01-05-2016 05:35 PM
2,975 ... 45678 ...
tools
  1. cole2kb's Avatar
    If you created your partition using Cannibal (or any other recovery), you're good to go. It's working automagically in the background.
    07-05-2012 04:13 AM
  2. Octahedron's Avatar
    How do I check it? How do I manage it? It's driving me crazy.
    07-05-2012 04:43 AM
  3. cole2kb's Avatar
    I can't help you there. I actually have yet to find an easy way to check it myself. But if your recovery stated it created the partition or didn't throw up any errors, you are good.
    I think the point of having it integrated in this way is to take the work out of having an sd-ext partition.
    inceyet likes this.
    07-05-2012 04:53 AM
  4. bennettg's Avatar
    That's does nothing if I skip wpa
    Me too. Frustrated.
    07-05-2012 06:02 AM
  5. cpresley1993's Avatar
    Great rom tdm! One question ....I am using cm9 and I notice on the home screens when I press the menu button, static Google search and gray border above the dock icons turn white. Then when I press menu again..they turn gray again. Why is that? It did this on kravens alpha 11 as well. It didn't do this when ics roms were based on 4.0.3
    tdm likes this.
    07-05-2012 06:38 AM
  6. inyourface09's Avatar
    Wow great work tdm and thekeaven and everyone else who made this possible! can anyone confirm that the native hotspot is working in the beta? Jw thanks
    tdm likes this.
    07-05-2012 07:40 AM
  7. tdm's Avatar
    Hey tdm
    Do you think when posting to goo.im you could put Cm9 and aokp in separate folders? (Ex. /devs/tdm/
    Quattrimus/Ls670/CM9/build.zip)
    I'm just afraid that I'm going to rush and tap the wrong one.
    Thanks
    Sent from my LG-LS670 using Android Central Forums
    Maybe... But can't you just zoom in more to make the links bigger?
    topdawg661 likes this.
    07-05-2012 08:33 AM
  8. tdm's Avatar
    can anyone give me a step by step on how to setup sd-ext with this rom? i tried creating an sd-ext from cannibal recovery, but how do i know if it worked?
    After creating it, wipe data and cache to ensure it is fully used and all old files are gone.
    Check it's being used by either looking at the first couple pages of logcat output at boot, or use a shell (adb or terminal emulator) and run mount. You should see both /data/app and /data/dalvik-cache mounted on /dev/block/mmcblk0p2.
    07-05-2012 08:41 AM
  9. tdm's Avatar
    Don't know, sorry.
    07-05-2012 08:43 AM
  10. ItsMoo's Avatar
    I noticed in the notification drop down, the slider for brightness moves in predetermined increments; it sort of snaps into place, but not exactly where you leave it. just fyi.
    awesome ROM in all other aspects! :beer:
    Sent from my Quattrimus ICS Optimus V
    tdm likes this.
    07-05-2012 09:25 AM
  11. chuckconnors's Avatar
    @tdm Just wanted to say thanks for all your hard work. I switched over from IHO Backside CM7 and must say that I'm loving my phone again! I've had a few issues with BT disconnect causing reboots and invalid package files from the market but I've managed to deal with both 'issues'. I'm sure these will all get worked out eventually.
    I'm thinking of trying out AOKP. Can I wipe both caches and flash on top of Quattrimus CM9 or do I need to do a full wipe for the install?
    Would also like to know how to turn off the shutter sound on the camera.
    tdm likes this.
    07-05-2012 10:16 AM
  12. cbucz24's Avatar
    To be safe as always, any time you switch roms its good to wipe everything. Who knows how many conflicting items and issues you could have.
    Camera is under sounds menu on both roms.
    tdm likes this.
    07-05-2012 10:39 AM
  13. cbucz24's Avatar
    If anyone wants a resized boot animation for AOKP, here you go. I didn't do any work to make it look "pretty" (you can definitely tell it's been scaled down), but it's proportionate and I personally find it much nicer to look at then before.
    Click to view quoted image
    http://dl.dropbox.com/u/72059024/bootanimation.zip
    Lol I was going to do that yesterday but fell asleep holding my phone after work.
