01-05-2016 04:35 PM
2,975 ... 7475767778 ...
tools
  1. sellers86's Avatar
    Ouch man. That was kind of rude. Tdm made that. Speaking of which, tdm, out of like the 3 boot logos submitted, have you chosen one of them yet? Or are you still going to hold a poll for which one?
    Sent from my A.C.R. Zombified Quattrimized AOKP OV.
    I'm pretty sure I've seen tdm say it was ugly to
    08-07-2012 08:34 PM
  2. kappacat's Avatar
    @tdm--- heres my entry for the bootsplash contest... i left it in png... :-)
    the*
    08-07-2012 09:15 PM
  3. StingDrop's Avatar
    I was kinda thinking the same thing, cause MX player with ARMv6 VFP Codec plays perfectly fine, so if its possible to take the code from the ARMv6 VFP Codec, and implement it into the system, and have the GPU use it as its source video decryption, couldn't that fix the video issues indefinitely?
    sent from my Zom-"Bean"(AOSP Jellybean)
    Exactly what i was thinking too
    Sent from my LG-VM670 using Xparent ICS Tapatalk 2
    08-07-2012 09:16 PM
  4. JussCallMeUno's Avatar
    No offense juss my honest opinion
    08-07-2012 10:59 PM
  5. benslgdroid's Avatar
    Haven't updated to beta2 because I put my sd in my new phone but I found a small one and updated and its smooth like a cool beer :beer: lol. Now I can see about getting a new theme made. If you need testing for cm10, no service testing, I'd be more than willing. I also would like to get it to have some early cm10 themes done.
    tdm likes this.
    08-07-2012 11:51 PM
  6. nitestalkr's Avatar
    You can check out Zakmans CM10 port for the V here http://forums.androiddcentral.com/sh... for Optimus V.
    Its currently the only actual build for the V right now. MMS is working on it, but SMS is half working(should be fixed either today or tomorrow by Andrewnelson) and it should have a flashable sd-ext script(that I will be compiling sometime today).
    sent from my Zom-"Bean"(AOSP JellyBean).
    08-08-2012 09:53 AM
  7. kcls's Avatar
    Can anyone point me to the thread or provide the best way to get rid of the "Out of space" errors? I still have 80mb of internal storage left, but when I went to update Nova Launcher today (via direct APK, not play store) it told me I was out of space. I know on CM7 it was as easy as running the Market Fix app, but I'm not sure if it's the same on Quattrimus. I know others have had this issue, but unfortunately I'm on tapatalk so I can't currently search the thread, but I will later when I get home if no one can provide an answer. I'm on CM9, using an older (July 25th or so?) Nightly. Thanks for any help!
    08-08-2012 12:29 PM
  8. kirurus's Avatar
    Anyone else having issues streaming Pandora over 3G on beta 2?
    08-08-2012 01:18 PM
  9. sellers86's Avatar
    try wiping cache and dalvik cache in recovery
    kcls likes this.
    08-08-2012 01:19 PM
  10. strabo231's Avatar
    Have an sd ext? Top link in my signature edit: didn't notice you were on tapatalk the first time I read that. Here's the link http://forums.androidcentral.com/showthread.php?t=193297
    Everything SD Cards - Discussion and How to
    08-08-2012 01:53 PM
  11. Ryuk6666's Avatar
    What kind of problems?
    08-08-2012 03:05 PM
  12. kirurus's Avatar
    Songs won't buffer. They just load, then skip. Works fine on WiFi though.
    08-08-2012 04:48 PM
  13. Ryuk6666's Avatar
    Your data speeds might be bad in that area or sprint might be working on your data towers. That doesn't happen to me. I don't know about anyone else. Is anybody else having these problems guys?
    08-08-2012 05:01 PM
  14. kirurus's Avatar
    It works fine on CM7. Also it wasn't happening until I tried out Bobz CM9 which is where I first noticed the bug. But it wasn't showing up on quattrimus. For some reason now its happening on quattrimus too. Every time I flash I ROM I start with a clean wipe so I dunno what the issue is.
    Unless the problem was fixed while I was flashing CM7 today >.<
    08-08-2012 05:29 PM
  15. Ryuk6666's Avatar
    We're you in the same area when you tried? If so, people have reported getting worse reception on ics than they do on cm7. ThatGuyLurkin can confirm this . So you might be one the ones that have this problem.
    08-08-2012 05:32 PM
  16. sellers86's Avatar
    For me when I have low signal it works on GB but not ICS.
    08-08-2012 05:38 PM
  17. tdm's Avatar
    On the verge of a functional multi ROM setup. This means the next release will be one ROM file for all phones (well two, one cm9 and one aokp, and maybe aosp if I can fix it).
    08-08-2012 06:55 PM
  18. andrewnelson23's Avatar
    Mind=blown
    jonny5449 likes this.
    08-08-2012 07:01 PM
  19. kcls's Avatar
    Whoops! Double post.
    08-08-2012 07:37 PM
  20. kcls's Avatar
    Have an sd ext? Top link in my signature edit: didn't notice you were on tapatalk the first time I read that. Here's the link http://forums.androidcentral.com/sho...d.php?t=193297
    Yup, creating an ext partition was the first thing I did before flashing Quattrimus.
    @Sellers I have seen reports that only temporarily fixed the problem?
    08-08-2012 07:38 PM
  21. sellers86's Avatar
    I dont believe there is a permanent solution to the problem
    08-08-2012 08:25 PM
  22. ThatGuyLurkin's Avatar
    I always had bad reception on ICS. Not really bad, but worse than normal. 0-1 bar on ICS, 2-3 on CM7. In my house.
    I occasionally notice keyboard lag. Anyone else have it?
    And I also say that this uses a Gingerbread Kernel?
    08-08-2012 09:03 PM
  23. dingermtb's Avatar
    I do believe it is a GB kernel. My reception is spotty in my house. On one side i'll get 2 bars, other side of house i get 1 bar, and upstairs, sometimes 3 bars (it's a row house). Once i get outside though, i get full bars. Then some areas i completely lose signal on outskirts of the city.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    08-08-2012 09:10 PM
  24. droiddekka's Avatar
    Has anyone else noticed that drawing an incorrect pattern on the lock screen will still unlock the phone?
    08-08-2012 10:35 PM
  25. kirurus's Avatar
    It was doing this even with a full signal.
    08-08-2012 10:42 PM
