01-05-2016 05:35 PM
2,975 ... 5253545556 ...
tools
  1. nitestalkr's Avatar
    What cpu setting stops random reboots for AOKP
    This Song Rocks:
    Forever Given Forever You
    By: Evanescence
    Savagedzen works for me.
    I run 844max/480min, and experience 0 reboots.
    sent from my un-dead sammich.
    07-24-2012 07:04 PM
  2. kobequintana's Avatar
    1 more question lol i was restoringy system an i got to the sdext restpre but it said error could not mount sdext. Is that bad
    This Song Rocks:
    By: Evanescence
    07-24-2012 07:13 PM
  3. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    No, that usually happens from time to time.
    What recovery are you using?
    07-24-2012 07:18 PM
  4. purpulehaze's Avatar
    I'm running 787/600 performance governor smoothly
    07-24-2012 07:23 PM
  5. kobequintana's Avatar
    Drews 1touch recovery
    This Song Rocks:
    By: Evanescence
    07-24-2012 07:32 PM
  6. jayleekay's Avatar
    I had to chime back in and say i was wrong about the bluetooth voice dialing working. It works without bluetooth, but not with.
    07-24-2012 07:47 PM
  7. nitestalkr's Avatar
    This Song Rocks:
    By: Evanescence
    Then yea, that's normal, especially since you changed your ext size.
    07-24-2012 07:51 PM
  8. kobequintana's Avatar
    Ok cool i have nothing to worry about
    This Song Rocks:
    By: Evanescence
    07-24-2012 07:55 PM
  9. bennettg's Avatar
    Kernel status? Non barnicle wifi tether workarond? I need non ad hoc tether please
    07-24-2012 07:57 PM
  10. kobequintana's Avatar
    So do i but all we can do is wait
    This Song Rocks:
    My Heart Is Broken
    By: Evanescence
    07-24-2012 08:11 PM
  11. vm_760's Avatar
    Thought I'd post this showing my phone running at 0%. Ran like that for over an hour today before it finally died. I did it after flashing the newest aokp nightly.
    Bug? Or just a glitch?
    Sent from my twice fried OV using Quattrimus as a pacemaker
    07-24-2012 09:16 PM
  12. nitestalkr's Avatar
    Nice set up!
    Mind sharing it in my Rom comparison/set up thread?
    Did you wipe cache and dalvik cache?
    Try wiping battery stats from recovery.
    Or, maybe its the circle battery mod.
    These are just a few suggestions.
    07-24-2012 09:25 PM
  13. nitestalkr's Avatar
    M9-NIGHTLY-120605 Change Log: Disable ip6tables bandwidth control for the moment,some wifi tether fixes related to hostapd(not stable yet), disable dalvik heaps logs
    The quoted text is what 1 device did to kind of fix wifi tether in their cm9 rom.
    And they're using a froyo based kernel, so they're worse off than us.
    07-24-2012 10:04 PM
  14. jto101680's Avatar
    I promised myself i wouldn't flash this again until the new kernel was working. Tdm, like Rob Schneider would say on an Adam Sandler movie, "YOU CAN DOOOO IT"!!!
    andrewnelson23 likes this.
    07-24-2012 10:15 PM
  15. droiddekka's Avatar
    what's the best workaround for recording/viewing video cam files?
    I'm on aokp 724 currently.
    07-24-2012 10:24 PM
  16. nitestalkr's Avatar
    You can record using the camera app on tthe phone, and to view it, use mx player from the market.
    droiddekka likes this.
    07-24-2012 10:26 PM
  17. ganggreen30's Avatar
    TDM I was wondering if u could implement permission managements into our rom? Something like Svyat does on Xda with his Pdroid patch app. Thanks
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    07-24-2012 11:55 PM
  18. nitestalkr's Avatar
    Permissions management is included in the super user app.
    Unless you're talking about read/write permissions..
    07-24-2012 11:57 PM
  19. benslgdroid's Avatar
    use mx player.
    Any progress on the Netflix you were working on?
    07-25-2012 12:56 AM
  20. andrewnelson23's Avatar
    Here it is.
    and kobe. flash gapps.
    07-25-2012 01:07 AM
  21. ganggreen30's Avatar
    Well I guess I'm speaking of privacy permission controls check out pdroid patcher or pdroid in the market jerryscript had a permission manager on his backside iho rom where u would go to the manage apps setting and scroll down to permission tap on a permission and poof deny a permission say start up on boot or deny phone id or deny sms etc....
    07-25-2012 01:14 AM
  22. andrewnelson23's Avatar
    did flashing gapps fix? btw if you were booted into a rom that's nowhere even close to a bricked phone haha :P
    07-25-2012 01:18 AM
  23. nitestalkr's Avatar
    You can change permissions of apps in the super user app.. I think.
    I miss Jerryscript, he was such a great dev!
    clodfelterac likes this.
    07-25-2012 01:20 AM
  24. JadenBrown30's Avatar
    tdm, I just wanted to say thank you for all of your hard work on this ROM. It has given my phone a great new life. I appreciate all of the countless hours you put into it.
    clodfelterac and tdm like this.
    07-25-2012 01:21 AM
  25. Wheellzz's Avatar
    curious if anyone has been able to fix the contacts / caller id / lockscreen album art cutoff, or knows of a workaround.
    also what recovery are most people using, i think i'm running an outdated one back from when i'd been running IHO..
    thanks everyone.
    07-25-2012 01:22 AM
