01-05-2016 05:35 PM
2,975 ... 6970717273 ...
tools
  1. jetfactor's Avatar
    just want to say... tdm you're awesome, and I have been spoiled running your build of ICS on my OV. however... I just got an HTC one and am doing the switch. not much development on it at the moment, but ohh well.
    i'll definitely be popping back in from time to time... just cuz I don't have service on my OV doesn't mean I can't flash any new sweet build you come up with!
    -sent from space.
    tdm likes this.
    08-04-2012 02:19 AM
  2. topdawg661's Avatar
    Links down??
    08-04-2012 02:33 AM
  3. tdm's Avatar
    Links down??
    Which links? Try getquattrimus.com
    topdawg661 likes this.
    08-04-2012 02:44 AM
  4. topdawg661's Avatar
    The one that says primary? But that worked! I'm trying out aokp again. But so far I've loved your rom great job(:
    tdm likes this.
    08-04-2012 02:56 AM
  5. clodfelterac's Avatar
    08-04-2012 03:20 AM
  6. drm1992's Avatar
    I see a beta 2 does that mean we have to do a full wipe or just do a dirty flash?
    08-04-2012 04:29 AM
  7. strabo231's Avatar
    Beta 2 is just the July 31st nightly so if you already flashed that you don't need to do anything else.
    tdm likes this.
    08-04-2012 04:41 AM
  8. vm_760's Avatar
    im only at 748MHz any more power and the phone will power off the sec i click it.
    Try running 480/806 savagedzen governor ...seems to work for alot of people. Also remember not all OV's are created equal.
    Sent from my twice fried OV using Quattrimus for life support!
    08-04-2012 05:33 AM
  9. bennettg's Avatar
    Tdm,
    Do you need volunteers to test your 3.0 kernel?
    08-04-2012 10:01 AM
  10. tdm's Avatar
    Tdm,
    No but thanks. And it won't be ready for a while yet.
    nitestalkr likes this.
    08-04-2012 10:18 AM
  11. ThatGuyLurkin's Avatar
    Although most were not created equal, ICS seems to have different performance in overclocking. It's like the ZV9 update nightmare again.
    08-04-2012 10:56 AM
  12. jensonco's Avatar
    Is Beta 2 more recent then the July 31st nightly?
    08-04-2012 12:19 PM
  13. coolbryan22's Avatar
    Beta 2 is the July 31st nightly. So no.
    08-04-2012 12:50 PM
  14. drm1992's Avatar
    OK thank you.
    08-04-2012 01:15 PM
  15. ThatGuyLurkin's Avatar
    1st link has been down for about 3 days or more. I forgot what it looks like. o_O
    08-04-2012 03:03 PM
  16. tdm's Avatar
    Links in the OP fixed. Sheesh, you guys are sooooo demanding.
    08-04-2012 04:37 PM
  17. ThatGuyLurkin's Avatar
    Lol. Sorry TDM.
    MMS seems broken for be in this. Im using Beta2.
    08-04-2012 05:15 PM
  18. anthonycr's Avatar
    WARNING: Don't feed the noobs trolls!!
    08-04-2012 05:30 PM
  19. kcls's Avatar
    While you're at it, you might want to change "Latest Release" to Beta2 instead of Beta1. Just a suggestion
    tdm likes this.
    08-04-2012 05:31 PM
  20. tdm's Avatar
    Obviously there's too many places where information needs updated. I thought about removing that from the OP but left it in for now.
    I think it took me over half an hour to fix everything up for beta2 yesterday. That's not acceptable either. I need to script the promote procedure.
    I also need to quit building 3 different ROMs for basically the same phone. I'll get the edify code for a unified ROM install going one of these days soon......
    benslgdroid likes this.
    08-04-2012 06:39 PM
  21. jto101680's Avatar
    Is there a good fix for the white screen bug (gmail, Facebook, browser)? I've used force gpu rendering and changed my screen density to 140. Its improved, but still happens. If I clear data and cache on browser it fixes for a minute or two. Any suggestions? Also, I'm using dolphin mini. I found its the best 3rd party browser for me on this rom (aokp).
    Optimus v with a little tap tap tappy
    08-04-2012 07:57 PM
  22. LG_VM670's Avatar
    I kill the app by holding the back button (must be activated in the settings under development) or clear the data
    Song Of The Week
    Song: End Of The Dream
    Band: Evanescence
    Album: Evanescence
    jto101680 likes this.
    08-04-2012 08:08 PM
  23. ThatGuyLurkin's Avatar
    When the browser happens, just exit it, open the recent apps, and swipe it away. That works for me.
    Gmail and Facebook, idk. Always had problems with Gmail.
    08-04-2012 08:09 PM
  24. nitestalkr's Avatar
    Always had issues with Facebook on ICS, then I started using a 3rd party app "3DF Black", and it worked a lot better.. but now I'm on Jelly Bean, and Facebook is a lot snappier and responsive without needing to be overclocked.
    sent from my un-dead sammich.
    08-04-2012 08:42 PM
  25. ThatGuyLurkin's Avatar
    Hey TDM. How would ome remove Offline Charging? o_O
    08-04-2012 09:21 PM
