01-05-2016 05:35 PM
2,975 ... 5354555657 ...
tools
  1. nitestalkr's Avatar
    curious if anyone has been able to fix the contacts / caller id / lockscreen album art cutoff, or knows of a workaround.
    also what recovery are most people using, i think i'm running an outdated one back from when i'd been running IHO..
    thanks everyone.
    Use Drew's Cannibal Open touch recovery. Its bad @$$!
    sent from my un-dead sammich.
    Wheellzz likes this.
    07-25-2012 01:24 AM
  2. strabo231's Avatar
    Anybody know off the top of their head where this is in the rom files?
    META-INF/com/google/android/update-binary
    I know ive seen it a dozen times and now and can't seem to find it again
    07-25-2012 10:21 AM
  3. cole2kb's Avatar
    Last few pages cleaned. Keep it on topic, guys. Use private messages or a separate thread.
    tdm, inceyet, purpulehaze and 3 others like this.
    07-25-2012 10:57 AM
  4. sellers86's Avatar
    its in the directory you typed... lol. But you most likely looking for the updater script which is in the same directory. Ive never been able to open an update binary, even on linux.
    07-25-2012 11:04 AM
  5. strabo231's Avatar
    You have got to be kidding me! Yeah I see it now. Looked right by it 20 times probably.
    BuggerZ likes this.
    07-25-2012 11:20 AM
  6. tdm's Avatar
    I promised myself i wouldn't flash this again until the new kernel was working. Tdm, like Rob Schneider would say on an Adam Sandler movie, "YOU CAN DOOOO IT"!!!
    It'll be a while. I started working on my marquee.
    jto101680 likes this.
    07-25-2012 12:07 PM
  7. jensonco's Avatar
    Anyone solve the battery drain issue with ICS?
    07-25-2012 12:13 PM
  8. sellers86's Avatar
    I don't experience this issue. Btw, for anyone reading this, I recommend aokp unless you watch YouTube. Its rock solid. I've been running it for 2 days with no reboots, and even with no OC its extremely smooth. Good work tdm!
    tdm likes this.
    07-25-2012 12:29 PM
  9. jensonco's Avatar
    My battery drains wicked fast...even if I'm doing very little. It once lost 30% in just under 2 hours.
    07-25-2012 12:31 PM
  10. jensonco's Avatar
    Screen brightness and battery calibration doesn't fix it.
    07-25-2012 12:34 PM
  11. sellers86's Avatar
    My battery drains wicked fast...even if I'm doing very little. It once list 30% in just under 2 hours.
    Thats weird.. I went on aokp and from unplugging the charger at 12:30 pm I still had about 45% remaining at 3 in the morning. Keep in mind I have a 3900mah battery. On my regular battery I can get about 15 hours with moderate usage. Including a couple test flashes.
    07-25-2012 12:35 PM
  12. sellers86's Avatar
    I've been off of my charger for 2 hours and it says I've been off of it for 7 minutes. Mine gives a false reading. BUG REPORT
    07-25-2012 12:38 PM
  13. jensonco's Avatar
    My time on battery is correctly displayed.
    sellers86 likes this.
    07-25-2012 12:43 PM
  14. nitestalkr's Avatar
    All the battery stars are still a lil touchy here and there, you may had a soft reboot and didn't notice. Which would explain the 7 minutes...
    It only tells you how long the OS has been booted, so any reboots, soft reboots, or random reboots interfere with the time shown.
    07-25-2012 12:55 PM
  15. droiddekka's Avatar
    You can record using the camera app on tthe phone, and to view it, use mx player from the market.
    when i try to install the codec i am getting a 'not compatible with other applications using the same shared ID' error
    any ideas what causes this?
    07-25-2012 01:19 PM
  16. nitestalkr's Avatar
    are you installing the one that its recommending?
    i've never ran into, nor heard of that issue.. so this is news to me. O.o
    07-25-2012 01:25 PM
  17. kobequintana's Avatar
    Could I get full gapps for CM9
    07-25-2012 02:54 PM
  18. BuggerZ's Avatar
    Google Apps - RootzWiki
    07-25-2012 03:02 PM
  19. kcls's Avatar
    Yes, just download them here: Goo.im Downloads - Downloading gapps-ics-20120429-signed.zip
    And flash them with the ROM.
    07-25-2012 03:11 PM
  20. cbucz24's Avatar
    Well TDM, I tried waiting an looking but I couldn't hold out any longer. I couldn't find a marquee at a reasonable price, so I ended up with an evo. I know this is all a bit off topic, but I wanted to say how impressed I am with the work you, kraven, etc have put into these roms.
    My poor v seems so much smoother running your AOKP than my evo running it.
    I'm a nightly or two behind but its so fast. I just wanted to say a big thanks!! :thumbup:
    I'll still be using your work for a bit longer till I can find a cheap donor. Getting harder
    I know you will do amazing work for the marquee. Good luck with everything.
    tdm likes this.
    07-25-2012 03:53 PM
  21. s13-d's Avatar
    How long have you been experiencing this? My OV has had the same problem, but it seems to have come out of nowhere over the last two or three days. Same deal, battery drains much faster than usual and the screen is listed as causing 50-70% of the drain. Can't be the brightness because I never have it above 40%.
    07-25-2012 04:03 PM
  22. sellers86's Avatar
    That makes sense, I did throw my phone to prove to my friend they are indestructable... lol
    07-25-2012 04:07 PM
  23. nitestalkr's Avatar
    Yup... that would do it xD
    I love these phones so much!!
    People often put their phones in a plastic baggy while its pouring rain, im just walking in the open rain, texting, watching all the rain drops splash on my screen(without any extra protection at all). xD
    07-25-2012 04:10 PM
  24. sellers86's Avatar
    These phones are just about unbrakable and unbrickable. And it just won't die thanks to all of our awesome devs. Thanks to tdm, bobzhome, Leslie Ann, gannon, mrg666, even the older devs like obijohn mmarz and any other devs im not remembering. You guys are awesome and I really appreciate it. Thanks.
    inceyet, tdm, Badboytoast and 1 others like this.
    07-25-2012 05:32 PM
  25. kidfcp's Avatar
    Off topic I know but let me humor you guys... I once jumped in pool 5 ft. deep with my OV in my pocket still, for at least 5 minutes straight or more (yes some beers may have been involved). Aired it out in sun, did the bowl of rice trick, etc. Thought I was toast. After 3 days I was operational again and gradually the LCD spotting faded.
    These things are built well. No doubt. Between that and TDM's hard work I'm lovin' my OV
    sellers86, tdm and Badboytoast like this.
    07-25-2012 05:56 PM
