01-05-2016 04:35 PM
2,975 ... 7172737475 ...
tools
  1. nitestalkr's Avatar
    I'm wondering, is Deep Sleep back?
    AFAIK, deep sleep is working in AOKP, and I think in CM9 as well.
    Someone correct me if I'm wrong.
    sent from my un-dead sammich.
    08-05-2012 04:50 PM
  2. LG_VM670's Avatar
    What is deep sleep?
    Song Of The Week
    Song: End Of The Dream
    Band: Evanescence
    Album: Evanescence
    08-05-2012 04:51 PM
  3. kirurus's Avatar
    beta 2 is liquid smooth. props tdm!
    tdm likes this.
    08-05-2012 05:04 PM
  4. nitestalkr's Avatar
    What is deep sleep?
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    Its when the phone turns its display off, and after x amount of time, it enters a state of "deep sleep" that uses a lot less battery power, and turns off certain functions (only while in such a state) that aren't needed to perform very basic service functions.
    Think of it like this; if you were barely asleep, you're heart is still beating at a normal rate, and thus continuing to burn energy, and may wake up hungry.
    Whereas, if you're out cold, or in a very deep sleep, your heart rate, along with other bodily functions, slow down, and in turn, your body uses less energy, and will wake up energized and ready to continue your day.
    08-05-2012 05:25 PM
  5. flapjack.fiasco's Avatar
    What is deep sleep?
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    Deep sleep is what your phone does after it hasn't been used for a bit, in order to conserve battery life.
    08-05-2012 05:25 PM
  6. kobequintana's Avatar
    Wow beta 2 already cool great job tdm
    tdm likes this.
    08-05-2012 05:32 PM
  7. bh0's Avatar
    Does anyone else's clock get out of sync? Seems like it only updates after 10-20 seconds after I unlock the phone.
    08-05-2012 07:58 PM
  8. Conrail16's Avatar
    This is a known bug with no known fix.
    08-05-2012 08:20 PM
  9. sellers86's Avatar
    There is a fix, its been explained multiple times. Download clock sync from the market, go into its settings and change refresh rate to 30 seconds and check strict intervals.
    ThatGuyLurkin and laceous like this.
    08-05-2012 08:39 PM
  10. ThatGuyLurkin's Avatar
    Wouldn't that kill battery more?
    I hide lock on status bar anyways :P
    08-05-2012 09:07 PM
  11. robwalters72's Avatar
    Alright. I only ask you or anyone questions if a Google search returns nothing. Just my two cents and I appreciate all the work you and every other devs do.
    Hey,
    I am learning too, so I added you on facebook just now. Feel free to ask me and if I know, I'll be glad to help.
    Rob
    08-05-2012 09:42 PM
  12. robwalters72's Avatar
    Deep sleep is working on AOKP beta 2. Over 70% of my uptime is deep sleep now.
    Rob
    08-05-2012 09:44 PM
  13. drew_t's Avatar
    I get "Unfortunately, Clock has stopped" error messages on the initial unlock after rebooting, when I tap on the face of the clock, and when I go into the clock app and try to set an alarm. Is this related to the sync issue, or something else? (I've just installed that ClockSync app and set it as instructed, but I'm still getting the error message.) CM9 Beta 2 (working very nicely other than this).
    08-05-2012 09:46 PM
  14. tdm's Avatar
    That is a sign of a dirty flash. Clear clock data. If you have other issues, do a full wipe in recovery.
    drew_t likes this.
    08-05-2012 11:23 PM
  15. tdm's Avatar
    Got the multi device ROM setup penciled out. Should have something working this week.
    08-05-2012 11:25 PM
  16. sellers86's Avatar
    Hey,
    Rob
    Feel free to ask me anything. I read everything here and if there is a fix for something I probably know it.
    robwalters72 likes this.
    08-05-2012 11:30 PM
  17. sellers86's Avatar
    I notice no battery drain
    ThatGuyLurkin likes this.
    08-05-2012 11:30 PM
  18. kobequintana's Avatar
    Where is systemUI.apk located
    08-05-2012 11:43 PM
  19. sellers86's Avatar
    system/app
    08-05-2012 11:45 PM
  20. ThatGuyLurkin's Avatar
    System/App
    08-05-2012 11:45 PM
  21. nitestalkr's Avatar
    It should be in:
    /system/app
    sent from my Zom-"Bean"(AOSP JellyBean).
    08-05-2012 11:59 PM
  22. varockchick's Avatar
    Not good if you will need alarm on. I had some reboot while on charger when I was sleeping . Offline charging = no alarm. I do have backup alarm, so no big problem for me, but generally better idea is online charging automatically .
    If my phone randomly reboots while on the charger it just goes to the charging screen to....i too have to unplug it to get it to boot
    08-06-2012 12:36 AM
  23. kobequintana's Avatar
    What's the best app to edit things inside an AOL
    08-06-2012 12:41 AM
  24. rmwutr's Avatar
    First time posting, to thank tdm for the awesome ROM.
    Still reboots when I try to do certain things like change settings but beta 2 is much much better than beta1 and nightlies for me. Thanks a lot for the insane work
    tdm likes this.
    08-06-2012 12:47 AM
  25. kboone13's Avatar
    So all thats really broken now is hot spot and random reboots? Nice!
    Also I would like to say that Bluetooth tethering works!
    And the youtube "slideshow" bug is still there
    this rom will be PERFECT once those 3 things get fixed. also, does anyone know why the date keeps randomly disappearing from my notification drop down box?
    EDIT: Scratch that last part. I guess you gotta have the weather enabled to have the date there too. The date will stick if you enable then disable, but only until you reboot.
    08-06-2012 01:05 AM
