01-05-2016 05:35 PM
2,975 ... 7778798081 ...
tools
  1. HavocX's Avatar
    Can you guys explain the difference between beta 2 and nightly pls.
    08-10-2012 02:18 AM
  2. nitestalkr's Avatar
    Beta(x) marks each major update/milestone for quattrimus, and nightlies are just small minor fixes, added commits, etc etc..
    Any nightly built after Beta2, will be Beta2+small fixes.
    Nightlies are released nearly every night, or when commits are changed(to prevent unnecessary builds with 0 changes).
    Betas are released whenever something big/important is fixed/added to quattrimus.
    sent from my Zom-"Bean'(CM10 JellyBean).
    RT78 likes this.
    08-10-2012 02:31 AM
  3. nitestalkr's Avatar
    Can you guys modify the kill when pressing the back key? It kills the cell's desktop too
    Just don't hold the back key while on the desktop/homepage.
    It only kills whatever app is being currently used.
    08-10-2012 02:32 AM
  4. kobequintana's Avatar
    Exactly what's wrong with aosp
    08-10-2012 03:56 AM
  5. sellers86's Avatar
    probably something that would blow your mind.. lol. and with the way tdm explains things, it would blow mine too
    08-10-2012 04:06 AM
  6. kobequintana's Avatar
    Lol ok
    sellers86 likes this.
    08-10-2012 04:07 AM
  7. MidtownHD's Avatar
    @tmd, the last few builds (b2/nightlies) set the default ringtone to "silent". I've missed several calls due to this.
    RT78 likes this.
    08-10-2012 12:38 PM
  8. nitestalkr's Avatar
    @tdm, if you don't mind me asking, how was "Android is Upgrading: optimizing 'x' out of 'a lot' of apps..." issue at every boot, fixed?
    Running into this issue on JellyBean..
    08-10-2012 12:56 PM
  9. sellers86's Avatar
    I always got it on quattrimus and I'm getting it on bobzhome too. I don't think its an issue, its just cache or dalvik cache repopulating or something like that.
    a5pe4 likes this.
    08-10-2012 02:56 PM
  10. BuggerZ's Avatar
    I had that same problem you need to make your SD ext bigger
    It's not sd-ext. Internal has 20mb left, and sd-ext has 600mb left, which should be Moore than enough. It's another problem.. Perhaps with /data I'm guessing. We might need to bind more mounts from sd-ext to /data.
    08-10-2012 03:00 PM
  11. andrewnelson23's Avatar
    I get the 'upgrading apps' thing every boot, but it only has one app that it upgrades every boot. And I have like 20 apps besides gapps.
    08-10-2012 04:57 PM
  12. strabo231's Avatar
    Make sure all your apps are moved from the sd card to the phone, not the ones already on the ext, just the ones on the root of the card. Then go into recovery, wipe dalvik, and reboot. That will move the rest to the sd ext
    08-10-2012 05:00 PM
  13. A.I.'s Avatar
    Ram is always 200 below, ICS is a resource hog too?
    Hardware Acceleration adds RAM, amongst other changed. I suggest using KSM - even compcache if its still there and you're desperate for RAM.
    08-10-2012 05:02 PM
  14. BuggerZ's Avatar
    That's the odd thing. I clean wiped for beta 1, and I already had sd-ext ready when I installed it, so there's no left over apps on the system for beta 1. Then I dirty flasheda nightly, then beta 2 over the nightly 7-23. So, considering that, there should be no apps that are not on sd-ext, except for system apps of course.
    08-10-2012 05:24 PM
  15. ilikechicken123's Avatar
    I'm too excited for AOSP
    08-10-2012 05:39 PM
  16. kirurus's Avatar
    Anyone else having issues streaming Pandora over 3G on beta 2?
    Well I fixed my issue using the v1.5.10 of Pandora.
    08-10-2012 06:43 PM
  17. imsparcus's Avatar
    TDM thanks for such an awesome rom. One question though is anyone else having problems with geotagged photos. They keep showing that they were taken in Uttar Pradesh instead of, in my case, Florida. Still my favorite rom; keep up the great work.
    tdm likes this.
    08-10-2012 10:38 PM
  18. bashok's Avatar
    Hey tdm, can you use this ( OTA Update Center: Android developers can now push OTA updates to ROMs ) to help update your ROM's?
    I don't see BETA 2 in ROM Keeper so I am hesitant to update to it.
    08-10-2012 10:47 PM
  19. dingermtb's Avatar
    Use goo manager from the market. tdm has the betas and nightlies there. He's still working out the kinks in ROM Keeper.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    08-10-2012 11:05 PM
  20. strabo231's Avatar
    Must be the data then
    08-10-2012 11:18 PM
  21. sellers86's Avatar
    as do I, its really not that big of a deal. Not sure if its a "bug" though
    08-10-2012 11:24 PM
  22. bashok's Avatar
    I got it, but I don't know where to look to get his recent ROMs.
    08-10-2012 11:55 PM
  23. ThatGuyLurkin's Avatar
    Used AOKP for almost 2 days, I noticed I get Reboots when trying to send a SMS when I'm plugged up via charging.
    Without charging, it doesn't reboot.
    08-11-2012 01:05 AM
  24. dingermtb's Avatar
    Browse all files - devs - tdm - roms - quattrimus - VM670 for Betas or Nightlies - VM670 for nightlies
    08-11-2012 01:16 AM
  25. inceyet's Avatar
    TGL which version you using cause I've been on the 7/31 aokp and besides messing with the oc aside that its been my dd can't stay away I'll go to gsnap and gtr for a lil but ultimately come back to AOKP
    08-11-2012 01:58 AM
