01-05-2016 05:35 PM
2,975 ... 6465666768 ...
tools
  1. ThatGuyLurkin's Avatar
    Lol. My time is stuck at 3:58?
    Also, what are you Guy's overclock? I get nothing but freezes. Am ready to break my phone...
    08-01-2012 04:06 AM
  2. strabo231's Avatar
    And to restore all the data on the card I just connect via USB and copy the files back over?
    You can actually do the entire thing in recovery. Just mount usb storage, copy the files to pc, unmount and format/partition, remount, copy files over to sd, then unmount and reboot.
    08-01-2012 04:07 AM
  3. strabo231's Avatar
    Ive had that problem since like alpha 7 or 8. Could never OC. Finally got 480/806 on Performance to work. Had like 2 reboots in the last 5 or 6 days. Time I'm not sure about though.
    08-01-2012 04:09 AM
  4. nitestalkr's Avatar
    @tdm, slight new bug in AOKP 7/31.
    Notification drop down drawer gets stuck on landscape, while in portrait.
    sent from my un-dead sammich.
    tdm likes this.
    08-01-2012 04:11 AM
  5. jlkiller893's Avatar
    Did they fix the text msg vibrate function? i tested it on : 9-20120619-UNOFFICIAL-LS670 and when i recieved a text msg it wouldnt vibrate. Any fix yet?
    08-01-2012 05:01 AM
  6. ThatGuyLurkin's Avatar
    Enable Vibrate in Message settings. It was never broken...
    Correct me if I'm wrong.
    08-01-2012 05:37 AM
  7. anthonycr's Avatar
    Nope never broken. All notifications are just default set to not virbrate.
    08-01-2012 06:30 AM
  8. xpbryan101's Avatar
    My phone restarts a lot when it's off wifi, anyone know how to fix this?
    08-01-2012 07:39 AM
  9. jayleekay's Avatar
    I must just be one of the lucky ones. Cm9 has been running flawlessly for a long time. Only reboots i've ever had were from the bt toggle. Go me!
    08-01-2012 07:42 AM
  10. nitestalkr's Avatar
    Change your governor to savagedzen and your clock settings to 480min 600+Max.
    08-01-2012 08:19 AM
  11. dlewis8176's Avatar
    Start by reading this guide: http://forums.androidcentral.com/opt...ustom-rom.html
    You can also scroll back a few days in this thread; a guy who was asking beginners-type questions was given a number of suggestions and links by several posters.
    "Mirrors" = the same file, available at several different web addresses in case there is some problem with downloading from the primary source. You only need to download the ROM and the gapps files once; it doesn't matter if you get them from the main source or one of the mirrors.
    Ok thanks I got it to work I'm all good now!!!
    08-01-2012 09:19 AM
  12. tdm's Avatar
    Click to view quoted image
    Can someone verify this is or isn't a problem? I didn't see any changes for 7/31 except my kernel fix.
    08-01-2012 09:23 AM
  13. benslgdroid's Avatar
    Its something that came up a while back with mine. A simple reboot fixed it.
    tdm and vm_760 like this.
    08-01-2012 09:51 AM
  14. andrewnelson23's Avatar
    I just discovered my phone is BEAST. decided to experiment with OC. Currently I'm stable at 825/864. Bumping it up right now to 844/864, and somehow, I don't think it's gonna be a problem. WIN.
    08-01-2012 10:13 AM
  15. jlkiller893's Avatar
    Thanks guys it works fine now noticed it had settings and figured it out this morning
    Cheers
    08-01-2012 10:54 AM
  16. tdm's Avatar
    There isn't likely to be much change to the code in the next couple of weeks. I'm busy with ICS bringup on my Marquee, which will be followed by my Slider. The ICS code in both CM and AOKP isn't changing much at all recently, as both are working on JB now.
    So, any objections to promoting the 7/31 build to beta2? Are there any regressions or issues that weren't present in beta1?
    08-01-2012 10:59 AM
  17. andrewnelson23's Avatar
    Dooooo ittttt
    08-01-2012 11:13 AM
  18. inceyet's Avatar
    Are you kidding me tdm you a beast bruh I'm on the 7/31aokp :thumbup::thumbup: got my vote on beta 2 haven't messed with oc yet aside 600/480 standard but hands down top rom and has been my daily
    tdm likes this.
    08-01-2012 11:58 AM
  19. nitestalkr's Avatar
    Yea, that bug I reported is apparently a VERY rare bug, so it's not that big of a deal, just a UI restart, and its fixed.
    I say a promotion is needed, and I'd suggest only updating if you personally have something to add to the ROM, or if there's any changes to CM9 and AOKP.
    08-01-2012 02:56 PM
  20. jto101680's Avatar
    Benn running aokp for a week or so. Finally did thw partition and it made things run much smoother. Id say a definite beta 2 rom. Ive followed this since the very first release and its come so far it's amazing. A true tribute to your work tdm. However, I feel to go beta 3 or whatever, the new kernel has got to work. Getting that kernel working could be the single biggest upgrade the optimus has ever had. It will force other dev to turn the corner, leaving GB behind, and moving further in to 4.? :thumbup:
    Edit: no pressure by the way
    andrewnelson23 and tdm like this.
    08-01-2012 04:21 PM
  21. nitestalkr's Avatar
    ^+1 all the way!!
    Once that kernel is fully functional, it will most likely extend development for the into the next android milestone(kit-kat? ).
    Our little Optimi have already come a long way, lets push it to the Max!
    08-01-2012 05:44 PM
  22. kobequintana's Avatar
    ^+1 all the way!!
    Rock on nitestalker rock on
    08-01-2012 05:58 PM
  23. nitestalkr's Avatar
    Funny thing is, I currently am rocking out xD
    Warming up/practicing on my vocals.
    08-01-2012 06:00 PM
  24. kobequintana's Avatar
    Lol
    08-01-2012 06:32 PM
  25. nitestalkr's Avatar
    Been testing out battery life with low to moderate use on AOKP, and I'm impressed so far.
    I took my phone off the charger after a full charge at 12am (GMT +7hours Arizona) and it is now at 20% and its 4:55pm (GMT +7hours Arizona) which means, it has been running for ~17hours, with ~4hours of music playback, tapatalk for a total of ~3-5 hours, web surfing on WiFi for ~1-2 hours.
    I wish the battery stats issue was fixed so i could show proof... it says its only been off the charger for 6 hours lol.
    08-01-2012 08:00 PM
