01-05-2016 05:35 PM
2,975 ... 7273747576 ...
tools
  1. emburybrett1's Avatar
    I haven't had any reboots as long as im not overclocked any faster then 748MHz on Performance.
    08-06-2012 02:29 AM
  2. kobequintana's Avatar
    When I try to download a ROM from mediafire it completes but says it faild
    Song Of The Week
    Song: End Of The Dream
    Band: Evanescence
    Album: Evanescence
    08-06-2012 02:23 PM
  3. grosskum's Avatar
    In AOKP beta 2 when I hold power it reboots rather than power menu. I've rebooted, looked in settings, but can't find anything. It worked right when I downloaded beta2 but now it just reboots. Any workarounds or help?
    08-06-2012 03:29 PM
  4. ThatGuyLurkin's Avatar
    Try a reflash, if not, look into power widget settings. :/
    08-06-2012 03:47 PM
  5. ThatGuyLurkin's Avatar
    What's the best app to edit things inside an AOL
    What do you mean AOL?
    08-06-2012 03:48 PM
  6. kobequintana's Avatar
    Whoops lol it was auto correct I meant to say what a the best app to edit in an apk
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    08-06-2012 03:53 PM
  7. kcls's Avatar
    There really isn't an app to do this. The best way to edit an APK is to pull it from your phone to your computer, decompile it with apktool or apkmanager (I prefer apktool) make your edits and recompile and sign and push it back to your phone. For further questions, however, please start a new thread as this does not pertain to Quattrimus in the least.
    08-06-2012 04:26 PM
  8. samson lamadine's Avatar
    Hey is anyone else lock sound not working on cm9 beta2??
    08-06-2012 04:40 PM
  9. brotherswing's Avatar
    I have the lock sound, but there's a delay. Roughly two seconds after the screen goes dark I hear the click.
    sent from the hip.
    08-06-2012 05:13 PM
  10. ThatGuyLurkin's Avatar
    sent from the hip.
    Same here, but isnt that due to the screen off animation?
    08-06-2012 05:21 PM
  11. kobequintana's Avatar
    As so do i
    sent from the hip.
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    08-06-2012 06:04 PM
  12. bigsupersquid's Avatar
    just a note:
    Removing the NFC project (useless without the supporting hardware) from quattrimus cm9 with the local_manifest seemed to make a subjectively noticeable difference in overall response speed in everything but the lousy ics browser. Especially combined with removing the live wallpaper project.
    08-06-2012 07:58 PM
  13. brotherswing's Avatar
    Hey, I'll try that!
    sent from the hip.
    08-06-2012 08:03 PM
  14. jonny5449's Avatar
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    Are you on stock rom or downloading from 3g those could be the problems
    looking for good keyboards??
    visit
    jonskeyboards.com
    08-06-2012 08:44 PM
  15. kjmott's Avatar
    Does anyone with the battery charging problem know if this is fixed in beta 2?
    Wasn't sure what all was changed in beta2 but before I flash I thought I would check.
    For now I'm stuck with 7.2
    08-06-2012 09:36 PM
  16. nitestalkr's Avatar
    It wouldn't hurt to check it out yourself, I'm sure others that have that issue are staying away from Quattrimus till it is mentioned that its fixed. And the only people that can test this, would be the ones with that issue. So give it a shot, and report your findings.
    sent from my Zom-"Bean"(AOSP JellyBean).
    brotherswing likes this.
    08-06-2012 09:38 PM
  17. kobequintana's Avatar
    visit
    jonskeyboards.com
    I am using 3G and I'm on ics beta 2
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    08-06-2012 10:07 PM
  18. ganggreen30's Avatar
    TDM preferably or someone with know how please tell me how to spoof or change my Mac address please
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    08-06-2012 10:19 PM
  19. ganggreen30's Avatar
    No battery charging prob. Here.
    08-06-2012 10:20 PM
  20. ganggreen30's Avatar
    Is anyone using awesome beats on this from? I'm not sure its working cause it occasionally force closes
    08-06-2012 10:21 PM
  21. grosskum's Avatar
    How do you enable different media volumes for headsets in AOKP. In CM9, if I plugged in my headset my media volume would go from 0 to like 50%. I've looked in sound settings and can't find that option. Does it have to do with the dsp manager app that is included in CM9? Because I can't that dsp manager in the store.
    08-06-2012 10:24 PM
  22. nitestalkr's Avatar
    Awesome Beats is known to have force closing issues on several ARMv6 devices such as ours.
    08-06-2012 10:32 PM
  23. nitestalkr's Avatar
    AOKP uses MusicFX as its EQ, and as for volume levels, I believe its in ROM control, general UI or Sounds.
    Some setting saying "enable volume bar settings" or something llike the.. I'm on Jelly Bean right now, but I'll flash back to AOKP to give you the correct info.
    08-06-2012 10:39 PM
  24. ganggreen30's Avatar
    Your on jellybean? Which rom the alpha one
    08-06-2012 10:45 PM
  25. kobequintana's Avatar
    http://forums.androidcentral.com/sho...d.php?t=192291
    Here's the link to one of them its still in very early development but its smooth and fast
    Song Of The Week
    Band: Evanescence
    Album: Evanescence
    Zm9309z4z6 and nitestalkr like this.
    08-06-2012 10:50 PM
