01-05-2016 04:35 PM
2,975 ... 7071727374 ...
tools
  1. tdm's Avatar
    Hey TDM. How would ome remove Offline Charging? o_O
    You need to repack boot.img.
    Maybe I could cook up a build prop that disables it though.
    sellers86 and nitestalkr like this.
    08-04-2012 08:43 PM
  2. nitestalkr's Avatar
    Or make it so that the phone only enters offline charging if the battery percentage is below a certain point, like below 15%-20% from a powered off state.
    sent from my un-dead sammich.
    08-04-2012 09:09 PM
  3. jonny5449's Avatar
    What were the problems with aosp alpha 10????
    looking for good keyboards????
    visit my sight
    jonskeyboards.Wordpress.com more than 50 downloads in the first 2 hours
    08-04-2012 09:50 PM
  4. cpackar's Avatar
    I flashed this rom, and I go to install an app a few hours after using it and it says I have Insufficient storage.
    What do?
    08-05-2012 12:06 AM
  5. kcls's Avatar
    I actually have a problem with charging while powered off. On CM7, if the phone was off and charging, it would show the battery screen. When I hit the power button, while it was still on the charger, the phone would reboot, and boot up into android. On CM9, when I try to turn on the phone while its plugged in, it just reboot right back into the offline charging screen. In order to get it to boot into Android, I have to unplug the phone, turn it on, and then plug the phone back in. Is this a known issue?
    dzdzjb likes this.
    08-05-2012 12:09 AM
  6. tdm's Avatar
    Don't know offhand why that would be.
    08-05-2012 12:27 AM
  7. plantucha's Avatar
    Not good if you will need alarm on. I had some reboot while on charger when I was sleeping . Offline charging = no alarm. I do have backup alarm, so no big problem for me, but generally better idea is online charging automatically .
    08-05-2012 01:25 AM
  8. ThatGuyLurkin's Avatar
    With that said! I meant to ask:
    How would one remove Offline Charging? I deleted files that said bootinages and charger animations to be greeted with a LG loop. I battery pulled and it booted back up and the file were back.
    08-05-2012 01:53 AM
  9. benslgdroid's Avatar
    Something in the boot sequence is seeing those missing and rewriting them. What that is or how to stop that is out of my range.
    08-05-2012 01:56 AM
  10. nitestalkr's Avatar
    And the only dev that I can think of that fixed the offline charging to only charge when below a certain percent, was JerryScript, but it seems he'd opt'd out, for good..
    08-05-2012 02:08 AM
  11. sellers86's Avatar
    Offline charging is a bit buggy in ics roms, and always has been for me.
    08-05-2012 03:43 AM
  12. sellers86's Avatar
    Tdm got offline charging working right on iho if I remember correctly.
    a5pe4 likes this.
    08-05-2012 03:44 AM
  13. emburybrett1's Avatar
    I forget who said their phone said it was roaming but mine did to while I hit a dead zone out of town trying to load weatherbug.
    When "roaming" its they same as searching for signal no calls no data.
    08-05-2012 07:49 AM
  14. tdm's Avatar
    If you have to ask, you probably shouldn't be doing it.
    Unpack boot.img, remove the line that execs chargerlogo in init.rc, repack, and flash with flash_image.
    sellers86 and ThatGuyLurkin like this.
    08-05-2012 09:14 AM
  15. moosemauler's Avatar
    This is my first time posting to this forum because Ive never had a problem with the Quattrimus CM9 ROM. Great job TDM, it works great. Smoother than any CM7 ROM Ive used(IHO, Mirage, Harmonia, etc.) I have been running it since it became Beta.
    The only problem Im having is that I cant assign custom ringtones to individual contacts in my Contacts list. Ive tried setting up individual ringtones with Google Contacts and Go Contacts.
    When I assign a custom ringtone to an individual in the Contacts list it shows the custom ringtone that I chose, but when I get an incoming call from that person the phone always rings with the Default ringtone. Has anyone else had a similar problem. Ive read this entire thread and I see no reference to this situation.
    Any help would be greatly appreciated.
    tdm likes this.
    08-05-2012 11:37 AM
  16. sellers86's Avatar
    No offense tdm, but I hate this answer. I appreciate that you went ahead and explained it, but how are people supposed to learn without asking? Just doesn't make sense.
    bhasden likes this.
    08-05-2012 01:27 PM
  17. flapjack.fiasco's Avatar
    If he had added "... without doing a lot more reading first." It's true though, there's a lot of stuff that your average user shouldn't be trying, at least until they've done a lot more reading on the subject. But we should try to point them in the right direction, as tdm did.
    sellers86 likes this.
    08-05-2012 02:00 PM
  18. tdm's Avatar
    I'm not against learning. But it takes initiative and research to make these changes. Without these, you're going to get stuck and/or be asking a continuous stream of questions. A few google searches or looking through my github would easily turn up the required changes, so anyone asking is not taking much initiative. No offense, but I'm not much of a dev tutor -- few are.
    08-05-2012 02:01 PM
  19. emburybrett1's Avatar
    Any one having issues with apple mail? (@me.com)? Keeps telling me that it couldnt sign in anymore. It is working fine on my ipad but just is kinda bugging me that it keeps poping up.... Should I just remove the Whole email and add it again?
    08-05-2012 02:25 PM
  20. sellers86's Avatar
    Alright. I only ask you or anyone questions if a Google search returns nothing. Just my two cents and I appreciate all the work you and every other devs do.
    08-05-2012 02:30 PM
  21. HurrrDurrrDURP's Avatar
    Oh hai, I haven't read this thread in awhile... can someone PM me or post a quick status update on quattrimus? ty :3
    08-05-2012 03:38 PM
  22. sellers86's Avatar
    Beta 2 released, Bluetooth reboots fixed.
    HurrrDurrrDURP likes this.
    08-05-2012 03:47 PM
  23. ThatGuyLurkin's Avatar
    I don't understand how to unpack a boot.img, I never understood the instructions. I've read 4+ threads
    08-05-2012 04:03 PM
  24. HurrrDurrrDURP's Avatar
    So all thats really broken now is hot spot and random reboots? Nice!
    Also I would like to say that Bluetooth tethering works!
    08-05-2012 04:04 PM
  25. ThatGuyLurkin's Avatar
    I'm wondering, is Deep Sleep back?
    08-05-2012 04:32 PM