    Its weird the images were square? The p500 doesn't have a square screen, so why were they sized like that in the first place? I vaguely remember this used to fit our screens fine a while back. Someone must have synchronized it up with a wrong build a few months ago an its never gotten fixed.
    Either way, thanks cole...
    07-05-2012 10:46 AM
  14. sdxben's Avatar
    Has anyone tried to put Google Now on this ROM yet?
    Instructions can be found here on xda-developers - View Single Post - The Google Now for ICS Project. [UPDATE 7/5][NO VOICE][APK AND ZIP] XDA.
    07-05-2012 10:48 AM
  15. willmon22's Avatar
    I am wondering about the deep sleep feature on this rom. Will it be kept off as it seems to help greatly when tethering it. All that has happened on other roms is that it just kept going into a deep sleep mode and the phone wouldn't respond like it was off. And I always had to take the battery out and put it back in.
    07-05-2012 10:55 AM
  16. inceyet's Avatar
    I use es file explorer
    07-05-2012 11:24 AM
  17. chuckconnors's Avatar
    Just checked again and I do not see any Camera related options in the Sound menu of CM9 nightly 7-02
    The phone tried to update a handful of apps and they all came back as invalid packages. Any idea on what I can do to fix this? I was able to get mxplayer to install after getting invalid package by trying it over and over again. Really curious why it works sometimes and not others.
    07-05-2012 11:45 AM
  18. tdm's Avatar
    I just discovered that AOKP doesn't have Apollo (or any other music player) by default, and Apollo isn't available in Market. Any suggestions for a music player that works, well, about like the default Android music player (i.e., Apollo)? Or how to acquire Apollo?
    Last I checked, most of the fully-featured players (e.g., Winamp et al) are overloaded with extra junk I won't need (including but not limited to ads, annoying trial periods, or crippleware), and DeadBeef is as bad on Android as it is my laptop (nonstandard commands and impractical issues with playlists).
    I downloaded an official AOKP build (for the p990) and, as strange as it may seem, it appears they don't include a music player. I found the commit in github that removed it, so it was intentional. Also found this thread which verifies that this is intentional.
    I could build one, but space is tight already (I had to remove SwagPapers to make room for gapps, which made me sad -- it ruins part of the AOKP experience). Better to install your own preferred player so that it doesn't eat more space in /system.
    inceyet and poweredge99 like this.
    07-05-2012 12:15 PM
  19. ilikechicken123's Avatar
    why does only a small portion of a picture fit as the wallpaper on ics? Even with no scroll.
    07-05-2012 12:30 PM
  20. ItsMoo's Avatar
    HUGE lock screen issue; after changing the lockscreen style under ROM settings, I had NO lockscreen for over an hour, even after I wiped cache and reflashed. it just came back after I somehow got passed the blank lock screen by pressing the weather from the notification drop down and switching to one of the other styles...very weird.
    07-05-2012 12:53 PM
  21. inceyet's Avatar
    Double Twist is a dope music player that's what I got works great.also tdm I've been getting random reboots and I have a partion set up at 512 ext and 64om on my 16g card any thoughts again great work bruh
    07-05-2012 01:08 PM
  22. plantucha's Avatar
    QUOTE=sdxben;1926526]Has anyone tried to put Google Now on this ROM yet?
    Instructions can be found here on xda-developers - View Single Post - The Google Now for ICS Project. [UPDATE 7/5][NO VOICE][APK AND ZIP] XDA.[/QUOTE]
    No voice search. It knows where i work. It knows weather. That's it. Maybe next version
    07-05-2012 03:22 PM
  23. medina623's Avatar
    for aokp I was using double twist player, bit then I found a good music player, same as Apollo but wont show the album covers
    07-05-2012 03:35 PM
  24. medina623's Avatar
    if you guys want to try out this music player
    theboyshort likes this.
    07-05-2012 03:39 PM
  25. rwcordell's Avatar
    I'm getting lots of random reboots too.
    For now I under-clocked to 480MHz and the freezing has stopped.
    Even at that speed It runs smoothly for most things. Thanks for all the hard work!
    tdm likes this.
    07-05-2012 03:43 PM
2,975 ... 45678 ...
