01-05-2016 04:35 PM
2,975 ... 5556575859 ...
tools
  1. kcls's Avatar
    Don't buy phones with locked boot loaders, and avoid samsung. LG phones are not usually sexy but they easy to dev. Well, aside from root on the marquee zvc update.
    Evo V doesn't have a locked bootloader, afaik.
    tdm likes this.
    07-26-2012 12:36 PM
  2. cbucz24's Avatar
    Lol I definitely avoid Samsung, had too many issues in the past. But unlocking the boot loader wasn't that bad. Achieving the s-off was a chore, but its all doable :beer:
    07-26-2012 12:37 PM
  3. tdm's Avatar
    Google searches indicate it does...
    kcls likes this.
    07-26-2012 01:10 PM
  4. vm_760's Avatar
    One of my other phones is the LG Thrill 3d and it's pretty sexy..lol
    07-26-2012 01:28 PM
  5. sellersj27's Avatar
    Can anyone that has successfully overclocked Quattrimus CM9 beta on their OV please msg me. I'm having lots of reboots and freezing with mine. I love ICS but mannnn is it laggy compared to CM7 IHO Backside overclocked to 480 and 806.
    All OV's are not equal... I had the same problem with cm9 beta. aokp was much better...cm9 Godzilla, so far, is faster yet! Are you running any script tweaks? V6 supercharger is awesome
    07-26-2012 01:48 PM
  6. Super R's Avatar
    Has anyone got the headset microphone working in this rom? It looks like BobZ fixed it in his ICS rom, but it is still not working for me in Quattrimus.
    Thanks to all who have worked on this project...it is amazing
    tdm likes this.
    07-26-2012 06:20 PM
  7. coreyactor's Avatar
    Sorry somewhat of a no0b question. Is it safe to put "[MOD]Amphetamines" together with this Rom?
    07-26-2012 06:47 PM
  8. sellers86's Avatar
    Yes. Make a backup just in case.
    coreyactor likes this.
    07-26-2012 06:49 PM
  9. ThatGuyLurkin's Avatar
    Yes. Completely.
    @TDM, whenever I use this rom, it locks up after 5 minutes. Every boot... :/?
    07-26-2012 06:50 PM
  10. topdawg661's Avatar
    Is tdm still working on ics for the optimus slider??
    My customized tapatalk signature
    07-26-2012 07:12 PM
  11. Revenant Ghost's Avatar
    Actually, the bootloader is locked. It's not too hard to unlock it through HTCdev though. Just make sure you use the right browser when you do.
    But getting S-OFF to be able to flash ROMs, kernels and radios without much hassle, to me that was a little unnerving. Especially when you have to do that "wire trick".
    07-26-2012 08:02 PM
  12. dingermtb's Avatar
    Amphetamines MOD runs great on this ROM.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    inceyet likes this.
    07-26-2012 09:30 PM
  13. kobequintana's Avatar
    im having 3g issues could it be the rom or the phone
    i tried turning it off for 10 min than turning it on and it still says 1x and its then bars rare wight not red (have a theme installed)like when you dont have data on
    can it be the rom, phone, or where i am?
    drm1992 likes this.
    07-26-2012 09:32 PM
  14. flapjack.fiasco's Avatar
    Sounds like location. Are you somewhere that you don't normally go?
    07-26-2012 09:46 PM
  15. dingermtb's Avatar
    I get the same issue when my bus gets to the same area every day. Definitely sounds like location. Possibly a "dead zone". I'm in Philadelphia, a major city, but there are still "dead zones" here and there around the outskirts.
    07-26-2012 10:07 PM
  16. kobequintana's Avatar
    No at my gpas like always and nw it says 3g but 1 bar and no arrows that says its wrking
    Song: Understanding
    Band: Evanescence
    07-26-2012 10:13 PM
  17. nitestalkr's Avatar
    Song: Understanding
    Band: Evanescence
    Sounds like the infamous "Virgin Mobile is working on their towers in you're area." response would be your answer.
    sent from my un-dead sammich.
    07-26-2012 10:54 PM
  18. kobequintana's Avatar
    Ok thank you
    Song: Understanding
    Band: Evanescence
    07-26-2012 11:19 PM
  19. dzdzjb's Avatar
    Just to double check, what are your clock speed governors? Too low a minimum speed, especially with the wrong governor, can cause locking up or overheating. 480/600 with msm7k or SmartAssV2 have worked very well for me.
    07-27-2012 12:13 AM
  20. kobequintana's Avatar
    Is their something wrong with the VM670 nightlys because all them show up *** July 26???
    Song: Understanding
    Band: Evanescence
    07-27-2012 05:16 AM
  21. nitestalkr's Avatar
    Song: Understanding
    Band: Evanescence
    July 27 is the latest, they finish getting uploaded by 3:00am-3:30am Arizona time (GMT +7) from what I've noticed.
    07-27-2012 05:36 AM
  22. flapjack.fiasco's Avatar
    This no changelogs business is seriously irking my curiosity. Does anyone know a place to view the nightly changelog besides going on github? Like, does AOKP or CM have a nightly changelog page?
    07-27-2012 08:20 AM
  23. ThatGuyLurkin's Avatar
    Overclocking really wouldn't do it justice.
    I normally run 480/806 but same problem. So I did 480/787, still there. I tried lower, same problem. It's frustrating....
    07-27-2012 08:38 AM
  24. ThatGuyLurkin's Avatar
    I too, am in Philadelphia. With ICS I get 1 bar reception in a 2-3 zone area and alot of service timeouts. IMHO, ICS has worse reception.
    07-27-2012 08:42 AM
  25. pbailey212's Avatar
    Your rom has nothing to do with your reception. The only thing that MIGHT effect it would be your baseband, which is unaltered from flashing roms. Maybe they are working on the towers in your area. Or something near by is now interfering with your signal. But from Froyo to gingerbread to ics etc, your signal is not affected
    sent from my Nokia 5110
    07-27-2012 09:04 AM
