ring checked...thats how i got it to work on mine....cant figure out how to change te timestamp font color but you could download go sms from the market and and customize it any way you want
    Wheellzz likes this.
    07-24-2012 11:13 AM
  7. flapjack.fiasco's Avatar
    Thanks everybody.
    I agree, light grey on white is a strain to read. There's always those inverted gapps. I'm not a fan of using modified system apps myself, as an update to said apps could make things a little screwy or broken, but there are some people using it, so maybe it's worth a try.
    Inverted Google Apps
    07-24-2012 11:17 AM
  8. Wheellzz's Avatar
    indeed, i'll give it a shot. i'm not to hot on using modified system apps either....but i don't exactly have anything to lose, can always reflash...
    07-24-2012 11:43 AM
  9. grantbob's Avatar
    Over the weekend, I upgraded from Gingerbread to CM9. After playing with it for a couple of days now, I really like it.
    Are there enough changes to warrant flashing the latest nightly on a daily basis, or can I just do it once or twice a week?
    07-24-2012 12:58 PM
  10. varockchick's Avatar
    I do it every night cuz I'm OCD about it lol....seems like with every build things run smoother..but I'm a noob so what do I know...lol
    07-24-2012 01:16 PM
  11. benslgdroid's Avatar
    In an ideal world that's how it's supposed to work although it doesn't always happen that way. You'd be surprised how an accidental punctuation or even a capital can screw things up.
    sellersj27 likes this.
    07-24-2012 01:43 PM
  12. robwalters72's Avatar
    I don't understand all of the details, but I read an explanation in the old Quattrimus thread about the way the sd-ext/app folder is linked to data/app so the rom can find the apps you have installed.
    The system just cannot calculate the correct space free/used while the folders are linked. Otherwise, it works exactly as it's supposed to.
    Hope this info helps.
    Rob
    07-24-2012 02:11 PM
  13. dgb43070's Avatar
    You can add remove and resize partitions nondestructively using a program called gparted live.
    07-24-2012 03:08 PM
  14. nitestalkr's Avatar
    Orrrrr partition wizard for windows.
    No need to format/wipe anything, you can resize without loss of data.
    sent from my un-dead sammich.
    07-24-2012 04:19 PM
  15. nitestalkr's Avatar
    You can flash the newest every now and then, once idk twice a week is good.
    Like varrokchick, I flash every build, AS SOON as its built and uploaded.
    07-24-2012 04:21 PM
  16. dingermtb's Avatar
    I too flash daily, hence, supposedly being throttled. Gives me something to do at work. As a Security Supervisor, i basically get paid to play on my phone, lol.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    07-24-2012 04:34 PM
  17. kobequintana's Avatar
    Whats new in aokp? Bcuz i want to switch form cm9
    This Song Rocks:
    By: Evanescence
    07-24-2012 04:36 PM
  18. nitestalkr's Avatar
    Now I'm going to go into that carrier trade, based on JUST your statement xD
    07-24-2012 04:42 PM
  19. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    Umm, not all that sure, usual AOKP bugs are still there, haven't really noticed anything big change lately. It still seems to be the same ole AOKP that ive been using from the start. I'm sure there's small bug fixes here and there that I don't notice.
    07-24-2012 04:46 PM
  20. kobequintana's Avatar
    Ok and wen switching could i just do a dirty wipe or a clean wipe
    This Song Rocks:
    By: Evanescence
    07-24-2012 04:47 PM
  21. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    The dirtiest wipe you can think of.
    Well.. wipe just cache/dalvik cache.
    07-24-2012 05:02 PM
  22. clodfelterac's Avatar
    a clean and thorough wipe/format is always recommended to weed out any errors/bugs that may/can be caused by a dirty flash... its pointless to report any bugs you find if you dont properly wipe/format/install fresh, as bugs could be from use of improper procedure and not necessarily the rom itself (following proper procedure)...
    Teh_Gaberz likes this.
    07-24-2012 05:27 PM
  23. nitestalkr's Avatar
    Actually, even tdm says a dirty flash does no harm when switching between quattrimus cm9 and quattrimus aokp. Its because they are still the same ROM, just different mods. Now if you're switching from 2 different ROMs ie, quattrimus and bobz ICS, THEN you do a full wipe.
    07-24-2012 05:33 PM
  24. kobequintana's Avatar
    Ok i just falshed AOKP qa d changed the cup settings to 480/787 savangenen wrk pritty gpod only had to random reboots though
    This Song Rocks:
    By: Evanescence
    07-24-2012 06:13 PM
  25. kobequintana's Avatar
    What cpu setting stops random reboots for AOKP
    This Song Rocks:
    By: Evanescence
    07-24-2012 06:41 PM
