01-05-2016 05:35 PM
2,975 ... 6667686970 ...
tools
  1. emburybrett1's Avatar
    Wipe cache and dalvik cache, and reflash the rom.
    The SD-ext script will take effect after reflashing.
    sent from my un-dead sammich.
    No need to wipe data? Also any work around for overclocking? Every time I try the phone reboots even at only 729 MHz. Sorry for asking so much just alot has changed since I last used this phone in August 2011.
    This rom has the best battery life out there!
    08-02-2012 11:39 AM
  2. nitestalkr's Avatar
    Correct, no need to wipe data.
    Try 729max 600min on savagedzen.
    You just gotta spend a lil trial and error messing with several combinations to find what works best for your phone.
    08-02-2012 12:06 PM
  3. jensonco's Avatar
    I just saw my LG Optimus V roaming in a low-signal area. Is that actually possible with this ROM?
    08-02-2012 12:06 PM
  4. cole2kb's Avatar
    Not sure why you saw what you saw, but no, it's not possible, with this or any other ROM.
    08-02-2012 12:08 PM
  5. jensonco's Avatar
    Also...check this out, lol. 179 MB of space but I can hold 322 MB, lol. This must be do to the sd-ext, I assume?
    08-02-2012 12:09 PM
  6. jensonco's Avatar
    I'll take a screenshot next time. It was odd, lol.
    08-02-2012 12:12 PM
  7. nitestalkr's Avatar
    Yea, Virgin Mobile doesn't allow Roaming at all, yet you're not the first to report momentarily roaming.
    I've read here, and in other Android forums of Virgin Mobile users, typically with the Optimus V, have experienced several cases of Roaming, with a wide variety of several Roms.
    08-02-2012 12:24 PM
  8. emburybrett1's Avatar
    If you ask me they should let us roam like sprint. Hell i would even pay $10 to $20 more then i do now for the roaming like sprint does so i could use the phone in more places.
    08-02-2012 12:44 PM
  9. emburybrett1's Avatar
    Thanks and i think the issue was that it was still on InteractiveX I changed it to proformance it can overclock just fine now.
    08-02-2012 01:37 PM
  10. Rudeco's Avatar
    So is the AOKP 31st version the only one going beta 2, or is cm9 31st going as well? Also, when is it and can I just download the 31st file now or will the beta 2 release differ from it in any way?
    08-02-2012 02:17 PM
  11. kobequintana's Avatar
    I am so tired I was up all night playing with aokp
    08-02-2012 03:43 PM
  12. nitestalkr's Avatar
    Both will be beta2, and I believe every build after including 7/13 will be considered beta 2
    08-02-2012 04:09 PM
  13. zeldalink14's Avatar
    First off i LOVE this AOKP ROM. By far the best I've had on my phone to date. I wanted to flash the new nightly but the main link is broken. Anyone else running into this issue?
    08-02-2012 04:36 PM
  14. Ryuk6666's Avatar
    Hey tdm, I think the system is reading sdcard free memory wrong, because I should still have around 5gb left. Not 1.5....
    Click to view quoted image
    Sent from my Quattrimized AOKP OV.
    Sent from my A.C.R. Zombified Quattrimized AOKP OV.
    08-02-2012 05:34 PM
  15. kobequintana's Avatar
    While I'm in GB what are the files for the hot spot
    Edit: Nvm I'm back with Quttrimas because the home button didn't work and I got stuck in the browser after changing my theme
    08-02-2012 06:26 PM
  16. strabo231's Avatar
    You guys ever see that post leslieanne put up about them supposedly implementing roaming? Think it said it was supposed to have been July 1
    08-02-2012 06:34 PM
  17. kobequintana's Avatar
    Any idea of what a wrong with the aokp youtube
    Song of the week:
    Song: End Of The Dream
    Band: Evanescence
    Album: Evanescence
    08-02-2012 06:53 PM
  18. daddy4life09's Avatar
    So still no youtube fix for aokp?I just find it hard to beleave that after all this time noone has figured this out.....
    08-02-2012 07:03 PM
  19. LG_VM670's Avatar
    Can't we just get the thing that messed up out of aokp and import the one from CM9
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    08-02-2012 07:19 PM
  20. anthonycr's Avatar
    Yeah but that was only a rumor spread by an uninformed public relations individual.
    nitestalkr likes this.
    08-02-2012 07:26 PM
  21. emburybrett1's Avatar
    what now i keep getting no space left for anything i did 512MB and in setting it says i have used 212MB from the 179 MB so i know it is somewhat working but no space for a 2.12 MB file...?
    08-02-2012 07:53 PM
  22. LG_VM670's Avatar
    Try making your SD ext bigger
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    08-02-2012 07:56 PM
  23. strabo231's Avatar
    Ahh I gotcha. Shocker!
    08-02-2012 08:14 PM
  24. kboone13's Avatar
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    I was thinking this myself. But apparently it doesn't work after flashing gapps. Maybe it would work if tdm himself took the lib files and whatever else is responsible from cm9 and put them in aokp, then we could just flash it
    08-02-2012 08:51 PM
  25. LG_VM670's Avatar
    Possibly
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    08-02-2012 09:34 PM
