01-05-2016 05:35 PM
2,975 ... 6768697071 ...
tools
  1. tdm's Avatar
    Been fighting with 3g on my marquee, finally won today. I'll try to get beta2 promoted tomorrow and look at one or two other things.
    08-02-2012 10:04 PM
  2. sellers86's Avatar
    you got 3g on the marquee? nice. I may have to take up asadullahs offer...
    08-02-2012 10:06 PM
  3. ganggreen30's Avatar
    why cant i download the latest nightly it just give me beta 1 zip. when i try for primary page it gives a page error?
    08-02-2012 10:09 PM
  4. sellers86's Avatar
    it should be in the directory nightlies/VM670
    08-02-2012 10:13 PM
  5. ganggreen30's Avatar
    could u post me a link. or just give me a url please
    08-02-2012 10:14 PM
  6. ganggreen30's Avatar
    i got it neverming it is the july 31 one right
    08-02-2012 10:17 PM
  7. LG_VM670's Avatar
    http://getquattrimus.com/roms/quattrimus/nightly/VM670/
    Here you go
    Song of the week:
    Song: End Of The Dream
    Band: Evanescence
    Album: Evanescence
    ganggreen30 and tdm like this.
    08-02-2012 10:19 PM
  8. tdm's Avatar
    I did. It's kind of a hack right now and doesn't switch back from wifi well yet, but it does work.
    Next is the cameras, and then it should be close to what you folks have been enjoying for several weeks.
    08-02-2012 10:40 PM
  9. tdm's Avatar
    Not sure how long I'll have the marquee though. I am eyeing the spectrum now....
    08-02-2012 10:46 PM
  10. LG_VM670's Avatar
    Quick stupid? If something's compatible for the O1(optumus1) is it compatible with the OV
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    08-02-2012 10:49 PM
  11. tdm's Avatar
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    The OV is part of the O1 family.
    LG_VM670 likes this.
    08-02-2012 10:54 PM
  12. LG_VM670's Avatar
    OK thank you
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    08-02-2012 10:55 PM
  13. ganggreen30's Avatar
    quick question im partitioning my sd card i picked 1024 then it asked me swap size after what is that should i choose 0M 32M or128M or what thanks
    08-02-2012 11:00 PM
  14. LG_VM670's Avatar
    I chose 32 but its up to
    Song of the week:
    Band: Evanescence
    Album: Evanescence
    08-02-2012 11:05 PM
  15. tdm's Avatar
    Zero. Or the smallest number available.
    08-02-2012 11:10 PM
  16. ThatGuyLurkin's Avatar
    Hey TDM. The latest Beta, do you plan on updating?
    Also, AOSP?
    Sent from my VM670 using Tapatalk 2
    08-02-2012 11:12 PM
  17. droidmike_k's Avatar
    That is fantastic! I've been eyeing getting a Marquee, but lack of decent roms has been holding me back.
    Quattrimus is a great ROM, btw. I'm still on Reborn, and I would love to use Quattriumus as my daily driver. The only thing holding me back is the mic on my headset not working. Would that be one of the things you plan on looking at?
    tdm likes this.
    08-02-2012 11:27 PM
  18. sellers86's Avatar
    If you want, I can dig up the build.prop fix from CAI and give you a link. See if it works on the marquee.
    tdm likes this.
    08-02-2012 11:31 PM
  19. tdm's Avatar
    Yes I'll update the beta.
    I might look at the headset issue but I'll need to dig out a wired headset.
    Yes aosp is still coming, and the kernel.
    Please do dig up the fix, thanks.
    08-02-2012 11:52 PM
  20. jto101680's Avatar
    Yessssss.... the kernel
    08-03-2012 12:04 AM
  21. kboone13's Avatar
    08-03-2012 01:21 AM
  22. ThatGuyLurkin's Avatar
    TDM.Simplydev is down?
    I'm going to flash again and hope I get no reboots. :o
    08-03-2012 01:32 AM
  23. benslgdroid's Avatar
    Just as I should be getting my new phone. I'll still find a way to mess around with it.
    08-03-2012 01:38 AM
  24. sellers86's Avatar
    I found the fix, but I also checked the marquee build.prop. The fix is already included, so its not the answer... sorry.
    tdm likes this.
    08-03-2012 02:38 AM
  25. LG_VM670's Avatar
    Could the new kernal possibly fix the wifi hotspot problem
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    08-03-2012 02:56 AM
