- Forum
- LG Android Phones
- More LG Phones
- LG Optimus Series
- Virgin Mobile Optimus V
- Optimus V Rooting, ROMs, and Hacks
[ROM][BETA] Quattrimus ICS
- I'm currently on the beta1 aokp. I remember using a screen filter on an alpha build. It allowed you to edit screen colors to save battery file.
Settings > Display > Custom Backlight Settings > Edit Other Levels...
When I try to go to this it says "Unfortunately, Settings has stopped."
Is there a way to fix it or an alternative?
Sent from my LG-VM670 using Android Central Forums07-28-2012 03:06 PMLike 0 - Yo go to the stickies how to root your phone is in there plus Cole gave you the link ....:banghead: again do not open any files at all ....I HIGHLY recommend you read that tread 1 before you do a thing to you phone or you can brick it ....also start off with a iho first as I said before.... you have been warned good luck
Edit: page 144 is the link
Sent from my LG-VM670 using Android Central Forumscoolbryan22 likes this.07-28-2012 03:16 PMLike 1 - I'm currently on the beta1 aokp. I remember using a screen filter on an alpha build. It allowed you to edit screen colors to save battery file.
Sent from my LG-VM670 using Android Central Forumsinceyet likes this.07-28-2012 03:24 PMLike 1 -
- I flashed oakp. When i try to make a call it wont work. it says "call has been lost" every time, any ideas? Might as well tell you all my problems. I was running cm9. I partitioned my sd and phone would not reboot. stuck at boot ani. I removed the sd card during boot and it worked. every time i reboot i must pull out the sd or it sticks on boot ani. Swithched to aokp. same issue will not boot up with a partioned sd inserted. phone will not make calls either as i already stated. help! -ls670 cannibal recovery.07-28-2012 04:19 PMLike 0
- Has anyone gotten a Google Play store error? I flashed the cm9 beta and then the aokp, tried using both the slim and full gapps-ics-20120429. I've also made a sd-ext with and without swap space, wiped everything including dalvik cache. I also have my phone's esn, meid, and mdn zeroed out for wifi only use, Im not sure if that has anything to do with it.07-28-2012 08:54 PMLike 0
- Quick question if the devs are working on jb is there going to be a new thread or the same
Song: Understanding
Band: Evanescence
07-28-2012 09:23 PMLike 0 - Has anyone gotten a Google Play store error? I flashed the cm9 beta and then the aokp, tried using both the slim and full gapps-ics-20120429. I've also made a sd-ext with and without swap space, wiped everything including dalvik cache. I also have my phone's esn, meid, and mdn zeroed out for wifi only use, Im not sure if that has anything to do with it.
Sent from my LG-VM670 using Tapatalk 207-28-2012 09:37 PMLike 0 - I'm having a problem actually. My last rom was iho backside 7.2 cm7. And I was losing connection and going to 1x on backside and now I'm losing it on quattrimus, I really like this rom and I'd love to be able to fix this.
Thanks-
Brandon07-28-2012 09:55 PMLike 0 -
- My signal never did this before and my brother has an ov too, his doesn't do that. But he's still on backside also.07-28-2012 09:59 PMLike 0
- Sorry to bother you again, but when I start losing connection and have to cycle through airplane mode, it shows the one arrow pointing up and I can't use data unless I reboot or airplane.
Sent from my LG-VM670 using Android Central Forums07-28-2012 10:18 PMLike 0 - Tried it with both nightly and beta of cm9 and aokp. Even checked MD5 and they were correct. I'll just use a different rom.07-28-2012 10:59 PMLike 0
- Would anyone know why this thing keeps restarting on me (No overclocking, before it restarted I checked and the processor is all stocked)..I've tried just about everything, this is on the cm9 version, I'm going to give the akop version a try, it worked fine on my phone. Just keeps restarting on my wifes07-29-2012 02:42 AMLike 0
Sent from my LG-VM670 using Tapatalk 207-29-2012 02:46 AMLike 0 -
I'm curious about this too - I used night mode all the time on IHO (easier on my eyes), but I haven't found a way to get something like that working on AOKP yet.
Sent from my LG-VM670 using Android Central Forums07-29-2012 05:07 AMLike 0
- Forum
- LG Android Phones
- More LG Phones
- LG Optimus Series
